How to control 230V lighting dimmers and switches from a PC in one device?
amadeo007 6531 3
  • Seeking a PC-controlled mains dimmer and switch
    #1 8095143
    amadeo007
    I’ve already searched the forum and the internet, looking in DIY sections and elsewhere.
    Specifically, I’m interested in a computer-controlled switch for home (or room) lighting – something along the lines of a ‘smart home’.Such a device would control the brightness of a light bulb (a room lamp, a chandelier), switch it on/off, and adjust the mains voltage from 0 to 100% (dimming). On the forum, I found a controller, for example, for controlling RGB LEDs and similar, but no one has posted a device like the one I’m describing, unless I’m searching in the wrong place. I found a device on the forum and on Allegro for controlling relays, but it only allows you to switch the device on and off; it doesn’t allow for voltage adjustment. Is it possible to build something like this in a single device?? If so, how, and if there’s a DIY guide somewhere, that would be even better. Please help :)
    Simply controlling on/off from a PC (50% satisfaction):
    Link to the right device (99% satisfaction), but you need to buy an additional receiver
    Device:
    Description:
    http://www.stelektronik.pl/HAS_R8_2RE_2SW_1001_pl.pdf
    Receiver:
    Description:
    http://www.stelektronik.pl/HAS_R8_TR_0904_pl.pdf
    The cost of the switch itself is around 120 zł
    The second option costs around 700 zł + software (charged separately)
    Why did you delete my post! Do you think I don’t know? Does my friend still not understand Link . You want to build a smart home but you’re having trouble understanding a simple text. I deleted the incorrectly attached files. [Łukasz]
  • #2 8095652
  • #3 8095730
    amadeo007
    Programming shouldn’t be a problem – six years at school studying Pascal, C++ and a few others shouldn’t be too bad:)
    I’ve also heard about the Hall2007 system
    Manufacturer’s website:
    http://neuron.com.pl/hall2007.html
    What do you think of it??
    Has anyone had any experience with it??
    p.s.
    I’m mainly concerned about the price:) I know that for, hmm, 55,000 they’d even give me the software for free, but unfortunately I can’t afford such luxuries, and I know it could be done more cheaply:)
  • #4 8142355
    zubel
    Conditionally unlocked
    Help: 41
    Rate: 129
    A microcontroller + some extra wiring + a few actuators – and you don’t need a remote control or a computer if you just want to play around with the lighting
