C++ Program: Temperature Conversion with T Key Repeating & N Key Closing (Celsius to Fahrenheit)
kakus777 21320 12
How can I make a Celsius-to-Fahrenheit program repeat after pressing T and exit after pressing N?
Use a `do-while` loop: after each temperature conversion, ask whether to repeat, read one pressed key into a character variable such as `CzyKoniec`, and continue only when it is `T`; if the user presses `N`, the program exits [#8639226][#8642867] The calculations should be inside the `do { ... }` block, and the key must be read before the loop condition is checked [#8642867] You do not need to initialize `CzyKoniec` before the loop if you assign it from keyboard input inside the loop [#8642867] A loop is the right solution here rather than trying to solve it with only `if` statements [#8636708][#8639311]
  • #1 8636185
    kakus777
    Hello, I have a program that converts degrees Celsius to degrees Fahrenheit and I have to put a query into it at the end after the calculations. When I press the T key, it is to repeat the calculations, and if the N key is to close the program.
    I put a program and ask for help
    [code:1:6854be4f2d]
    #include
    #include
    #include
    #include
    using namespace std;
    int main()
    float c;
    float f;
    cout > c;
    cout
  • #2 8636329
    Dżyszla
    Help: 1095
    Rate: 226
    heard a colleague about the loops?
    Mad.
    Help: 37
    Rate: 16
    As above, read about loops first and then try something like this:
    do{
    // wstaw tutaj swój program
    // dopisz sprawdzanie klawisza, wynik zapisuj do zmiennej
    }while() // w () sprawdzaj wartość zmiennej
  • #4 8638670
    kakus777
    I understand loops but I have such a task to do to make loops with the keys from the keyboard t and n. And I do not know how to assign it; /
    Write a program to convert temperature in degrees Celsius to temperature in degrees Fahrenheit according to the formula TC = 5/9 (TF-32). Each time the calculations are made, the user is asked "Should I repeat the calculations (Y / N)?" If the answer is "T" (the letter T is pressed on the keyboard), the calculations continue. If the user presses the N key, the program exits. The program should only respond to the T and N keys.
  • #5 8638773
    walek33
    Help: 132
    Rate: 81
    I would like the use more if .
  • #6 8638972
    kakus777
    but how to assign it because I don't know how; /
  • #7 8639226
  • #8 8639311
    przemo_wielki
    Help: 61
    Rate: 10
    This can only be done with if, but without labels, it will not happen because "The program should only respond to the T and N keys". Listen to the advice of colleagues, do it on the while loop because you are unnecessarily trying to complicate such a banal code.
  • #9 8639383
    kakus777
    char Czykoniec;
    what should be in the final condition ???
    while (Czykoniec == 'T');
  • #10 8639392
  • #11 8642769
    kakus777
    someone could correct me, because I click a key on the keyboard when calculations are made and the program turns off; /
    [code:1:a2c5fdd813]#include
    #include
    #include
    #include
    int main()
    char Czykoniec = 'T';
    do {
    float c;
    float f;
    cout > c;
    cout
  • #12 8642800
    Dżyszla
    Help: 1095
    Rate: 226
    to my knowledge this program should not compile at all. What is this incomplete do loop, and then two while loops? I don't understand ...
    First, by doing a do..while loop, you don't need to initialize the variable's value before the loop. Second - where is getting the key character right before the end of the loop?
  • #13 8642867
    Mad.
    Help: 37
    Rate: 16
    The program compiles surprisingly ;) What is in red -> does not match.
    down Czykoniec = 'T';
    while (Czykoniec! = 'T' && Czykoniec! = 'N');
    } while (Does the end! = 'T');
    getch ();
    It should be like this:
    do
       // obliczenia temp.
       do
          // instrukcje:
          // pytanie o powtórzenie programu
          // pobranie klawisza wciśniętego przez użytkownika
       while(warunek1);
    while(warunek2);
    Where there is an instruction, you have to read the typed key by the user and save it to the variable Czykoniec. Additionally, just enter the yes / no question there, because if the person gives something other than Y / N, he will see the same question again. The outer do-while loop is fine, so are the conditions.
    As Dżyszla wrote, you do not have to initiate Czykoniec with some value because you will have to get it from the user anyway.
The discussion revolves around a C++ program designed for converting Celsius to Fahrenheit, with specific requirements for user interaction via keyboard inputs. The user seeks assistance in implementing a loop that allows the program to repeat calculations when the 'T' key is pressed and to terminate when the 'N' key is pressed. Various responses suggest using a do-while loop to handle the input and control flow, emphasizing the need to read a character from the keyboard and check its value to determine the next action. Suggestions include initializing a variable to store the key input and using conditional statements to manage the program's execution based on user input.
