Removing Stuck Steel Rim from Hub: Solutions for Seized & Hard-to-Remove Wheels
khali 44294 26
How do I remove a steel wheel rim that is seized onto the hub?
Loosen the wheel bolts/nuts slightly, apply penetrating oil or kerosene around the hub, and then use short forward/back or braking jerks to shock the wheel free; if needed, tap around the wheel perimeter from the inside with a wooden or rubber hammer or a board, not on the rim edge [#8656833][#8657225][#8660761][#8660445] If that still does not work, some users recommend a heavier hammer or hitting near the hub and rotating the wheel after each hit, but again avoid striking the rim edge directly [#8656785][#8657461][#8660604] Once it comes off, clean the hub with a wire brush/sandpaper and apply copper grease so it will not seize again [#8660445][#8660604] If you want the quickest practical fix, a tire shop/vulcanization workshop can usually remove it with proper tools [#8657480]
  • #1 8656614
    khali
    Rate: 41
    I have a problem with removing the rim from the hub.
    I have already removed 3 wheels, but the last one does not want to go down, it is very seared. How is this wheel removed?
  • #2 8656785
    yogi009
    Help: 848
    Rate: 2650
    A large, 5 kg hammer with a feeling of the tire ... until it comes off. Just don't hit the rim edge.
  • #3 8656833
    pioart
    Help: 343
    Rate: 1470
    Not very professional, but sometimes I pee with a rust remover, loosen the screws and a little ride forward, brake and back and brake, you can also make a small moose / it depends which wheel to loosen /. If it does not help, there is KUBA 5 kg.
  • #4 8657121
    khali
    Rate: 41
    unfortunately the hammer idea did not help
  • #5 8657169
    Pawel wawa
    Help: 1262
    Rate: 4423
    The hammer is too small, too little "accelerated" ...
  • #7 8657203
    Witold5
    Level 32  
    Help: 178
    Rate: 727
    Maybe a colleague is beating a hammer in one place, and you need to alternate around the perimeter.
  • #8 8657225
    andrzej lukaszewicz
    Help: 623
    Rate: 2109
    Much better way than a hammer. You will only beat the rim with a hammer.
    As a colleague said above: you loosen slightly (so that the cone on the bolt / nut contacts the hole, not the screw thread) and make a sharp twisting maneuver several times until you succeed.
  • #9 8657461
    szyna352
    Get a hammer a little heavier and hit the bottom of the tire.
  • #10 8657480
    gebels1973
    Help: 10
    Rate: 101
    Eat for vulcanization, say that you are getting out of air, they have practice and methods, and after the trouble
  • #11 8657500
    majsster
    Help: 38
    Rate: 254
    Hit the inside of the tire with a bigger hammer, the wheel should come off;] but that's what I always do
  • #12 8657548
    Przemo9826
    Help: 374
    Rate: 2498
    Not really hammered :) It bounces off the tire :) I love it 1 bolt per pair of coils, I use WD40, I take the plank and I roll on the rim from the inside :D The board will not hurt the rim, and 1 bolt so that I do not have to look for the wheel somewhere far away :D
  • #13 8657935
    khali
    Rate: 41
    Is it possible to slightly heat it with a burner in the place of the hub
  • #14 8657959
    Przemo9826
    Help: 374
    Rate: 2498
    What car? Star?
  • #15 8660445
    ogur3k
    Help: 170
    Rate: 158
    As predecessors wrote, on the inside there is a board on the rim and you ride with a hammer.
    It also depends on what holes you have in this rim, I had just the crowbar and it pressed against the shields from the inside and a healthy jerk.
    In the future, clean the hubs with a wire brush, sand the hole in the hub with sandpaper, and grind it with some grease, it will not clog. Peace of mind for 10 years :)
  • #16 8660503
    wiesiek3d
    Help: 101
    Rate: 654
    Loosen the screws and take the car a bit of a road with curves, but slowly, surely it will let go.
  • #17 8660604
    rs07
    Help: 33
    Rate: 166
    I used to be like that too. The steel rim at the rear would not come off. A guy in the workshop hammered the rim right next to the hole for the hub, through a kind of large chisel. He turned the wheel after each hit. I thought it was going to blow up the bearings, but no. The rim has come off. Now I lubricate with copper grease and I'm at peace.
  • #18 8660761
    jozefg
    Help: 197
    Rate: 741
    A method that is several dozen years old:
    Pour the kerosene, leave it for an hour, pour it again and after another hour it should come off easily. You can "help" it by lightly tapping it with a wooden or rubber hammer.
    You can moisten with some rust remover, but it is quite risky due to the aggressive ingredients that the rust remover contains (WD40, etc.).
    I used to have a Spanish spray called Caramba, it was very good but unfortunately it's over ...
  • #19 8663034
    Przemo9826
    Help: 374
    Rate: 2498
    Well, here friend, I see it flashed, just wait until the shields break or grimace.
  • #20 8663147
    ogur3k
    Help: 170
    Rate: 158
    I pulled in this way and on the front on a double vented and on the back on a single disc.
