Canon LBP 5000 Printer Error E002 0000: Seeking Manual & Solutions - HP 2600 Equivalent
Deiwid 3170 4
  • #1 8695510
    Deiwid
    Help: 20
    Rate: 11
    Has someone manual for this printer? Equivalent to HP 2600
    I am looking for information on error E002 0000
  • #2 8697305
    leeart
    Help: 269
    Rate: 433
    Your error is related to the persistence team. Check the thermistor, foils on the heater,
    LEE-CAN SERWIS
    PLAC CZERWCA 1976R NR 2 LOK 06, Warszawa, 02-495 | Tel.: 502XXXXXX (Show) | Company Website: serwisdrukarki.pl
  • #3 8697414
    rys57
    Moderator
    Help: 212
    Rate: 436
    The heater, too.
  • #4 8697471
    leeart
    Help: 269
    Rate: 433
    I did not finish my speech, so while continuing I also check the heater itself as well as the fusing connection with the NTSC board, and the thermistor. As it turned out that everything works, you have a damaged NTSC disc. In fact, it's about the wrong temperature for fixing during work.
    LEE-CAN SERWIS
  • #5 8697512
    Deiwid
    Help: 20
    Rate: 11
    The problem turned out to be trivial. Damaged heater wire caused a short circuit and fused the fuse.
    Everything has been repaired.
    Unfortunately, there is a calibration error every now and then, but that's another matter.
    Best wishes and thanks for your help
