Red Light Indicator Meaning on 3-Phase Electricity Meters
manok 58724 9
What does the red light on a three-phase electricity meter indicate?
The red diode indicates that one phase is missing; when the third phase returns, the light should go off [#1814734] If it stays on, check whether a fuse or the pre-meter protection has blown and report the fault to the electricity supplier/owner of the meter (ZE) [#1857275][#20155269] If the meter was just reinstalled and the lamp came on immediately, the phase sequence may be wrong or one voltage coil may be connected in reverse, so the wiring should be corrected [#1860826]
  • #1 1814371
    manok
    Rate: 10
    What does the red light in the 3-phase meter mean?
    • Red Light Indicator Meaning on 3-Phase Electricity Meters licznik3fazoy.jpg (37.34 KB) You must be logged in to download this attachment.
  • #2 1814606
    Aleksander_01
    Help: 1167
    Rate: 3435
    Please provide what is written on the yellow sticker and next to the diode. If it is a new meter, the red diode may signal play with neodymium bulbs.
    Regards
  • #3 1814671
    manok
    Rate: 10
    Text on the sticker "High fees will be charged for damaging the measuring device and breaking seals"
    Nobody played with magnets at the counter.
    Currently, there is only one phase
    Aleksander_01
    Help: 1167
    Rate: 3435
    This means that the diode indicates the absence of one of the phases. Report this problem to ZE. The diode will turn off when the third phase appears.
    Regards
  • #5 1814779
    manok
    Rate: 10
    Thank you very much for your help
  • #6 1856052
    arturo29
    Hello ! This happened to me once when I connected such a meter, try to change the order of the power phases, if you have access to the meter or the meter is not sealed, best regards, Artur
  • #7 1857275
    Andrzej .W
    Rate: 40
    As written earlier - the red diode signals the absence of one phase, i.e. either the fuse in the network or in the pre-meter protection may be blown/they are sealed and this fact should be reported to ZEO/
  • #8 1860826
    7garfield7
    It means the absence of 1 or 2 phases at the same time, if there are no 3, nothing lights up :-) ). If such a diode turned on immediately after the meter was reinstalled, it means that the phase sequence has not been maintained and one of the voltage coils is connected in the opposite direction. Just connect it correctly and it`s ok.
  • #9 20155168
    tenshigames2000
    Regards
    What does ZE mean? Where should I report it?
  • ZE means the electricity supplier and meter owner
    #10 20155269
    Tomek.K.
    Help: 255
    Rate: 536
    Regards
    ZE: Power Plant, i.e. the electricity supplier, the owner of the meter.
    A failure should be reported if 1 phase is missing. The energy emergency service only checks up to the cable connection, and if there is something further towards the premises, they do not deal with it.
The red light indicator on a 3-phase electricity meter signifies the absence of one or more phases. Users are advised to report this issue to the electricity supplier (ZE) if one phase is missing. The light may also indicate a problem with the phase sequence or a blown fuse. If the meter was recently reinstalled, incorrect phase connections could be the cause. Properly reconnecting the phases should resolve the issue. The yellow sticker on the meter warns about high fees for damage or tampering.
