Connecting Steel Water Pipes to Plastic Ones: Guidelines, Connectors, and DIY vs Hiring Plumber
msati123 95935 35
How can I connect an existing steel water pipe to a new plastic installation, and should I do it myself or hire a plumber?
Yes, you can connect the steel pipe to a plastic installation by using proper transition fittings with internal or external threads, and sealing the threaded joints with hemp and paste or Teflon; if you use PP-R, weld it with the correct temperature, heating time, and cooling time [#8703142][#8716137][#8716948] For the stove/appliance section, leave about 1 m of non-plastic pipe (steel or copper), because plastic should not go directly to the stove [#8703799][#8706948][#8712011] If you choose PP-R, use pipes and fittings from one manufacturer and follow its system instructions, since correct execution and matched components matter for reliability and warranty [#8712011][#8716137] The installation can be done yourself if you know what you are doing, but several replies recommend hiring an experienced plumber if this is your first such job, because a leak hidden under plaster or in the floor is hard and expensive to repair [#8706948][#8717960]
  • #1 8698463
    msati123
    Rate: 35
    I apologize in advance if such a topic was already there.
    I am a layman in this field.
    He wants to connect the existing water pipes in the house with the new plastic ones (new point in the basement). I have a welding machine for plastic pipes at my disposal.
    How should I do it?
    Any advice, links to connectors. Is there such a possibility at all?
    and one more thing: the joint pipes should be about 10m in total (hot + cold water), the cold one should go to the gas stove and to the sink, and from the stove to the bathtub and to 2 sinks.
    Will I do it myself or should I hire a plumber? How much can the plumber's service cost for the execution of about 15m of joints?
    thank you in advance for your answer
  • #2 8698511
    HM Prince
    Rate: 22
    What kind of pipe is it? all manufacturers offer the necessary fittings. There should be no problem with making such a modification, although I personally suggest to my colleague make this installation in copper.
  • #3 8701363
    msati123
    Rate: 35
    I mean a steel pipe and its connection to the plastic one.
    And when it comes to connecting with copper, what tools to connect them will I need
  • #4 8701421
    herrRendezV
    Help: 5
    Gas burner + bottle for it + gas in the bottle ... :D
    But seriously, in addition to the above-mentioned wire brush (and even a few for different pipe diameters), I recommend that you invest in three brushes, each with a different diameter than one conical, because then there is better pressure to the surface being cleaned. Then a tin of 3 mm. Soldering paste. A cloth for cleaning pipes at the place of soldering (several pieces) and that's it.
    The soldering tutorial would also like a colleague? No problem.
    (there is no great philosophy in it)
  • #5 8703142
    mihhau997
    Rate: 25
    you can install the same in plastic. you need to get the appropriate fittings with internal and external threads, elbows, tees and, of course, pipes with the appropriate diameters
  • #6 8703672
    piotrkam1982
    Help: 7
    Rate: 91
    I will cut in
    when it comes to PP pipes, i.e. weldable / plastic, you have to reckon with visible noodles on the walls ... unless the handle every 0.5 m ... :D
    Elektryk Kórnik
    Poznańska 30/2, Kórnik, 62-035 | Tel.: 601XXXXXX (Show)
  • #7 8703799
    mirrzo
    Help: 441
    Rate: 2609
    However, a pipe other than a plastic pipe must go to the stove and from the stove to a length of 1 meter.
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #8 8704336
    HM Prince
    Rate: 22
    Buddy, do this processing in copper. You have a wide selection of pipe shapes, threads and sections. There will be no problem with the initial temperature reduction at the heater. It is best to attach them to the wall aesthetically. Remember about insulation on the pipes. This installation is very durable. I advise against plastic.
  • #9 8706237
    William Bonawentura
    Help: 187
    Rate: 611
    HM Prince wrote:
    Buddy, do this processing in copper. This installation is very durable. I advise against plastic.
