Electrolux EHI6540FHK - how to connect an induction hob - 3 phase installation
Arencjo1 11394 4
  • #1 16248784
    Arencjo1
    Rate: 8
    Hello, I have to connect the induction hob and the problem of how to connect it, so as not to burn it.
    Attached with pictures of cans and plates.
    In the manual - the board is under 220/240 V power supply.
    Thanks for the help in advance.
    Electrolux EHI6540FHK - how to connect an induction hob - 3 phase installation20170202_2..315.jpg (620.03 kB)You must be logged in to download this attachment. Electrolux EHI6540FHK - how to connect an induction hob - 3 phase installation20170202_2..419.jpg (680.67 kB)You must be logged in to download this attachment.
  • #2 16248859
    mietek654
    Help: 140
    Rate: 292
    Welcome to the instructions of the plate should be everything described.
    osiniak75
    Help: 350
    Rate: 544
    And the plate on warranty? Because it would be appropriate for a qualified electrician to make connections. Otherwise, in the event of damage to the disc, there may be problems with the warranty repair.
  • Have an electrician certify the induction hob connection
    #4 16251658
    wojpok
    The record cost you about PLN 1,400.
    The electrician will take about PLN 100 for connecting the certificate with a stamp that the board has been properly connected. Plus some 20 zlotys for a household appliance box to seal this. You give PLN 120 and sleep peacefully.
    But if it's still too much for you, then the connection instructions are usually on the cable or on the bottom of the board. If you do not understand the information contained therein, and you are not able to verify the correctness of the home installation Do not do it alone!
  • #5 16435137
    Arencjo1
    Rate: 8
    I close the topic, everything works, connected by colors
