IRLR2905PBF vs IRLR3110ZPBF vs IRLR3114 vs IRL3705: Best Transistor for Injection Pump Controller
tomekpppp 22377 9
Which MOSFET is the best replacement for an injection pump controller, and do these candidates have the same switching speed/reaction time?
The thread leans toward the IRLR2905PBF as the most appropriate replacement for this controller, but the real choice depends on matching a logic-level N-channel MOSFET in the small DPAK package with low RDS(on), low gate charge, and at least 55 V rating [#8061235] The replies say the switching speed is not the same for all of them: higher-current parts generally have larger gate capacitance/charge and can be slower, which may trigger control errors in the pump driver [#8061235][#10011288] IRLR3110ZPBF is specifically described as having too high on-resistance, while IRL3705/IRLZ44N do not fit the controller housing; IRLR3705Z and IRL3705ZS are mentioned as usable alternatives if the case is machined [#8061235][#10011288] One poster also notes that if there is a mechanical fault in the pump, no transistor will last [#9702768] For mounting, the practical advice was to solder the transistor and lightly mill the case rather than rely on paste or adhesive [#11632065]
  • #1 8048150
    tomekpppp
    Hello!!
    As in topic :) which of the following transistors:
    IRLR2905PBF IRLR3110ZPBF IRLR3114 IRL3705
    will be the best option? This is to be a transistor for the injection pump controller. The first is supposedly the closest to the original. The most important is the reaction time of all of them. Do they have the same time?
    http://www.datasheetcatalog.org/datasheet/irf/irlr2905.pdf
    http://datasheetz.com/data/Discrete%20Semicon...ETs%20-%20Single/IRLR3110ZPBF-datasheetz.html
    http://www.datasheetz.com/data/Discrete%20Sem...20-%20Single/IRLR3114ZTRPBFCT-datasheetz.html
    http://www.irf.com/product-info/datasheets/data/irl3705z.pdf
  • #2 8061235
    nikimis
    to those listed
    IRLR2905PBF
    IRLR3110ZPBF
    IRLR3114
    IRL3705
    you can still add
    IRLR2705PBF
    IRLR2905ZPB
    IRLU3705ZPB
    IRLZ44N
    it connects them all
    1 / production in the same company IR
    2 / "logical" control
    3 / and the purpose of "automotiv" or motoring.
    4 / sa type Mos-fet channel N
    these transistors and many more can help to regenerate a damaged Bosch pump driver ...
    but how to assess their suitability for this application ???
    maybe from the beginning - for this application they should
    1 / transistors should have a so-called "logical" control level
    that is, it is already attached to a level below 3V on the gate
    2 / min. Current max. 42 A / - resistance of the coil of the dose controller 1,2 ohm /
    3 / small DPACK housing and not 2Dpack - that's why IRL3705 and IRLZ44N do not fit inside the controller and either mill the lid or install it outside
    4 / the corresponding low ON resistance in conduction - the smaller the better
    5 / possibly high speed of work - here, in principle, is coupled with point 2 - maximum conduction current - because the higher it is the higher the gate's capacity and the transistor is "slower"
    6 / operating voltage minimum 55V / for 12V power /
    but "vox populi - vox Dei"
    according to practitioners, the IRLR2905PB is the most appropriate
    but there are those who devoutly believe in the miraculous power of IRLU3705 for the exceptional failure of Bosch's Bosch Focus pump - statistically more than 80% of failures concern this model, especially vintage 1998/1999
    after installation
    IRLR2905ZPB IRLR3114
    or other with higher current and the related gate area capacity, the controller often reports errors due to too slow control of the solenoid valve
    IRLR3110ZPBF has too high resistance in the ON state
    but most importantly - to determine what was the cause of the failure and not to drive with the air in the fuel lines - refuel at least 2/3 of the tank and not allow to "drive on the fumes"
  • #3 9701443
    marcin w
    Rate: 81
    I now have a dilemma with the choice of a transistor, I would like to temporarily heal my VP44 injection pump in the opel and give myself a little time to prepare for the expense related to regeneration.
    The most frequently mentioned are:
    IRLR2905
    VDSS = 55V
    RDS (on) = 0.027?
    ID = 42A
    Pd = 110W
    However, in the Opel forum I found two posts that strongly undermine this transistor
    The man who inserted IRLR2905 twice and fell after 2 days
    as I wrote in my last post I gave up the next transistor replacement and I was going to sell the astra for parts. I put it on eBay. 2 days before the end of the auction, a "potential customer" wrote to me, who asked what was wrong with the pump and offered me a repair if I want. I wrote back to him that I was fixing the driver - after two days it was the same. He was surprised a bit because he thought that only he and his company in the UK knows how to do it ...
    In any case, it stood out that he offered to repair the driver in exchange for information on how I learned about the transistor + opinion about his company at the English automotive electronics forum ...
    I sent the driver, returned after 4 days, astra started and works until now (I've tested it for 2 weeks) :wink:
    I do not know what transistor it used but wrote that it does not mount IRLR2905 because it overheats ...
    Another quote also from the forum
    I have one friend from the forum and I think irlr2905 is poor and irlr3705 perfectly. This fact eliminates the first one.