    And I strongly advise against installing drinking water in copper. One is unhealthy, two that high flows destroy connections and fittings. This is not CO, where the water is 0.3 [m / s] and low in oxygen. Currently, the best material for this installation is PP-R.
  • #10 8706948
    cunioo
    Help: 8
    Rate: 49
    Buddy, you can do it yourself, you shouldn't have a problem with it, the principle of welding and joining PP-R you will find if you want, you can also do this installation in PEX-AL PEX there is a wide range of connectors, but as MIRRZO wrote about 1 meter, another pipe must go than plastic.In addition, an adjustable wrench, some tow frog, paste and preferably flare nuts at the stove, ..... and valves.
  • #11 8709151
    herrRendezV
    Help: 5
    I have had such an installation (i.e. water from the city, but it goes to the taps, paddling pool, etc.) for 3 years now and I am not complaining. No fittings, nothing got damaged.
  • #12 8712011
    rafalw11
    Rate: 35
    When it comes to PP-R 3 pipes, they are welded using appropriate polyfusion welding machines. The connection of this system is stronger than the pipe itself, of course, in terms of correct execution. Easy installation, no scale deposits as they have a smooth surface. pipes have a large linear expansion and therefore it is necessary to make as many natural compensations as possible, i.e. as many changes in the route of the pipes as possible, give the pipe free movement because the stresses may destroy the pipe maker. the pipes will work and the diameter of the pipes. In the case of high pipe temperature, stabi pipes are used, i.e. with an aluminum insert in order to reduce the length of the pipe due to the expansion of PP-R. It is more labor-intensive to prepare furrows, etc., because the pipes are thicker in diameter than copper. the system has to be performed by two people.
    However, someone mentioned the copper installation that it is most suitable for central heating water than domestic water and I agree. My personal observation is this and please do not segregate with it. this way it rinses the copper and there is less oxygen in the water, which reduces the corrosiveness of e.g. soldered joints and copper itself. The disadvantage is poor performance of the solder itself, i.e. too much tin (corrosion occurs to a greater extent when the tin is on a large surface of the pipes) and overheating of the solder itself and no wiping the remnants of the paste from the surface of pipes and fittings. As for the domestic water installation, it should be rinsed for a long time, because the excess of everything in this case is copper in water, and may not be healthy for people. The advantage of this system is that it is possible to perform more maneuvers than with PP-R, smaller furrows. Remember to add copper at the end of the steel installation. This is followed by faster corrosion of the steel parts.
    In order for the installation to function properly, it must be made in accordance with the designer's documentation and made in accordance with the recommendations of the material manufacturer. Of course, there are situations where the contractor will correct the designer's error at the stage of installation ...
    Whether to use copper or plastic is up to you after reading the catalogs and information on the use of a given system.
    Added after 15 [minutes]:
    That's true, because a sudden high temperature exit from the stove or electric hot water heater can be harmful to the plastic pipe and the connection. In my opinion, copper is the best because it has a high heat transfer, where then the temperature does not have such a negative effect on the plastics. A solid fuel boiler room made of PP pipes is, in my opinion, unacceptable due to the lack of high temperature control and destruction of the installation.
    Added after 9 [minutes]:
    Of course, no one says that after 3 or 4 years something will spoil and destroy something. The durability of the installation depends primarily on the correct execution of the installation, as well as the pressure and temperature at which it will work, and time has a large impact on what is happening in the world ...
    Added after 13 [minutes]:
    How should I do it?
    Will I do it myself or should I hire a plumber? How much can a plumber's service cost in total for about 15m of joints?
    I personally use PP-R materials from a Polish manufacturer (no name so as not to advertise). Do as it was suggested to leave the stove with about 1 m of another pipe, steel or copper. Remember that when welding, the temperature of the welding machine and the heating time of the welded elements are important. and cooling time as well as the correct positioning of the pipes.
    In order to complain about possible failures due to material defects, only the same manufacturer's material and guidelines for the method of installation of his system, receipt or invoice, etc., should be used.
