Canon G3400 Printer: Troubleshooting Error 5B00, Blinking Failure Lamp & Possible Pampers Solution
gosia88_lublin 15279 5
  • #1 17273772
    gosia88_lublin
    I have a canon G3400 printer. I got error 5B00. And the failure lamp with the switch blinks alternately. The technician over tele said it was probably pampers.
    Will you help? :)
    Moderated By dt1:
    We help their Author in other people's threads, we do not add our own problems. I have separated the post into a separate thread.
  • #2 17275385
    leeart
    Help: 269
    Rate: 434
    Yes it is pampers. Must be replaced and deleted.
    LEE-CAN SERWIS
    PLAC CZERWCA 1976R NR 2 LOK 06, Warszawa, 02-495 | Tel.: 502XXXXXX (Show) | Company Website: serwisdrukarki.pl
  • #3 18075827
    Marro_358
    I have a similar problem. And the question. Can you provide any more detailed information on how to do this?
  • #4 18076723
    leeart
    Help: 269
    Rate: 434
    A program is required for erasing. To use the program, the printer must be started in the service mode.
    LEE-CAN SERWIS
  • #5 18083873
    endriuf
    Printers specialist
    Help: 621
    Rate: 1532
    You can do this using this program. You can buy the cancellation code on a popular auction site for about PLN 30. As for replacing the pampers, it is a rough job and when it is the first reset, you can not replace it.
  • #6 18088222
    Marro_358
    Because the color head was clogged and I was cleaning the system (which causes a lot of ink consumption and dumps it into the pampers), I decided to have the printer replaced and the errors reset. I bought and replaced the color head with a new one. Now everything works fine and I hope that the equipment will serve for a while. Thanks for the help.
    Maybe someone will need videos with instructions on how to replace the head in a printer of this type.
    https://www.youtube.com/watch?v=zaJpwZAvwsM
    https://www.youtube.com/watch?v=w183NPUI-YA
