Mini-Jack Input: Understanding Voltage Requirements for Optimal Performance
parkour1995 20898 8
  • #1 8332599
    parkour1995
    Rate: 8
    What is the voltage at the mini-jack input?
    Thanks.
  • #2 8332630
    ajpier
    Level 36  
    Help: 360
    Rate: 477
    What is this input/outlet.
  • #3 8332640
    parkour1995
    Rate: 8
    Where the mini-jack plug plugs in.
  • #4 8332646
    ajpier
    Level 36  
    Help: 360
    Rate: 477
    What am I asking. Microphone, headphones, line-in.
  • #5 8332661
    mirekgnd
    Help: 17
    Rate: 21
    Entrance or exit? This is not the same.
  • #6 8332774
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    This is the entrance so it's how you get there.
  • #7 8333010
    parkour1995
    Rate: 8
    Headphones
  • #9 8349550
    nero226
    Help: 7
    Rate: 9
    "Headphones" - Stupid talk. Specifically where, what? Because it's generally about 2 to 100V.
The discussion revolves around the voltage requirements for mini-jack inputs, specifically addressing the confusion regarding the type of input (microphone, headphones, line-in) and its functionality. Participants clarify that the mini-jack is primarily an input for headphones, with voltage levels generally ranging from 2 to 100V. The conversation highlights the importance of understanding the specific application of the mini-jack to determine the appropriate voltage for optimal performance.