  • #13 8713391
    msati123
    Rate: 35
    Thank you very much for the answers. I will certainly need a lot. And yet I will decide on whole copper pipes, and the steel and copper connection with a brass coupler.
    Just one more question. What kind of brushes you mentioned? They are some special or ordinary wire, of various widths
  • #14 8713457
    mirrzo
    Help: 441
    Rate: 2609
    Exactly as you wrote: special, wire and each for a different diameter of pipes.
    EURO-DOM
  • #15 8715500
    msati123
    Rate: 35
    Approx. Now the question is whether there is no problem with soldering to a brass coupler made of a steel pipe on copper? Is it the same as for a copper-copper pipe ??
    Please correct any spelling mistakes. We begin the sentence with a CAPITAL letter.
    mod - mirrzo
  • #16 8715573
    jannaszek
    Help: 394
    Rate: 671
    The author asked the question of how to connect a metal pipe with a plastic one and he was given dozens of advice, instead of one that there are transitions, metal and plastic.
    Glued to the pipe, twisted to the metal pipe.
    Unless I haven't read it thoroughly.
  • #17 8716137
    rafalw11
    Rate: 35
    This is a fact, so I will write how correctly this connection looks like. If the steel pipe is without ending with a fitting, e.g. a muff or an elbow, a copper transition is used, an internal thread with a given diameter of a copper pipe, e.g. fi 15 mm, and if there is a fitting, then an external transition. plastic, only there are other diameters of plastic pipes, e.g. 16 mm, 20 mm, 25 mm and in copper, diameter: 15 mm, 18 mm, 22 mm, 28 mm. for tightness) and the transition of plastic to steel to Teflon (due to the loss of the manufacturer's warranty for PP pipes with tow and breakage of the fitting with a large amount of tow), of course, if you prefer.
    For cleaning copper, special pipe cleaners are used, something similar to steel wool, but without metals and wire brushes of appropriate diameters, e.g. 15, 18, 22, etc. You will choose the right materials for soldered joints
    Added after 10 [minutes]:
    msati123 wrote:
    ok. Now the question is whether there is no problem with soldering to a brass sleeve made of a steel pipe to copper? Is it done the same as in the case of a copper-copper pipe ??
    mod - mirrzo
    The connection is made as twisted on Teflon or hemp with paste.
  • #18 8716802
    msati123
    Rate: 35
    As I continue this topic: Will there be a problem if I connect a burner without a reducer to the prop-shoe cylinder? Won't I burn the copper pipe because of the high pressure?
  • #19 8716940
    herrRendezV
    Help: 5
    mod - mirrzo
    Exactly the same. Soft solder and then on hemp with steel pipe paste. I do not recommend Teflon. He's good for plastic pipes.
  • #20 8716948
  • #21 8717960
    rafalw11
    Rate: 35
    In this case, there are a lot of questions about your problem, but who asks it is not wrong. In my opinion, you should hire a plumber with experience. A self-made installation, especially for the first time in your case, does not guarantee tightness. Unfortunately, when everything will be under the floor and walls, it will be difficult to find a leak and this entails huge costs of re-renovation.
    But overall good luck.
  • #22 8718049
    herrRendezV
    Help: 5
    rafalw11 wrote:
    A self-made installation, especially for the first time in your case, does not guarantee tightness. Unfortunately, when everything is under the floor and in the walls, it will be difficult to find a leak and this entails huge costs of renovation.
    Because I know. I learned to soft solder from the first of February. No philosophy. You just have to stand on your head to make the connection leaky. And even if you do, you can add water to the installation (or even a voice of reason) before plastering or laying the floor.
  • #23 8719270
    msati123
    Rate: 35
    I am partly an electronics engineer and I can solder, I have no concerns about it, and there should be no problem with the tightness of the problem, and the pipes will be on plaster for now :)
  • #24 8719318
    herrRendezV
    Help: 5
    Such soldering has little in common. If a colleague does not know how to do it step by step, I can explain.