    The parameters of this recommended one are:
    IRLR3705ZPBF
    VDSS = 55V
    RDS (on) = 8.0m?
    ID = 42A
    Pd = 130W
    I came across several times
    IRL3705ZS
    VDSS = 55V
    RDS (on) = 8.0m?
    ID = 75A
    Pd = 130W
    The symbols are very similar to the two above (IRL3705 and IRLR3705) and are easy to confuse, but the catalog parameters of the allowable current are very different.
    Some still recommend
    IRFZ44N
    VDSS = 55V
    RDS (on) = 17.5m?
    ID = 49A
    Pd = 94W
    IRL3803S
    VDSS = 30V (probably should be enough, rather at 12 V power supply there will be no more voltages in the system)
    RDS (on) = 0.006?
    ID = 140A
    Pd = 200W
    However, nowhere can I find an unambiguous oneanswers, it seems that the most recommended IRLR2905 is probably not the best solution, I have already seen a few entries where professionals repairing these drivers confirm that it is not IRLR2905, but nobody wants to reveal the secret that should be mounted.
    Looking for thermal adhesives, I began to think about one more thing, to improve the heat dissipation of the transistor, it is not better to use thermally conductive paste instead of thermal glue, which has better thermal conductivity. In order for the transistor to adhere well to the surface, it should be well pressed from the top.
    Now I would like to exchange the transistor for days, but I do not know what to install, I bet on IRLR3705ZPBF.
    Maybe someone has already struggled with it and has experience in the practice of inserting transistors.
    Can you say your opinion on this topic?
  • #4 9702768
    janusz2008
    Help: 170
    Rate: 515
    If there is a mechanical cause, no transistor can withstand.
  • #5 9703274
    tomekpppp
    I put in this IRLR2905PBF for 100 km. :) if you have any more questions, write GG 7723234
  • #6 9703901
    marcin w
    Rate: 81
    janusz2008 wrote:
    If there is a mechanical cause, no transistor will last.
    I know about it, but with posts on the forum Opel well-chosen transistor held up to 30 thousand km. Let it with me at least 10 or 5 thousand km, as for me it will be about 2 months, and this will allow me to prepare financially. And the service, if the driver is damaged, will not fix it any more but only replace it with a new one.
    tomekpppp wrote:
    me in my insert IRLR2905PBF was enough for 100 km.
    How did you assemble it, thermal glue or solder permanently to the heat sink?
    As I have already quoted the opel forum, IRLR2905PBF is not suitable due to overheating because I think IRLR3705ZPBF recommended, I even thought I could use IRL3705ZS but 75A would be rather excessive, and I remember that the higher the current, the slower the transistor will be, which can negatively affect the operation of the whole pump.
    If it was possible to mount it on a thermally conductive paste instead of glue, it would be better to dissipate the heat. Soldering permanently to the heat sink would be the best option, only that I do not know how to decorate it without damaging the transistor itself.
  • #7 9707274
    tomekpppp
    for thermo conductive paste
  • #8 9709961
    marcin w
    Rate: 81
    I found a thermal adhesive, one that Arctic Silver Thermal (TM) Adhesive other is THERMOPOX 85 CT . Both have a similar thermal conductivity and much better than the generally available tempered pastes for PC processors. I do not know which one to use, THERMOPOX 85 CT does not have any operating temperatures.
  • #9 10011288
    MSWOLA
    Level 19  
    Help: 20
    Rate: 67
    I saw drivers where IRL3705ZS was inserted in the D2PAK enclosure. You need to cut the housing a little deeper and fit it on the old heat sink. You have to get a little more naked with wires, but somebody does not put them in a way that makes it harder for them to work.
    DPAK
    IRLR3705Z http://www.irf.com/product-info/datasheets/data/irlr3705z.pdf
    VDSS = 55V
    RDS (on) = 8.0m?
    ID = 42A
    Pd = 130W
    Qg = 44nC
    D2PAK
    IRL3705ZS http://www.irf.com/product-info/datasheets/data/irl3705z.pdf
    VDSS = 55V
    RDS (on) = 8.0m?
    ID = 75A
    Pd = 130W
    Qg = 40nC
    The last parameter seems to play an important role here.
  • #10 11632065
    adielektro
    Help: 20
    Rate: 158
    I always solder the transistor and gently mill the case. Every car starts, one drives a long time for the other on the same transistor. No pastes, adhesives and other clamps, full temperature control of the heat sink and two soldering irons and skill = success. An old theme but it keeps coming back.
The discussion revolves around selecting the best transistor for an injection pump controller, comparing four models: IRLR2905PBF, IRLR3110ZPBF, IRLR3114, and IRL3705. Key considerations include reaction time, suitability for automotive applications, and thermal management. The IRLR2905PBF is noted for its close resemblance to the original component but has received mixed reviews regarding reliability. The IRL3705ZPBF is recommended for its lower on-resistance and higher power dissipation capabilities. Users emphasize the importance of proper thermal management, suggesting soldering to the heat sink for better heat dissipation. Additional models like IRFZ44N and IRL3705ZS are also mentioned, with the latter having a higher current rating but potential concerns about slower response times. Overall, the choice of transistor should consider both electrical specifications and thermal performance.
