Replacement of water pipes in the bathroom. Which system to choose?
Ssaab 29724 48
Which pipe system should I choose for a DIY bathroom water installation: PP or PEX?
For a DIY bathroom water installation, choose welded PP if you want the cheapest and simplest system, but choose crimped PEX if the pipes will be hidden in walls or plaster and you want a thinner layout. [#17672180] [#17676493] PP is cheap and easy to buy, and the welder can be rented for little money, but it takes practice and careful planning because the fittings are bulky and welded joints should not be left in inaccessible places. [#17672180] [#17676493] PEX does not need expensive tools, but for PEX-AL-PEX you should calibrate/deburr the pipe first so you do not damage the O-rings; a good crimped PEX installation is well suited to concealed runs. [#17668254] [#17668214] [#17676493] Buy pipes and fittings from a plumbing wholesaler rather than a supermarket; posters warned that supermarket goods can be weak or generic, and recommended proven brands such as Kisan for PEX and Vesbo for PP, with Tece Flex also praised as a premium system. [#17672755] [#17682372] [#17670006] [#17676493] Whatever system you choose, pressure-test the installation for several hours before closing the walls. [#17673081] [#17673241]
  • #1 17668188
    Ssaab
    Help: 16
    Rate: 54
    Hello. I am getting ready to renovate the bathroom in a block of concrete. I have to run the entire new water installation from the meter to the washing machine, cabin, washbasin and suspended toilet. I wonder what kind of installation to use. I hesitate between Pex and PP. Maybe some of you have experience with these pipes and their way of connecting and would like to share. I am asking for advice and guidance on specific companies that you recommend. Should the possible purchase of pipes and fittings in DIY stores be taken into account or should be sought in stores that typically sell these elements ..
    karolark
    Help: 702
    Rate: 2517
    You will do it yourself and what tools do you have - because if there are no tools, you have to add their cost.
  • #3 17668206
    Ssaab
    Help: 16
    Rate: 54
    I have no tools. There is a rental with us .. or if I decided to use PP, I could buy a welding machine .. cost from 100-170 PLN ..
    karolark
    Help: 702
    Rate: 2517
    PP fittings are cheaper, so they are economically better and simpler to implement
    But I don't like them :D
    12pawel
    Help: 207
    Rate: 697
    Twisted Pex does not require expensive tools. I did both, I believe that PP connections are more reliable than Pex, but they also have disadvantages such that in my opinion they are less resistant to mechanical damage. Pex gives up more under some stress.
    And for PP welding, you need to have some experience to warm up well, not overheat, and it was right (the beginnings are difficult, a few joints will pass before you get it.)
    I go more in PEX, I have to pull PP already when I have to
  • #6 17668242
    Ssaab
    Help: 16
    Rate: 54
    I thought about Pex, but twisted. I would get a few threads in the wall, and everywhere to avoid it .. But how is it possible to cover the thread so that the thread does not come into direct contact with the concrete, it shouldn't be a problem?
    12pawel
    Help: 207
    Rate: 697
    The most important thing in Pex is to use such a tool https://toya24.pl/product-pol-10008828-kalibrator-do-rur-PEX-AL-PEX-10x16-12x20-14x26.html
    otherwise you will damage the O-rings and there will be problems.
    With Pex, it is not a problem that it is in contact with concrete or not. There are theories that they can get off the ground, although I haven't seen it myself yet.
    Romulus7874
    Help: 109
    Rate: 458
    No twisted connections in the wall and anywhere with no access.
    It will take revenge sooner or later. I don't like to "leave" somewhere tight, but they will still go away. Make in Welded PP. Practice on a few blocks, take good quality materials. Plan what to do and in what order, because you can enter a dead end, i.e. a place where you cannot, for example, insert a welding machine. Provide the possibility of elongation of the pipes and their "work". (Lagging, foam)
  • #9 17668513
    Ssaab
    Help: 16
    Rate: 54
    I think it will be better with a deburrer ... https://toya24.pl/product-pol-10008870-kalibr...nikiem-do-rur-PEX-AL-PEX-16-20-26mm.html?rec= 101871201
    Added after 18 [minutes]:
    Is it worth buying in Castorama or OBI, or in some plumbing stores?
    Is there a specific company or does it not really matter?
  • #10 17668566
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Disconnecting a well-mounted PEX is impossible, you have to tear off the outer layer with the ring and it must be well over 100 kg because I hung on such a jerk and nothing.
    Secondly, I have compressed air installations on the pex and the pipe 18 calmly withstands 15 bar. and the thinner 16 for sure more.
  • #11 17668667
    Romulus7874
    Help: 109
    Rate: 458
    In ObI, I try not to buy, because contrary to appearances, it is not cheap at all. And in the rest of the supermarkets, cheap but with rice. Pipes and fittings from the same manufacturers only. It's about the PP composition, the same, but who knows ...
    When it comes to hydraulic, you have a wider choice, because there are always two or three producers in the lead and the prices are also adequate. I heard / read somewhere about unscrewing threads (inserts) from elbows or PP couplings but it did not happen to me. Maybe someone has worse experiences.
  • #12 17668715
    Help: 1405
    Rate: 6430
    How to buy company pipes and fittings online.