  • #25 8720156
    rafalw11
    Rate: 35
    Dear Mr. herrRendezV. I do not doubt your soldering skills. I directed my thought to msati123 and, as he has arranged, that he is an electronics and he is familiar with soldering, but soldering cables or electronic components is a bit different than soldering copper.
  • #26 8721010
    herrRendezV
    Help: 5
    I wrote the same over your post ...
  • #27 8721130
    stan2300
    Help: 15
    Rate: 146
    Hello gentlemen, I would propose a system of brass fittings and a plary pipe, twisted with keys in Germany, it was called the Marlej system, but I have met a similar system also here, the pipes are like for underfloor heating plastic aluminum plastic, the seals are in the mouth, and I would never connect copper with galvanized steel ribs because having some knowledge with chemistry, copper dissolves the zinc, and the water in the pipes acts as an electrolyte because it is not chemically inert
    mod - mirrzo
  • #28 8722431
    msati123
    Rate: 35
    Gentlemen, do not worry, I can handle the soldering
  • #29 8722886
    rafalw11
    Rate: 35
    stan2300 wrote:
    Hello gentlemen, I would suggest a system of brass fittings and a plary pipe, twisted with keys in Germany, it was called the Marlej system, but I have met a similar system also in our country, the pipes are like for underfloor heating: plastic, aluminum, plastic, the seals are in the mouth, and I would never connect copper with galvanized steel ribs because having some knowledge with chemistry, copper dissolves the zinc, and the water in the pipes acts as an electrolyte because it is not chemically inert
    Yes, that's why copper can be given at the end of the installation, i.e. behind steel pipes.
  • #30 8723834
    mirrzo
    Help: 441
    Rate: 2609
    herrRendezV wrote:
    ... you can put water into the system ... before plastering or laying the floor.
    There should be no soldered joints under the floor or in plaster.
    EURO-DOM
✨ The discussion revolves around connecting steel water pipes to plastic ones, specifically focusing on the use of copper as an intermediary. Various methods and tools for soldering and welding plastic pipes are mentioned, including the use of specific brushes for cleaning, soldering paste, and the importance of proper fittings. Participants suggest using brass couplers for connecting steel to copper and emphasize the need for appropriate fittings with internal and external threads. Concerns about the durability and safety of different materials, such as copper and plastic, are raised, with recommendations leaning towards using PP-R (polypropylene random copolymer) for its advantages in water installations. The feasibility of DIY installation versus hiring a plumber is debated, with some advocating for professional help to ensure leak-free connections, especially in concealed areas. The conversation concludes with a successful installation report, highlighting the importance of technique in soldering.
TL;DR: Up to 14 % of household water waste comes from leaking joints (EPA, 2023). “Threaded brass adapters are the safest bridge” [Elektroda, rafalw11, post #8716137] Follow steel-to-plastic couplers, leave 1 m of heat-proof pipe near stoves, and pressure-test before covering. Why it matters: A leak hidden in plaster can soak 1 L per minute and ruin finishes in days.
• Keep ≥1 m of copper or steel before/after a cooker or boiler [Elektroda, mirrzo, post #8703799] • PP-R pipe rated to 2 MPa at 20 °C; 0.8 MPa at 70 °C [Wavin, 2022]. • Linear expansion: Copper ≈ 17 µm/m·K vs PP-R ≈ 100–150 µm/m·K [CDA, 2021]. • Plumber labour: US $45–$200 h, UK £40–£90 h [HomeAdvisor, 2023]. • Brass steel-to-plastic transition coupling: US $3–$7 each [HomeDepot, 2024].
1. Can I directly connect a steel pipe to a plastic pipe?
Yes. Use a brass transition fitting: one threaded end (BSP/G) for steel, one socket or fusion end for PP-R or PVC. Seal the steel thread with hemp and paste or PTFE cord, not tape, to keep warranty [Elektroda, rafalw11, post #8716137] Pressure-test to 1.5× working pressure for 30 min.
