[Solved] Replacing the 3.5mm 4-pin Mini Jack in headphones with a microphone
Vende123 50274 10
How do I solder a headset cable with microphone to a 4-pin 3.5 mm TRRS jack when the cable only seems to have three visible wires?
Solder it by first identifying the conductors: the black bundle carries the microphone signal and its braid is ground, the green bundle carries the headphone channels, and the red fiber is only a nylon strength member and is not connected [#17027388] Use a multimeter to determine which green conductor is left and which is right, because those two can be swapped and the exact pin order cannot be confirmed from the photos alone [#17029094] The thread also notes that these “three wires” can actually contain multiple varnished conductors, so strip them carefully before soldering [#17027346]
  • #1 17027250
    Vende123
    Rate: 17
    Yesterday evening I had a problem with my Func hs-260 headphones. While moving the cable just under the cover of the jack, the headphones interrupted me until they stopped working. Today I wanted to prepare more or less a scheme for exchanging this plugin, but there is one problem.
    The cable is attached to the headphones (allows the use of a microphone and audio) and is further divided into microphone and audio inputs. So how to solder the cables with the jack correctly? There are only three, red, green, WHITE FIBER, and black, when you need 4 wires for soldering.
    I attach additional photos to illustrate the situation:
    Replacing the 3.5mm 4-pin Mini Jack in headphones with a microphone Replacing the 3.5mm 4-pin Mini Jack in headphones with a microphone Replacing the 3.5mm 4-pin Mini Jack in headphones with a microphone
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1152
    And no braid is tangled there [the screen]. As the fourth wire.
    You can ask for a photo of whole headphones.
  • #3 17027287
    Vende123
    Rate: 17
    As you can see, the microphone is also detachable. It is indifferent from which side it will be connected.
    And as for the fourth wire, I did not notice anything like that. Looking at the cable cut straightly, only three wires are available.
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1152
    In the pictures you can not see how many individual plugs are there: [green and red] (3 pins) ?. And we are to understand that this cable was damaged next to the plug [4 pin]? Attached to the headphones.
    The headphone plug is probably demountable and you can view the connections.
    E8600
    Help: 529
    Rate: 2515
    These wires are not a 2-strand case of each of these 3? Have you tried to gently remove the insulation from them?
    They can be varnished wires of different color of varnish.
  • #6 17027366
    Vende123
    Rate: 17
    Adds such an amateur scheme here to know where the problem is Replacing the 3.5mm 4-pin Mini Jack in headphones with a microphone
    And now yes, I checked these veins and there are actually several wires in them:
    -Black: Copper around white insulation, white insulation in which there is also copper (2)
    -Green: Green coated line, red varnished and plain copper (3)
    - Red: Only fiber (I checked 2x so I do not know why)
    Now a little more is known, now the question is how to solder it?
    E8600
    Help: 529
    Rate: 2515
    In black, it's signal on the microphone and the copper braid is mass.
    In the green copper wire the remaining mass is the left and right channel (using the multimeter you check the left and right channel).
    Red is a normal nylon cable that prevents damage to the wire when stretched (it is not connected anywhere).
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1152
    How would you like to upload photos from the work done. How does it look after soldering.
  • #9 17029012
    Vende123
    Rate: 17
    So what will the order of soldering on this Jack, looking at the pictures that I threw in the post?
    E8600
    Help: 529
    Rate: 2515
    Without measurements, you can only shoot. Probably it will be ok (if the plug is not in the Apple standard).
    Like the description in black. The highest left and right channels can be swapped, but this should not disturb (you would have to check it with a multimeter).
  • #11 17579664
    Vende123
    Rate: 17
    I bought new headphones. Repairing it was hard, for small soldering elements.
✨ The discussion revolves around the issue of replacing a damaged 3.5mm 4-pin mini jack in Func HS-260 headphones. The user encountered a problem where the headphones stopped working after moving the cable near the jack. They sought advice on how to properly solder the cables, which consist of three wires: red, green, and a white fiber, with confusion regarding the fourth wire necessary for the 4-pin connection. Various responses provided insights into the wiring configuration, suggesting that the black wire is for the microphone signal, the green wire carries the left and right audio channels, and the red wire serves as a protective element. The conversation included requests for additional images and clarification on soldering order, ultimately leading to the user deciding to purchase new headphones due to the complexity of the repair.
