Canon MP250, MP270 Error 5200 (P08) After Low Ink – What Causes This?
justyna710 113787 14
  • I had little ink recently, and when I want to print, I get an error 5200 and the display P08. What's up?
    justyna710
    justyna710 wrote 1 posts with rating 23. Been with us since 2010 year.
  • #2 8389140
    latkop
    Rate: 15
    Hello !
    As in the topic, when I try to print, I get a service error 5200, i.e. the filling of the so-called "pampers", ie the container for leftovers or dripping ink.
    I have already tried all printer resets given on various forums and websites, but nothing works ...
    Maybe someone has already had such a problem and knows how to solve it?
    If not, I will have to call the service and ask how much such cleaning will cost and where such services are located ...
    I will emphasize immediately that I have not found any questions about my printer model anywhere on the net, so I would like to ask you not to answer, for example, Google does not bite, because I spent 3 hours before I wrote this post ... I have no strength for this; /
    Regards
    and waiting for help :(
  • #3 8514991
    Bigger81
    Rate: 11
    Hello!
    I have a canon pixma MP250 printer. Error 5200 popped up while cleaning the print head, while the printer display showed error P 0 8. The failure was resolved after the carcass was refilled and the nozzles were wiped with a decongestant. As for the error codes, I recommend the on-screen manual. Advanced Guide> Troubleshooting> An Error Code is displayed on the LED screen. p 602.
  • #4 8782235
    saakashvili
    Rate: 36
    It is true that after time, but it is possible that someone will be looking for a solution to error P08, i.e. resetting the counter after the pampers is full. I tried and looked for a solution for a long time, finally I came across a way to reset the cartridge ... and it helped
    So: after cleaning the pampers:
    1. Disconnect the USB cable
    2. Turn off the device using the power button.
    3. Press and hold the "Stop / Reset" button (a triangle in a circle), and at the same time press and hold the power button.
    4. While holding down the power button, release "Stop / Reset", then click it 2 times in a row (briefly)
    5. While still holding the button. wait about 20-30 sec. until the display shows "0".
    6. Release the button. and then press "Stop / Reset" 4 times in succession (briefly)
    7. Turn the device off and on. *
    viola!
    * - if it does not help, click the power button 5 times (briefly)
  • #5 8947346
    Jaa123321
    Rate: 8
    saakashvili
    It worked for me :) it didn't even have to be cleaned. Thank you very much!
  • #6 9001295
    saakashvili
    Rate: 36
    Jaa123321 wrote:
    saakashvili
    It worked for me :) it didn't even need to be cleaned. Thank you very much!
    of course, it will work without cleaning, but you still need to clean the pampers anyway, because the ink may mess inside
    PS. Does anyone know how to effectively clean the diaper, or where can you get a new one?
  • #7 9002672
    endriuf
    Printers specialist
    Help: 620
    Rate: 1530
    It can be rinsed out under hot water. Ask about a new one at an authorized service point, eg Fis-Komp. But it is hardly available. Recently I asked for IP2000 and it is not.
  • #8 9286998
    pitbaw
    Help: 45
    Rate: 46
    saakashvili wrote:
    solutions regarding error P08 (error 5200 in the computer), i.e. resetting the counter after filling the "pampers".
    On Canon Pixma MP270 - also works
  • #9 9287032
    rys57
    Moderator
    Help: 212
    Rate: 436
    Action confirmed, transfer the topic to the "Diagnosis" section.
  • #10 9288254
  • #11 9689066
    tymoth
    Rate: 17
    How to empty / clean the waste ink container, the so-called "papmers"?
  • #14 9927424
    ector
    Rate: 11
    MP495
    - hold "triangle in circle", press POWER and keep it pressed.
    - holding power, release "reset"
    - press reset 4 times, release everything, the digit "0" will flash on the display
    - press "reset" 4 times
    - turn off the device
    - turn on the device and the blank sheet will pass through the rollers for checking.
    - the device is operational and ready for use.
    ps. I figured it out myself; Mr.
  • #15 9993502
    sklepdekarza.pl
    Erase works, thank you
    sklepdekarza.pl
The discussion revolves around the Canon MP250 and MP270 printers encountering error 5200 and display P08, typically indicating issues with the waste ink container ("pampers"). Users report various troubleshooting methods, including resetting the printer and cleaning the waste ink container. A specific reset procedure is shared, which involves a sequence of button presses to clear the error. Some users mention that the error may also relate to overheating of the nozzles rather than a full waste ink container. Cleaning methods for the waste ink container are discussed, including rinsing it under hot water and seeking replacements from authorized service points.
