Standard PC Audio Jack Output Power: Comparing Wattages for Motherboard Integration & Amps
pawel45sw 8442 9
How many watts does a standard motherboard PC audio output provide, and can it drive a small amplifier or speaker directly?
A PC audio jack does not have one fixed wattage; when feeding an amplifier, the important parameter is output voltage, and a typical line-level signal is about 2 Vp-p rather than a specific number of watts [#16706353][#16706355] The exact output depends on the sound card, and one reply notes that some Realtek devices are specified at 2 to 3 W [#16706651] If you want to know the real maximum on your PC, generate a 50–100 Hz 0 dB sine wave and measure the output voltage with a multimeter [#16706358] Do not connect a 3 W, 4 ohm speaker directly to the motherboard output, because that load is too low and can burn the sound card; one reply says a minimum of about 32 ohm is appropriate [#16706819]
  • #1 16706270
    pawel45sw
    Help: 5
    Hello. does any of your colleagues know how many W has the standard audio output from the PC? I know there is 0.5w in the phone. I think there are more in pc. When there is a 2x3w amplifier for a PC, then at half the volume the distortion begins, and the phone's volume level is Max and it is ok. I do not use any sound card except the one integrated with the motherboard.
  • #2 16706353
    elektryku5
    Help: 460
    Rate: 1055
    When connecting an amplifier, the amplitude at the output is more important, and yes, the PC can have a larger one, because the impedance at the input of the amplifier is high, unlike, for example, headphones.
  • #3 16706355
    sylweksylwina
    Help: 1882
    Rate: 2355
    The power depends on many factors, including on the impedance of the connected receiver - in the case of an amplifier it is a value so large that the power is practically not lost anywhere.
    In this case, we can talk about the level of the output signal, i.e. voltage, not power. It would be best to measure it at the output of the sound card, although such a typical value when it comes to the output signal level of various audio equipment is around 2 Vp-p. Unfortunately, without measurements under specific conditions, one can only assume what the maximum output power will be, or study a specific application of some integrated audio codec on the motherboard.
  • #4 16706358
    elektryku5
    Help: 460
    Rate: 1055
    You can always create a file with a sine of 50-100Hz 0dB and measure the voltages with a multimeter in both cases (lower or higher frequencies do not make sense, because for an ordinary multimeter it can be a problem).
  • #6 16706768
    pawel45sw
    Help: 5
    I wanted to know this, because in one computer I have a built-in 3w 4ohm speaker and I wonder if it can be connected without an amplifier.
  • #7 16706819
    pitrala1
    Help: 129
    Rate: 111
    You can, only after a short time you will burn the sound card. It is not adapted to such a low impedance load.
    In any case, I do not recommend it. Older, much older sound cards sometimes had 2 outputs, one of which was adapted to passive speakers, but that was ages ago.
  • #8 16707310
    pawel45sw
    Help: 5
    What if there was anything else to charge the sound card? The second speaker, for example? The motherboard is asus a7v8x-x. The amplifier was connected to the front panel, because the connector was free. In general, I'm going to put a music card there, because the drivers keep breaking down all the time. I don't remember the name of the card, but it's a soundblaster from Creative.
  • #9 16708678
    pitrala1
    Help: 129
    Rate: 111
    The only thing you can put in a loudspeaker, e.g. from large headphones, is 32Om minimum.
    Drivers corrupt, i.e.?
  • #10 16708964
    pawel45sw
    Help: 5
    I had a big problem with the sound. I tried different drivers and none of them wanted to work. Eventually it caught on and there was a sound. However, at some point he disappeared by himself. It is not on the built-in speaker or the external one. That's why I want to put a music card there.
The discussion centers around the output power of standard PC audio jacks compared to mobile devices, specifically addressing the user's inquiry about wattage. It is noted that PC audio outputs can typically deliver around 2 to 3 watts, depending on the integrated sound card, such as those from Realtek. The conversation highlights the importance of impedance when connecting amplifiers and speakers, with warnings against connecting low-impedance speakers directly to sound cards, as this can lead to damage. The user also expresses issues with sound card drivers and considers upgrading to a dedicated sound card, specifically mentioning a Creative Sound Blaster model.
