Understanding Application/Oct_stream: File Types, Extensions, & How to Open Them
tymeczek 37867 0
  • #1 7987152
    tymeczek
    Rate: 154
    application / octet-stream - what is it?
    Such a message often appears when the system cannot cope with opening file downloaded from the website
    As a rule, the problem is not on our side and it is worth experimenting a little extension change and perhaps it will succeed open .
    which files it concerns?
    - application / octet-stream *
    - application / octet-stream bin
    - application / octet-stream class
    - application / octet-stream dms
    - application / octet-stream exe
    - application / octet-stream lha
    - application / octet-stream lzh
    Here you will find links to 20 of the most problematic ones, file extensions along with a description and links to programs that can handle them.
