Report from the periodic 5-year inspection of the electrical installation
21951 17
What should a five-year electrical-installation inspection report for a single-family house contain, and is there a standard PINB-approved template?
There is no special PINB-approved protocol template; the inspection scope, test types, and an example report format are described in PN-HD 60364-6, “Low-voltage electrical installations—Part 6: Verification.” [#16567538] You may use your own tables and descriptions, provided the report includes all required information. [#16569913] A comprehensive report can contain the title page, applicable standards, inspector qualifications, instrument and measurement-method details, calibration information, measurement tables, building description, defects, recommendations, final assessment, and contents list. [#16569913] Diagrams, floor plans, and other relevant attachments may also be added. [#16569913] Completed reports are normally not shared publicly because they contain clients’ confidential data. [#16569913]
  • #1 16567503
    retrofood
    Help: 1140
    Rate: 4798
    101pawel wrote:
    - I think someone has such a protocol accepted by PINB,
    There are no such miracles. Everything in the subject, i.e. the scope and types of tests, and even an exemplary protocol model, is found in the PN-HD 60364-6 standard
    Low voltage electrical installations - Part 6: Checking.
  • #3 16568446
  • #4 16568579
    kozi966
    Help: 599
    Rate: 1288
    101pawel wrote:
    I do not find this standard in the free version?
    The standards are paid, there are no "free" standards.
  • #5 16569768
  • Custom inspection protocol structure and required attachments
    #6 16569913
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Buddy, for this you got the number of the standard to get acquainted with the requirements.
    On the other hand, you can create the protocol you like, the most important thing is to include all the important things. I use my own tables and descriptions.
    Sometimes I print only four protocols, each for a different type of measurement (you will find various examples on the Internet), and this is usually enough.
    You can also create so-called books from reviews, where you have a title page, list of standards on the basis of which the report was drawn up, information about the person performing the review together with a photocopy of qualifications certificates, information on the meter and measurement methods, its calibration and calibration certificate, measurement tables, building description, list of defects and post-audit recommendations, ruling and table of contents. Possibly, some attachments, diagrams, floor plans.
    Forgive me but I will not post complete completed protocol. There is confidential data there and I respect my clients. The report belongs to them and if they deem it appropriate, they can make it public, if necessary. I, of course, always keep a copy, but only in case of a random - court, prosecutor, or loss of the original by the investor.
  • #7 16570799
    masonry
    Level 30  
    Help: 106
    Rate: 832
    There is no such thing as:
    Protocols formulas are the whole mass on the internet, just enter the "measurement protocol" into the search engine.
    Secondly, I can not imagine that the measuring laborer does not know what the installation overview is and what the protocol looks like.
  • #9 16571375
  • #10 16571451
  • #11 16573492
    waski78
    Help: 26
    Rate: 89
    I once talked to a friend judge (penal department) how it is with this norms if there are no regulations, and there are norms and stated that if it is so, he (court) would have any grounds for giving a ruling . At the same time, he pointed out that we are all human and that he would do so does not mean that another court would do the same. So he goes to what he wrote
    15kVmaciej wrote:
    But if the installation was made in accordance with standards, it is safe. However, if you refer to ignorance and non-compulsory standards, in case something was done against the norms, how do you prove that the installation is safe?
    Another thing is poorly translated into Polish standards (Dr. Musiał once used to abuse this topic).
  • #12 16626941
    genuinejanbar
    Rate: 17
    15kVmaciej wrote:
    I imagine. For example, many people do not know that the RCD measures the response time and a different time limit is in the case of using RCD in additional protection and another limit in case of application to meet the condition of SWZ.
    In the case of new RCDs, no response time is measured unless something has changed recently.
    And as for the case of reset installations, there is no rule of existing protection there (on the islands), have they been outlawed yet?
  • #13 16626980
  • #14 16627205
    retrofood
    Help: 1140
    Rate: 4798
    15kVmaciej wrote:
    I will be gentle, so I will ask - if we do not measure time, what do we measure and for what purpose?
    Unfortunately, as far as I know, in the Polish version of the standard, they do not deal with solutions used in installations in the UK. But I promise to look again.
  • #15 16627612
    genuinejanbar
    Rate: 17
    15kVmaciej wrote:
    Buddy, for many years there is no zeroing and similar circuses on the Isles.
    In the case of new ones, we measure the trip current to determine if it is in the appropriate range.
    Well, unless something has changed in the last few years ...
    Greetings,
    genuinejanbar.
    PS.
    I assure you that I have read the relevant Polish standards and even a certain green book and in both cases I have made a positive check whether I remember something for them ...;]
  • #16 16633229
    thomyk
    Only the response current is measured at RCD. Time can be additionally.
    Other installations and houses are on the islands. You can not do everything by modeling yourself on other countries. There are other possibilities for eg earthing installations in Norway and others in Poland. Same as energy systems.
    The basis is a sound and reasonable reasoning of problems and their solutions.
  • #17 16633295
    e-sparks
    Electrician specialist
    Help: 77
    Rate: 216
    genuinejanbar wrote:
    In the case of new ones, we measure the trip current,
    Where does this requirement come from? Any recipe or standard would come in handy ...
    The problem is that these years have passed a lot, an age or more ...
    Others are installations bred by Polish ignorant alepstryków.
  • RCD timing depends on test purpose and protection type
    #18 16633459
The discussion revolves around the periodic 5-year inspection of electrical installations in single-family homes, as mandated by Polish Construction Law. The author seeks a sample protocol approved by the PINB (National Building Inspectorate) to understand the required scope of checks, which includes evaluating connections, accessories, protections against electric shocks, wire resistance, and earthing. Participants highlight that relevant standards, such as PN-HD 60364-6, outline the necessary tests but are not freely accessible. Suggestions include creating custom protocols that encompass essential elements like measurement tables, qualifications of the inspector, and recommendations based on findings. The conversation also touches on the variability in service pricing and the importance of understanding specific measurement requirements, particularly regarding RCD (Residual Current Device) testing.
