Failure LED On in Electricity Meter: Short Circuit Sign? Energy Consumption & Expert Opinion
wkamyczura 84583 9
Can the failure LED on an electricity meter indicate a short circuit in the building wiring, or does it mean something else?
No — the failure LED on this meter does not mean there is a short circuit in the building wiring; it is used to signal meter damage or unauthorized tampering, such as magnetic interference or an attempt to remove the meter [#8371081][#8372385] It can also light when one phase is missing, and on some three-phase inductive meters it may appear after a wrong phase sequence [#8371101][#8387917] One reply also says a lightning strike could damage the meter and trigger the indicator [#8371135][#8371192] If all receivers are switched off and the meter stops, that argues against a permanent short circuit in the installation [#8371192][#8373093]
  • #1 8370999
    wkamyczura
    Rate: 16
    I have a question whether the glowing failure LED in the electricity meter may be a sign of a short circuit in the building's electrical system itself.
    The energy guy came and said he checked the meter and it was OK - and the LED was on.
    He said that he thought the consumption was very high according to the meter and that this could be a short circuit problem in the electrical system.
    But I turned off all the receivers from the sockets and the counter stopped.
    If there was a short circuit in the installation, should this meter still not show energy consumption?
    Thanks in advance for your feedback.
  • #2 8371081
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    Failure light means that someone has tampered with magnets on the meter.
    Inflated indications the same.
    Definitely not.
  • #3 8371101
    prosiak_wej
    Help: 501
    Rate: 1461
    Hence the great popularity of neodymium magnets on Allehehe. It's good that you got a guy who did not pursue the topic, because it could end up badly ...
    On the other hand, the lighting of the 'failure' led on the meter may mean that one phase is missing. You may not notice this during normal operation if you have sockets and lighting on the other two (which are present). I have phases divided into rooms and when one of them goes out, it is usually the one in my room and studio. And the other rooms are supplied with energy :)
  • #4 8371108
    wkamyczura
    Rate: 16
    So, I have a question whether a lightning strike (about 2 weeks before noticing the diode has collapsed in the area so that my satellite decoder burned down, and even televisions and computers at my neighbors) could be the reason for this error?
    Added after 4 [minutes]:
    What if I found a guy cool, I don't know - I'm not at home and he came to check it today (I reported this problem to ZE) and I'm at work.
    the guy said he would have to replace the meter and the one that is sent to the forensic examination is due next week to replace it.
    When it comes to magnets, no one was up to anything with them - it is a single family house and I think I know what I was doing
  • #5 8371135
    prosiak_wej
    Help: 501
    Rate: 1461
    If you haven't magnetized anything, the so-called the forensic opinion will probably show that the meter was damaged by lightning. The meter belongs to ZE, so they should replace it on their own, but you should not bear any costs associated with it. About three years ago they exchanged with me, because the old one was about to end ;) They came, turned the electricity off, replaced, sealed, turned on the electricity, went. They got a cake and coffee ;)
  • #6 8371164
    wkamyczura
    Rate: 16
    ok.thanks just to be sure, because a few weeks ago I was doing a renovation and I was wondering that maybe if I drilled something, I drilled a cable somewhere and maybe that's why there is a failure on the meters (I do not remember anything more than this lightning and renovation which could cause a problem) - this diode and the faster (in my favor) counter should not be due to a short circuit inside the building?
  • #7 8371192
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    There are contractors inside which, after detecting the magnetic field, short-circuit the control circuit with the fuse, which causes it to burn and causes the failure to glow.
    This lightning could have caused it, since your decoder burned down, after the expertise, if they do not detect the magnetization of the meter, they will not accuse you of anything, but these inflated indications are definitely not a matter of lightning.
  • #8 8372385
  • #9 8373093
    parura09
    Rate: 26
    My friend, I also have a counter with a failure signaling diode, but for me it only lights up in the absence of a phase, but it never lit when I had a short circuit and when the fuses worked, the guy from the power plant did not check the pre-meter protections, maybe it worked causing disconnection of one phase and therefore the diode in the meter is lit.
  • #10 8387917
    Dixi68
    Help: 6
    Rate: 23
    The FAILURE diode is to signal the damage of the meter and not the damage in the installation. It's a pity you didn't enter the meter type. If it is an inductive meter, e.g. C 52z, the FAILURE diode may turn on e.g. after changing the phase sequence in the power supply. You don't even need to know about it. The repair of the power grid may have happened outside of your territory, and although it shouldn't happen, it does not always happen in life. And why does the meter activate failures at such a moment? Well, because sometimes in induction meters (of course three-phase) when there is no proper phase sequence, the dial does not stop in the so-called brake point and may rotate slowly even after the post-stop fuses are turned off. You can check it at your place. The brake point is a black or red line on the dial. Before turning it off, place it more or less in the middle of the window and see what happens.
The discussion revolves around the implications of a glowing failure LED on an electricity meter, with concerns about potential short circuits in the electrical system. Users share insights that the failure LED may indicate unauthorized tampering, such as the use of magnets, or issues like a missing phase in the electrical supply. One user speculates that a recent lightning strike could have damaged the meter, while others suggest that the meter's failure indicator does not directly correlate with short circuits. The consensus is that if the meter is functioning correctly, the failure LED should not indicate a short circuit, especially if energy consumption ceases when all devices are turned off. The discussion highlights the importance of professional assessment and potential meter replacement by the energy provider if damage is confirmed.
