Connecting the microphone to the computer. (XLR input with minijack adapter)
anetairafal 8058 7
  • #1 16359390
    anetairafal
    Hello, I would like to ask for help.
    I bought my daughter a dynamic microphone and it turns out the XLR tip. I bought a minijack adapter and connected it to my computer. Daughter did a trial recording and the noise only (noise filter is also included). How to connect it correctly? I searched and read about some mixers and preamplifiers but I don't know what and how. Mixer - too expensive. And how does the preamplifier work? Would that solve the problem?
  • #2 16362469
    RAFI462
    Rate: 27
    Computer-connected (electret) microphones work on a completely different principle from dynamic microphones.
    The microphone connected to the computer needs power from the sound card to operate
    A dynamic microphone works on the principle of a coil which, under the influence of sound wave vibrations, generates an electric field, therefore such a microphone will not work, because it sends a signal in a different way.
    So you need a transducer (simple mixer or amplifier). Personally, I recommend a mixer (even a simple model) will have sound correction and several signal inputs
    We connect the mixer with a usb cable if it has an audio interface, or a jack - chinch cable to the line input
    To start with, just a regular Behringer or LD at a price of around PLN 200 (new) can be found even with a USB interface.
  • #3 16362497
    anetairafal
    Thank you very much for the clarification. I found this amplifier. So I'll buy him. Oh, I didn't know so much trouble. Well, but as already said And you have to B.
  • #4 16362543
    RAFI462
    Rate: 27
    Hello. It's not a problem. Only when you buy "professional" equipment you need to buy equipment that will be able to handle it later. And besides, such a mixer can be directly connected to a set of speakers, on the second channel let the backing from the smartphone and there is already a party. :) I used to do this too. I know from my own experience that when you start it is better to add a bit and buy something mid-range (or even from the lowest good music store) than add it later (because something will break).
  • #5 16362564
    anetairafal
    Well, my daughter loves to sing and wants to make recordings with better sound, I just didn't know that when I buy a better microphone I need so many other devices. But as you write at the beginning it will be good. :)
  • #6 16362699
    yogi009
    Help: 848
    Rate: 2650
    Buddy, think about an external 24-bit sound card with a mic preamp then. There you will have access to your microphone and professional sound as well as software for its recording and semistudio editing (e.g. adding effects, etc.).
  • #7 16362713
    RAFI462
    Rate: 27
    Hello. The author of the topic was more about price and quality. I have my Yamaha S770 and the sound quality on this equipment is enough for me. I use a mixer, even a built-in computer to create arrangements I don't need. Of course, there are sound cards but at 700+ prices, unless I just don't know what a colleague means.
  • #8 16405519
    anetairafal
    you helped me a lot. Problem has been solved. Thanks.
✨ The discussion revolves around connecting a dynamic microphone with an XLR output to a computer using a minijack adapter, which results in poor audio quality characterized by noise. Users clarify that dynamic microphones require a preamplifier or mixer to function properly with a computer, as they do not receive power from the sound card like electret microphones. Recommendations include purchasing a simple mixer or an external sound card with a mic preamp to improve sound quality. Brands like Behringer and Yamaha are mentioned, with suggestions to invest in mid-range equipment for better performance and future compatibility.
