[Solved] Windows XP Home Edition SP3 - Post-Format Issues: Updates, KERNEL32.dll Error, Opera, and QupZilla
rockboys 3762 17
How can I fix Windows XP Home SP3 so browsers and other programs install and run after a format, when I get KERNEL32.dll and api-ms-win-crt-runtime-I1-1-0.dll errors?
You usually cannot make the newest Opera/QupZilla builds work on XP; the fix is to install older versions that are compatible with Windows XP, because XP does not support software from newer Windows generations [#16702537] [#16702544] [#16707272] In the thread, Opera 36 is mentioned as the last version that worked on XP, so version 47 and similar current releases will keep failing with DLL-related errors [#16702544] The advice was also to install the remaining XP updates first, ideally by leaving the machine online so Microsoft Update can fetch everything still available until it stops, and then install the rest of the software [#16702593] [#16707151] If a program still throws these errors after updating, try an older XP-compatible release instead of copying DLL files into system32 [#16707272]
  • #1 16702503
    rockboys
    Rate: 39
    I have a desktop computer with XP Home Edition Service Pack 3.
    A few days ago, I formatted this computer as the system got virus.
    Now after the format, there were problems with updates and to install and open some programs. Updates after the format were downloaded automatically, yesterday I searched manually with Update, I wanted to install the Opera browser but I get a KERNEL32.dll error. So then I installed Qup Zilla browser - but another error: api -ms -win-cst-runtime-I1-1-0.dll.
    Earlier, when I was making the system from this CD, there were no problems on this computer, now updates - Java was asking for download, now silence. Adobe Flash similarly. How do I get the programs to work, how do I fix it? I searched the net, but nothing specific. Apparently, SP1, SP2 and SP3 are downloaded - because XP is known to support no longer. But I count on forum support, help and advice.
    Updates such as: Microsoft.NET Framework, Microsoft Visual C ++ 2013 Redistributable (x86) or IE8 or WMP11 have been downloaded. Where is the problem :idea:
  • #2 16702537
    kpodstawa
    Help: 234
    Rate: 245
    You have to reckon with the fact that MS Windows XP does not support some software from Vista upwards and choose what you need individually. Java can be installed, but with the message that the system is out of date. Adobe Acrobat Reader - probably up to version 11, v. 9 certainly works. Flash - is no longer used, but can be downloaded from the Adobe website.
    Browser - I use Seamonkey. I know some people are allergic, but my robot works well, so I'm not looking for Firefox, Opera or Chrome. A lot of software has to be selected by trial and error. It is good to use "cleaners" such as CCleaner, Glary Utilities or Easy Cleaner.
    Note: I was having problems with MS Security Essentials - still out of date, despite updating. I installed Windows Defender (you need to look for an older installer) and then ... laboriously looking for an antivirus or not installing at all.
    That's it, because it is a theme-river.
    Krzysztof Podstawa
  • #3 16702544
    sylweksylwina
    Help: 1884
    Rate: 2357
    What version of Opera are you installing? As far as I know, version 36 was the last one on Windows XP. Rather, you have to look for the XP version as most of the latest software requires newer systems.
  • #4 16702570
    rockboys
    Rate: 39
    Opera version 47. It does not have to be Opera, but for it to work, as I mentioned above, Qup Zilla is nice and light under XP but I get this error :?: That's right, most of the latest software requires new systems etc, but even before the format, Chrome and Firefox worked for me. Currently only the Chameleon. Maybe the updates that this XP will download are still missing :?: Wait :?: How to fix why such an error that was not there before? I will install Flash and Java and check what's next. Maybe some other idea :cry:
  • #5 16702593
    kpodstawa
    Help: 234
    Rate: 245
    You can try patience similar to mine - leave the computer connected to the internet (logged out for security) 24/7. It should download those updates that Microsoft has released until the end of support. It is up to you to choose whether to install optional updates as well - I updated everything, because device drivers were also downloaded. Then you have to control the process "manually", because only critical updates are made automatically.
    An estimated indicator that more is not available for download could be the famous "End of Support" info box.
