Required Permissions & Steps for Connecting an Induction Hob: E Assembly, Measurements, Warranty
Miniax 92539 16
What qualifications are required to connect an induction hob: is E assembly up to 1 kV enough, or are measurements and D qualifications also needed, and what must be entered in the warranty card?
For the actual connection, an electrician with E assembly qualifications up to 1 kV is enough, and item 5 is not required [#8608209][#8608504] If the manufacturer does not request a test/measurement report, no additional D qualifications are needed for the connection itself, though some people still recommend checking the correctness of the work [#8608209][#8607713] For permanently connected equipment, some replies say measurements and a protocol may be required for commissioning, with signatures from the persons who performed and checked the measurements [#8607608][#8607630] In the warranty card, a stamp is not generally required; the forum consensus was that name and surname plus the qualification certificate number are sufficient, and some manufacturers accept a signature or stamp if they explicitly ask for it [#8607713][#8608209]
  • #1 8607450
    Miniax
    Electrician specialist
    Help: 173
    Rate: 290
    I have a fairly simple and layman question, because the recent discussions on the forum about what can and cannot be done with given permissions have mixed me up a bit.
    Namely, what specific permissions are required to connect an induction hob and similar equipment. Is E assembly enough (if so, with what subpoints), do you need E + measurements, or maybe E + measurements and D?
    And is a stamp required in the warranty card, or is a signature with the authorization number sufficient?
    I am asking this question because I could not find a specific answer anywhere. It says everywhere that permissions are required, but no one wrote what.
    Thank you in advance for your understanding ;)
    remik_l
    Help: 144
    Rate: 325
    For connection, the authorizations at the operating position (E) are sufficient, but to accept a given device for operation you must, among others, perform measurements (E + measurements + another person trained in OHS), check the results (D + measurements) and prepare a protocol signed by the persons performing the measurements, the person checking and the person for whom the measurements were performed.
    It is best to provide a photocopy of the authorization for the protocol.
    If I am wrong somewhere, please correct it.
  • #3 8607630
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Some manufacturers "require" only a Qualification Certificate at the operating position up to 1kV (renovation, installation) - by writing "an authorized electrician" in the warranty card, while others additionally require "certification" with a stamp (with the address), and as you know, you should comply with manufacturer's requirements because no warranty will be obtained :cry: If the receiver is connected permanently, such as this kitchen, it is necessary to take measurements and prepare a report, and this again requires an authorized electrician to sign his work. Nobody will question that :) (I only wonder who will pay for the measurements :) )
    I think everything is included in the device manual :)
  • #4 8607672
  • #5 8607677
    czesiu
    Help: 454
    Rate: 841
    And if the disc is damaged, they will tell you to unpack it and send it to the service. :)
    I wonder what measurements they can expect. As for the measurement of the circuit ended with a box for connecting the plate (SWZ, insulation), it could have been done before buying and connecting the kitchen, i.e. at the time of completing the construction of the installation.
    After connecting the swz and rez board, the circuit insulation will not change, and the insulation resistance of the board itself with the factory wire, as well as the continuity of the factory PE wire, should be checked by the manufacturer before launching the product on the market. That's my opinion.
    retrofood
    Help: 1140
    Rate: 4798
    It is best to provide a photocopy of the authorization for the record.
    I have never faced such demands.
    The manufacturer wants the cooker to be properly connected to each type of electrical installation. Because it determines the user's safety and the proper operation of the device. Therefore, its connection should be made by an electrician with a valid assembly group for devices up to 1 kV. And nothing more. Nobody requires a stamp, but you must provide the name and surname, PESEL number, and the number of the qualification certificate. The address is not required.
  • #7 8607754
    Miniax
    Help: 173
    Rate: 290
    And traditionally, how many people have so many different answers. You can see what our right is ;)
    The only question is who is right?
    (of course, I asked about the situation with the completed and measured installation, with a ready box for connecting the plate, and the plate connected permanently).
  • #8 8607814
  • #9 8607917
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Manufacturers reserve, under the pain of losing the warranty, that the connection may be made by a person having the appropriate electrical qualifications. The question arises what are the appropriate electrical qualifications to connect an electric stove :) In the case of a device terminated with a plug - none.
    If I'm not mistaken, the producers of Goranje and Whirpool require a stamp. What if we don't have it? In my opinion, the warranty card should then contain the name of the installer, authorization number and possibly the installer's home address. The question is who to bring to criminal liability in the event of problems. I have not yet met with the necessity to provide a PESEL number - or maybe I have not connected many cookers :)
    When it comes to taking measurements to a permanently connected receiver, shouldn't we even check the continuity of the protective conductor? A good (cautious) installer, as a "dupochron", will perform the measurements even in the case of replacement of the socket. This is not a must for this stove - but rather a good rule of thumb.
  • #10 8607966
    Miniax
    Help: 173
    Rate: 290
    So, to sum up, in the case of an installation prepared for connecting the plate, to make the connections, the E qualifications in the field of installation, point 2 (or maybe 5) are sufficient? and in the warranty card, your data + signature if there is no stamp?
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    It is enough to connect an electrician with an E-assembly up to 1kV (stamp or entered data). Although it is advisable to check the correctness of the activities performed (as I mentioned), the manufacturer does not request a test report - then you need a "slightly" wider scope of rights :)
    Unfortunately, not everyone knows about it and it is a pity that there is no such record. However, I believe that such a provision should be included in the terms of the guarantee.
    (or maybe 5)
    What is he saying? :)
  • #12 8608259
    Miniax
    Help: 173
    Rate: 290
    Thanks for the answer ;)
    I meant what sub-points in permissions are needed.
    Is subsection no. 2 - devices, installations and power networks with a voltage of not more than 1kV. Is also the subsection no. 5 - electrothermal devices.
  • #13 8608469
    retrofood
    Help: 1140
    Rate: 4798
    This is due to the fact that there is no address on the qualification certificate, only the PESEL number. The address falls under the Personal Data Protection Act.
  • #14 8608504
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Is subsection no. 2 - devices, installations and power networks with a voltage not exceeding 1kV. Is also the subsection no. 5 - electrothermal devices.
    Item No. 5 is not required.
  • #15 8608515
  • #16 8608706
    remik_l
    Help: 144
    Rate: 325
    elek2000 wrote:
    "Give the recipe where it says that the measurement protocol is to be signed by a specialist with group E and by a specialist with group D, not to mention the person for whom these measurements were performed.
    Maybe there is no such provision, but in the protocols, I have repeatedly found places where such persons sign themselves. More than once, I took the protocols to the person commissioning the measurements to be signed and the second (signed) copy was brought back to the company, which ended up in the binder.
  • #17 8608789
The discussion centers on the necessary permissions and steps required for connecting an induction hob. It is established that an electrician with E assembly qualifications is sufficient for the connection, but measurements must be performed to ensure safety and compliance. The consensus indicates that both E qualifications and measurements are necessary, with some suggesting the need for D qualifications as well. The warranty card typically requires the electrician's name, authorization number, and sometimes a stamp, depending on the manufacturer's requirements. Brands like Gorenje and Whirlpool are mentioned, with specific emphasis on their warranty stipulations regarding installation qualifications.