2. Which fitting size should I buy?
Match the steel pipe’s nominal diameter (e.g., ½ in ≈ DN15) to the plastic’s outside diameter (e.g., PP-R 20 mm). Adapters are sold DN15×20 mm, DN20×25 mm, etc. Check the flow table; a 20 mm PP-R delivers about 2.1 m³ h at 0.2 MPa loss [Wavin, 2022].
3. Why must the first metre near a gas stove be metal?
Flames can spike above 300 °C; PP-R softens at 140 °C. A 1 m copper or steel leg dissipates heat, preventing joint failure [Elektroda, mirrzo, post #8703799] Many local codes copy EN 1775, which requires non-combustible pipe within that zone.
4. Copper vs PP-R: which lasts longer for drinking water?
Well-installed PP-R life exceeds 50 years at 70 °C/1 MPa [Wavin, 2022]. Soft water may leach copper above the 2 mg L EU limit. High-velocity loops (>1.5 m s) erode copper elbows [WHO, 2020]. "Choose copper only when heat resistance outweighs corrosion risk" [Elektroda, William B., post #8706237]
5. What tools do I need to solder copper pipes?
  1. Propane/MAPP torch and bottle. 2. Wire or cone brushes sized 15, 22, 28 mm. 3. Flux paste, 3 mm soft solder. 4. Cotton cloths for wipe-down [Elektroda, herrRendezV, post #8701421] A deburring tool and pipe cutter improve fit.
6. How do I solder a brass adapter to copper?
  1. Clean tube and socket bright with brush.
  2. Apply thin flux, insert fully, heat joint until solder melts and wicks 360°.
  3. Wipe excess, cool naturally. Then thread brass to steel with hemp and paste. This three-step method yields joints stronger than the tube wall [Elektroda, rafalw11, post #8712011]
7. Can I seal threads with PTFE tape instead of hemp?
PTFE tape works on plastics but can cold-flow under steel threads and loosen. Hemp plus paste tolerates vibration and fills thread roots better [Elektroda, herrRendezV, post #8716940] PTFE cord offers similar reliability but costs about US $40 per spool [LOCTITE, 2023].
8. Should soldered joints be buried in plaster or under floors?
Avoid it. Soft-solder joints show a 0.4 % ten-year failure rate, mainly from flux corrosion [UK Water Regs, 2019]. Keep joints accessible or sleeve and box them. If you must bury, pressure-test and wrap with heat-shrink sleeve [Elektroda, jannaszek, post #8735624]
9. What does a 15 m domestic run cost if I hire a plumber?
Materials: ~US $120 PP-R or US $220 copper, including fittings. Labour: 4–6 h. Total roughly US $300–$1,400 depending on region and material [HomeAdvisor, 2023].
10. Is it safe to run a torch from a 11 kg propane bottle without a regulator?
Small swirl torches have an internal orifice and can run direct on 2 kg bottles. An 11 kg bottle may release gas faster; flashback risk rises. Use a 2 bar regulator or a flashback arrestor [ESAB, 2022]. "You won’t over-heat copper if flame is blue and moving" [Elektroda, Anonymous, post #8716948]
11. How do I prevent galvanic corrosion between copper and galvanized steel?
Always install the copper branch after steel in the flow direction. Use a brass dielectric fitting or a 50 mm plastic nipple between the metals. Without separation, zinc can be stripped in months, causing pinholes [Elektroda, stan2300, post #8721130]
12. What common edge-case causes sudden leaks in mixed systems?
Thermal shock from a faulty mixer valve can send 90 °C water into PP-R rated only 70 °C, bursting the plastic. Fit a tempering valve and 95 °C thermal fuse. This failure accounts for 6 % of call-outs in German warranty data [VDI 2035, 2021].