    There is also a "static" method - downloading updates from a "private" repository according to a recipe on the Internet. Packages are installed but not registered with Microsoft Update. Therefore, I advise you to do the first option first.
    KP
  • #6 16702656
    rockboys
    Rate: 39
    I will, I downloaded Jave SE7 and Adobe Flash Player and 129 updates have been downloaded.
    How to fix errors: api-ms-win-crt-runtime-I1-1-0dll? And KERNEL32.dll
  • #7 16707151
    Mario_q
    Maybe try from the beginning, i.e. fresh installation of win XP, install all the updates you have to download and then start installing the rest of the software you have to install. As a colleague said earlier, more patience. XP does.
  • #8 16707272
    sylweksylwina
    Help: 1884
    Rate: 2357
    Try an older version of the software that is compatible with Windows XP.
  • #9 16709414
    rockboys
    Rate: 39
    So I did, from scratch a fresh install, downloaded updates, and today it downloads more.
  • XP software compatibility and antivirus recommendations
    #10 16716006
    rockboys
    Rate: 39
    Krzysztof Podstawa
    From the beginning of my post, the system downloaded the updates twice and now stop, I check the update but there are no other updates, it downloaded Microsoft.NET Framewework probably all that were for XP, from early to later and others like IE8, WMP. I don't know does it matter that this system is in English :?: Microsoft Visual C ++ 2008 and 2015 Redistributable (x86) are missing, I installed Adobe Flash Player 27NPAPI and Adobe Reader8-Polish. Now I wonder what version of Java and where to download it 6 or7, because probably 8 will no longer work on XP, IE browser works I installed K-Meleon and it is very fast which surprised me pleasantly (apparently on the Firefox engine). CCleaner as well, and what antivirus? Is Bitdefender or Panda. I know you have to choose search, but how long to wait for the rest of the update :!:
  • Recommend cleaning, defragmenting, and scanning XP regularly
    #11 16716629
    kpodstawa
    Help: 234
    Rate: 245
    Antivirus package - I did not want to be specific, because I have a luxuriously paid Symantec Endpoint Protection at work. I'm not complaining - it can deal with bugs or network attacks. However, for private and business purposes, I have good opinions about free Comodo, since the time of the firewall for Windows 2000. In addition, I periodically use the free Eset Online Scanner - he was able to clean up after MS Security Essentials or Symantek.
    If you want to work on a computer, my suggestion is this: Do not wait for the next updates, just install the utility software, laboriously clean Windows with the system and external cleaners. Defragment it, because it's probably messed up the disk - system or external tool - Glary has a fast defragmenter with optimizer or Deflaggler (Piriform by CCleaner), which does long but decent. Work normally on the computer. Leave it online and it will look for updates. MS still sometimes publishes security fixes. You won't do it on "tip-top" anyway, and during current operation you have to periodically (e.g. once a month or a week) do so-called system maintenance - removal of ballast files, defragmentation, full and deep anti-worm scanning, etc.
    Krzysztof Podstawa
  • #12 16721562
    rockboys
    Rate: 39
    Krzysztof Podstawa
    Why don't you want to comment on the antivirus, Bitdefender is under XP and very light supposedly copes well with various nuisances from the Internet, Symantec the one you have reading has no good reviews but it's an individual matter Comodo is too heavy for the system apparently, I will not waited for the next updates because it may take time, it's a pity that the XP system is no longer supported :idea: I installed programs that I need, I defragmented with Revo (it has a lot of features) when my system crashed I had no antivirus, I installed Panda and found over 60 viruses, I gave them to cure, but I installed Malwarebytes and found a few more and this program detected some Panda files that it was some suspicious files and maybe I did it unnecessarily (for sure) :!: I deleted these infected files, then the system crashed :cry:
  • XP antivirus recommendations based on long-term experience
    #13 16723667
    kpodstawa
    Help: 234
    Rate: 245
    I did not want to comment on anti-virus programs because my views are very minor, although based on my "work" and private experience.
