Smart home project: audio-visual and fire alarm systems – how to plan them?
jordand 5829 5
  • #1 8114806
    jordand
    First of all, I’d like to point out that I’m not sure if I’m posting this in the right category.
    I’m tasked with designing a smart home, and the systems to be included will comprise, amongst other things, an audio-video system and a fire alarm system.
    I have a question regarding these two systems.
    1) What should the AV system look like, as I can’t find anything to help me with the implementation?
    2) Fire alarm system – is it better to connect the detectors and alarms to the control panel via a wired connection or wirelessly?
    3) Would it then be possible, for example, to connect the alarm control panel to a PC?
    I assume the control panel should have an output for connecting to a PC and that the manufacturer should provide some software?
    Thanks in advance for your help!
  • #2 8115774
    CSC
    Please let me know whether this is to be a theoretical or practical project, and what equipment you have available
  • #3 8116076
    jordand
    This is just a theoretical project, so I’m interested in any suggestions, regardless of the equipment.
    In other words, as far as the audio-video system is concerned, I’m interested in what equipment I should install there and what the overall setup looks like. From what I’ve managed to find on Google so far, I understand that there will be some sort of player in one room and the signal will be distributed to the other rooms from there? What sort of cables should I use? Is it possible to integrate this with the LAN network in some way?
  • #4 8126310
    wezyrek18
    jordand wrote:
    2) Fire alarm system – is it better to connect the detectors and sounders to the control panel via a wired connection or wirelessly?
    Do you want to build a fire alarm system based on an alarm control panel or a separate fire alarm control panel?
    All in all, it doesn’t really matter whether it’s wired or wireless, apart from the fact that the batteries need replacing every few years; personally, I prefer wired systems, where the cables are fire-resistant, of course :P .
    I don’t usually connect alarm control panels to a computer, although a company such as SETEL does have a dedicated network card for this purpose; it allows you to visualise the status of the control panel’s inputs and outputs and provides remote access to the system via the internet – quite a nifty feature.
  • #5 8126533
    deksta84
    Help: 50
    Rate: 84
    As for the video:
    A TV card for a PC isn’t exactly cheap. However, if you want to use a computer for that, why not? Have a look at PCI cards. Check how many inputs they have – though you won’t be able to do without a video selector switch.
  • #6 8140419
    robja
    I have the eHouse smart home system installed in my house which features built-in control of audio and video playback from Winamp directly via a Sony infrared remote control.
    The entire system can be controlled using this remote, amongst other things. In addition, the controllers can operate hi-fi and video equipment (by emulating a remote control – you can teach the system the control codes and then activate them)