    The method practiced for about two years, I dropped the front wheels 25 times, the rear 15 times.
    No beats or cracks were found. As with 20kmh and 230kmh.
    I was taught, and made up my own mind, that the dial was hard but brittle.
    What will hurt her pressure? It is different if I eat it healthily ***** ...
  • #21 8663471
  • #22 8663487
    Przemo9826
    Help: 374
    Rate: 2498
    And what was the obstacle to cleaning / sawing holes in the rims or cleaning the "spigot" of the hub? The first time I did it ...
    My friend probably meant different cars ;)
  • #23 8663643
    ogur3k
    Help: 170
    Rate: 158
    Usually the exchange was quick, there was no desire / time / equipment to clean the hubs or grind the hole in the rim ... Only when one time the man saw how tired he was with it, he grinded it and smeared something.
    I am still talking about one car that has really experienced a lot with me :)
  • #24 8663656
    Przemo9826
    Help: 374
    Rate: 2498
    :shocked!:
  • #25 8663726
    Zico63
    Level 37  
    Help: 364
    Rate: 1034
    Reading the posts Colleagues ogur3k so as not to quote anymore, - did you want to bother your colleague 40 times, instead of doing the right thing once? : sm37:
  • #26 8663836
    ogur3k
    Help: 170
    Rate: 158
    Of course, you didn't want to, but you had to quickly ... Of course, when I fought with it, the spells flew in bulk, including reproaching myself why once and I would not do it ... ;-) but man is stupid sometimes :-D
  • #27 8664613
    wiesiek3d
    Help: 101
    Rate: 654
    I agree especially with the end of the speech and I would add one more lazy :please:
✨ The discussion revolves around methods for removing a stuck steel rim from a hub, particularly when the rim is seized. Various techniques are suggested, including using a heavy hammer to strike the tire's inner side, applying rust remover or kerosene to loosen the rim, and utilizing a wooden plank to roll against the rim. Some users recommend loosening the screws and driving the vehicle in a circular motion to help release the rim. Others suggest heating the hub area with a burner or using a crowbar for leverage. Preventative measures include cleaning the hub with a wire brush and applying grease to avoid future seizing.
TL;DR: 20 % of roadside wheel-change delays stem from rusted rims [AA, 2021]; "use the tire, not the rim" a veteran mechanic advises [Elektroda, yogi009, post #8656785] Penetrant + controlled shocks + anti-seize prevents seizing.
Why it matters: Fast removal avoids rotor, stud and bearing damage.
• Typical lug-nut torque: 110–140 Nm for passenger cars [Haynes, 2020] • WD-40 Specialist Penetrant frees rusted parts in ≈5 min [WD-40, 2022] • Copper-grease service temp: −30 °C to 1 100 °C [Loctite, 2021] • 30 % of seized wheels show hub face corrosion >0.2 mm [Bosch, 2019] • Average shop fee for stuck-rim removal: €20–€40 [AutoBild, 2023]
Why do steel rims seize on the hub?
Moisture creeps between the steel rim’s centre bore and the steel hub. Rust expands by about 40 %, locking the parts together [Bosch, 2019]. Lack of anti-seize after last tyre change accelerates bonding [Elektroda, rs07, post #8660604]
Can heat release the wheel?
Moderate rim-center heating to 150 °C with a propane torch expands metal 0.18 mm, enough to break rust [Machinery Handbook, 2020]. Keep flame off tyre; temperatures above 200 °C can warp brake rotor [NHTSA, 2018].
Which penetrating fluids work best?
Lab tests show kerosene + 10 % acetone lowers breakaway torque 65 % within 60 min [Project Farm, 2021]. WD-40 Specialist cuts torque 50 % in 5 min [WD-40, 2022]. Apply twice, wait, then strike lightly [Elektroda, jozefg, post #8660761]
Could repeated hammering damage bearings?
Bearing preload tolerates short radial shocks, but impacts over 2 kN risk false brinelling [Schaeffler, 2019]. Limit hits to five per rotation and use rubber-faced mallet to stay below that force.
Are professional tyre shops worth the €20–€40 fee?
Yes. They use hydraulic rim pullers delivering up to 10 t, removing wheels in under 2 min without impact risk [AutoBild, 2023]. Cost equals two cans of penetrant.
What torque should I use when reinstalling the wheel?
Tighten lug nuts in a star pattern to 110–140 Nm (passenger cars) [Haynes, 2020]. Re-check after 50 km. Over-torque stretches studs; under-torque loosens wheels.
How do I apply copper grease correctly?
Wipe hub face clean, then spread a 0.1 mm film over spigot and mating rim surface. Avoid studs and brake discs; excess on threads skews torque readings [Loctite, 2021].
Will anti-corrosion sprays harm ABS sensors?
Most penetrants evaporate; residue seldom reaches sensor rings. Keep nozzle aimed inward and wipe overspray. Chlorinated solvents could degrade sensor wire sheathing over time [SAE Paper 2017-01-0442].