    For example. Before Microsoft trampled on its Security Essentials (for XP at least), I considered this program to be one of the best free software. It did not silt up inefficient computers and dealt with protection correctly.
    Parallel in time (i.e. the times of XP) MS Defender was completely sufficient for protection, although the system was red communicating the lack of an antivirus program. It could be turned off.
    Like you, I am preparing an XP computer and tormenting it as much as I can before it goes into service. He's online all the time, he only had Defender with a firewall and it didn't get any catastrophe. The fact that the computer has other protection mechanisms, such as strong passwords and an account limited to the current work. For the sake of peace and quiet, I installed Symantek to meet my employer's regulations.
    In turn, the Comodo package has been protecting just as effectively since W2K. It has been a mare for the past four years and can be overzealous. Usually there was something to do, and there was a better false alarm than worming. On W7 it works imperceptibly, on XP it takes efficiency, but not critically. In addition, I had nothing to complain about with the Comodo Dragon browser added. Obviously, I am not a technical guru and I express my opinion from the point of view of a standard user.
    About 5 years ago I tested antivirus packages to choose something free to work with before Symantek was bought. Now I looked at the installers from that period that I did not remove: Avira, Bitdefneder and already removed - Avast, McAfee, Arcabit - there were more, but I don't remember. I did not implement them after the test periods. I would have to strongly remember the reasons and it was not the arrival of Symantec Endpoint Protection. I'm pretty sure after all these packages, Eset Online Scanner cleaned a lot, clearly more than after Essential or SEP.
    Of course, these are observational conclusions, not supported by objective comparative studies in laboratory conditions.
    Krzysztof Podstawa
  • #14 16728546
    rockboys
    Rate: 39
    Still the problem is not solved, unless now the XP system has actually been "killed" but I still can't get over it because before the format, when the system was infected, there were more programs working as I mentioned the Qup Zilla browser very light and fast and I insisted on I also got used to it. Driver Easy downloaded the necessary drivers, the system as I wrote, downloaded updates but stop there, Visual C ++ Packages are missing
    and the browser does not want to install and still shows the api-ms-win-crt-runtime-I1-1-0dll error. However, I do not want to give up, there is an error somewhere, I count on advice with this dll - if it is missing, damaged or look where elsewhere. I heard that you can download this dll file and paste into system32 and it can fix the problem and the Packages download and install.
  • #15 16729551
    sylweksylwina
    Help: 1884
    Rate: 2357
    As I said, try installing older versions of these programs. Before the format, you probably didn't have the latest versions.
  • #16 16729890
    rockboys
    Rate: 39
    Installed Visual C ++ Package, api-ms-win-crt-runtime-I1-1-0dll problem. disappeared but another related to KERNEL32.dll appeared.
    Similarly, with the Safari browser everything is fine but it does not play videos from you tube there is a black screen saying that there is no ffmpeg that I installed and it did not work, I think it has something to do with HTML5 but how to fix it. Similarly, Opera also dark image does not have audio and video. River theme :idea:
  • #17 16748459
    rockboys
    Rate: 39
    Everything is fine, in fact, on XP not everything works anymore, e.g. new browsers or some new programs will not work because the XP system has no support. You only need to install what else works with this system, older versions. Thank you for your help and I consider the topic is closed.
  • #18 17475105
    rockboys
    Rate: 39
    Everything is already on this topic, XP, as almost everyone knows, is no longer supported and you need, as above, the help of colleagues, you need to install older versions of some programs that work on XP. Therefore, with new programs such as the new Opera browser or similar programs, the system will show errors. Thank you and I consider the topic closed.
The discussion revolves around issues faced after formatting a desktop running Windows XP Home Edition SP3, particularly concerning software updates and errors related to KERNEL32.dll and api-ms-win-crt-runtime-I1-1-0.dll. Users suggest that Windows XP no longer supports many modern applications, necessitating the use of older software versions. Recommendations include installing compatible versions of browsers like Opera (version 36) and QupZilla, as well as Java and Adobe Flash Player. Users also discuss the importance of downloading all available updates, using system cleaners, and selecting appropriate antivirus solutions. The conversation concludes with the acknowledgment that many newer programs will not function on XP due to lack of support, emphasizing the need for older software.
