Best Free Stencil Fonts for Printable Spray Paint Templates and Inscription Cutouts
fenders 49735 6
  • #1 8667471
    fenders
    Help: 8
    Rate: 40
    I`m looking for it and I can`t find much... Fonts for a template... I want to print an inscription on paper, cut it out, apply it and spray paint it.
    I`m looking for some simple font.
    Thank you in advance for your help !
    Regards
  • #2 8668194
    Muc13k
    Rate: 11
    Simple font? Arial, which is installed with Windows, will probably be the best fit. I don`t know what you want honestly. Which you want? Even simpler?
  • #3 8668406
    fenders
    Help: 8
    Rate: 40
    I need a font something like this:
    I mean letters with connections in: P,B,D,O,A,Q,R
  • #4 8668485
    Muc13k
    Rate: 11
    There is no point in helping here. You have to choose what works for you.
    Go to the website: http://webpc.pl/czcionki/ and choose what you need and download it.
  • #5 9294123
    Glowz
    Help: 7
    This art is called STENCIL , is the same name of the font and it is best to do it on cardboard by cutting out the letters with a wallpaper cutter or another knife. By default, this font should be on your system.
    Stencil fonts
  • #6 9302393
    ziqba
    Link a real mine of fonts, you will definitely find other interesting ones that will be suitable. Moreover, you can modify a simple font yourself by adding a "hyphen", e.g. with an "eye" in O.
  • #7 9302446
    Glowz
    Help: 7
    But why redo it when above I gave a link to a mine of fonts adapted for this purpose? :)
The discussion revolves around finding a suitable font for creating a stencil template for spray painting. The user initially seeks a simple font and later specifies a preference for letters with connections, particularly in the letters P, B, D, O, A, Q, and R. Responses suggest using the Arial font, which is commonly available on Windows systems, and recommend visiting a font website for more options. A specific mention of "Stencil" as a type of font is made, which is ideal for cutting out letters from cardboard. Additional suggestions include modifying existing fonts to meet the user's needs.