TL;DR: Windows XP support ended after “12 years,” so modern apps fail; use last‑supported versions and expect compatibility gaps. “Do not wait for the next updates, just install the utility software.” [Microsoft, 2014]
Why it matters: If you’ve reformatted XP SP3 and see KERNEL32.dll or api-ms-win errors, this FAQ shows which versions still work and how to stabilize the system for basic tasks.
How do I fix the api-ms-win-crt-runtime-l1-1-0.dll error on XP?
Use versions that officially support XP. Forum guidance: install older app builds instead of current releases. Newer software depends on runtimes compiled for Vista/7 APIs that XP lacks. “Try an older version of the software that is compatible with Windows XP.” [Elektroda, sylweksylwina, post #16707272]
Why do I get KERNEL32.dll errors when installing browsers like Opera?
Modern Opera builds require newer Windows APIs. On XP, calls into KERNEL32.dll fail, triggering errors. Install the last XP-supported build, such as Opera 36, or choose an XP-friendly browser. [Elektroda, sylweksylwina, post #16702544]
What’s the last Opera version that works on Windows XP?
Opera 36 is the final branch designed to run on Windows XP. Install that release when you need Opera on legacy systems. [Elektroda, sylweksylwina, post #16702544]
How many updates should I expect after reinstalling XP SP3?
Expect a large backlog. One user reported 129 updates after a clean XP SP3 install. Plan several reboots and long update windows. [Elektroda, rockboys, post #16702656]
Should I wait for every Windows Update before installing apps?
No. Install your utility software and start working; leave the PC online so updates continue in the background. This reduces downtime while XP fetches whatever remains. [Elektroda, kpodstawa, post #16716629]
Which browsers still run reasonably on XP?
Use XP-era browsers. A contributor recommends SeaMonkey for XP, noting stable daily use. You can also explore other legacy Firefox-family builds from the same era. [Elektroda, kpodstawa, post #16702537]
YouTube is black in Safari/Opera on XP—what’s going on?
That symptom matches missing modern media components and HTML5 support gaps on XP-era browsers. One user saw a black screen and ffmpeg complaints even after attempting fixes. [Elektroda, rockboys, post #16729890]
Did installing Visual C++ Redistributable help with runtime errors?
Installing the Visual C++ package cleared the api-ms-win error for one user, but a KERNEL32.dll error then appeared. This edge case shows XP’s API limits even after runtimes are present. [Elektroda, rockboys, post #16729890]
What antivirus setups did forum users find workable on XP?
Reported combos included the free Comodo suite and on-demand ESET Online Scanner. An experienced user noted ESET cleaned more after other tools in their tests. [Elektroda, kpodstawa, post #16723667]
Can I still install Java or Flash on XP?
Yes, with caveats. Java installs but warns the system is outdated. Flash was downloadable then, but it’s deprecated and unsafe for internet use today. [Elektroda, kpodstawa, post #16702537]
Will Windows Update still find anything for XP after a reformat?
Yes, within limits. Leave the machine connected; it can retrieve the remaining XP-era updates, though optional items may require manual review. [Elektroda, kpodstawa, post #16702593]
What’s a safe way to stabilize XP after a format?
Follow this quick start:
  1. Perform a clean XP install, then fetch available updates.
  2. Install only XP-compatible app versions.
  3. Add AV, then clean and defragment before daily use. “Fresh installation… then start installing the rest of the software.” [Elektroda, Mario_q, post #16707151]
Is it worth hunting for more updates, or should I move on?
Move forward with needed software and maintenance. As one expert put it, focus on utilities and routine cleaning; updates may still trickle in, but work shouldn’t wait. [Elektroda, kpodstawa, post #16716629]
Bottom line: Is XP still viable for modern browsing?
Partially. Expect many new programs and browsers to fail. Use older versions that still run on XP for light tasks only. “On XP not everything works anymore… install what else works.” [Elektroda, rockboys, post #16748459]