  • #13 17670006
    Parowy
    Help: 55
    Rate: 227
    Hello my neighbor from the Tri-City :)
    I use and recommend the Tece Flex system.
    Dear but in my opinion one of the best, I use this one, maybe because I have trouble-free access to it with a considerable discount :)
    I also have my own tools.
    Here is a small digression, I do not know about other manufacturers, but the Tece company services the tools for its systems on its own and at its own expense. According to a friend from an installation wholesaler, he does it so that there are no complaints resulting from improper installation, the use of worn out, broken tools.
    I sign it with my arms and legs ;)
    In fact, if you are interested in this system, write Pw, I will try to help
    bodziot
    Help: 37
    Rate: 92
    Find some local peksa company, they have crimping tools, calibrators and other tools for rent.
    robig
    Help: 62
    Rate: 145
    I recommend PP, it is simple for an amateur and cheap. Cheap tubes, cheap fittings. Shopping is best in a local store, they are often cheaper than in a yellow, green or other market, and you do not feel rice with it, as mentioned above by my colleague. The only bigger tool you need is a PP welder, which you can also rent for pennies. Of all these systems, you'll have the least fun, get the hang of quickly and get what you need.
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    I recommend welding pipes. Once I saw how the plumber was doing it and then for a few gold coins I borrowed a welding machine and made the installation for the dishwasher myself. No philosophy. It is very fun to work with this pipe system. When I remember how much they once had to work with metal, it hurts. ;-)
    A plumber advised me to buy "high-end" producers for hot water.
    kudłaty79
    Help: 14
    Rate: 39
    Just like colleagues above PP and so many cheap fittings and a welding machine for a few zlotys, all crimped systems are ok and only expensive couplings and you have to rent a problem with machines :)
  • #19 17672752
    Level 37  
    Help: 211
    Rate: 1014
    Depends on how much work you have. I paid PLN 20 for renting a welding machine per day.
  • #20 17672755
    ^ToM^
    Help: 495
    Rate: 2939
    I made myself out of copper. It is very nice to solder, although you know - copper is expensive. However, as much of this installation is not to be done, copper may be a good choice.
    Can also be made of PEX pipes. However, I warn you against buying pipes and fittings in supermarkets. You need to buy a proven manufacturer. I have two friends of plumbers and they only use Kisan materials, which are produced domestically. They then provide a written guarantee. They argue that you wouldn't dare install supermarket pipes. There have been times when they burst, or begin to leak suddenly in some place.
    I also encountered such a situation. Suddenly, at my father-in-law's bathroom, there was a stain on the wall. We started hammering the tiles to get to the pipes. It turned out that more or less in the middle of one cold water pipe, a hair-like micro-hole was formed - as if someone had forged it with a needle. But from this there was a meter-long trickle of water under pressure! The pipes were unknown to the manufacturer. I suspect it is from China, because we did not find any company markings. We exchanged the whole thing for Kisan. The pipes really look decent and the couplings are also precisely made. If you decide on PEX, buy Kisan or another good and proven company. Kisan is more expensive than market china, but you can be sure that it will last for years.
    However, PEX, despite the fact that it is popular, is precisely from the above-mentioned. because of this system I am afraid.
    And there are PP welding pipes. It is durable and easy to install and quite cheap. However, these pipes are unfortunately quite thick and this sometimes gets in the way of their use. However, well-welded ones have no right to leak and even along the length of the pipe, due to the thickness of the material, it is unlikely to be liquid.
  • #21 17672841
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    Also, I used to be exclusively for copper, but recently I have encountered two cases.
    1. A hole in the pipe on a straight section, cold water - after 5 years,
    2. A hole on the knee under the wooden floor on the circulation, the mist was flying, so that a stain was formed on the ceiling in the room below also about 5 years.
  • #22 17672857
    karolark
    Help: 702
    Rate: 2517
    Because it is copper :D and rice copper from supermarkets :cry:
    Cheap and good until now :idea:
    I, on the other hand, only use glued PVC for cold water.
  • #23 17672898
    ^ToM^
    Help: 495
    Rate: 2939
    I gave Hutmen copper pipes, but for CO. So far, although it's been 15 years, nothing has happened to it.
  • #24 17673081
    zbigniewsk
    Help: 14
    Rate: 52
    Good evening.
    Based on my experience, I have the most important advice, after the installation, whether it is PP, PEX, copper or steel, you should perform the so-called water pressure test for several hours. Such a test will possibly detect defects in the material used. Last year, an installation made of copper flew in my cage the year before. Made by a "foreman" with experience who did not like the pressure test. In the apartment on the 2nd floor there is a tragedy, the parquet needs to be replaced throughout the apartment, the replacement of the fresh water installation combined with the removal of tiles in the kitchen and bathroom, and renovation of the apartment below. After forging it turned out that the copper tube from Hutmen had a defect. The breakdown was when they were at work. Please remember that even the most reputable manufacturer will not guarantee that the material will be perfect. As I worked, I had a case that the 2.3 mm ferochrome wire was leaky at a pressure of 25 atm. The delivery was only 2.5 tons and everything was included in the manufactured insulators. It was just a tragedy to sort out good plays. We sorted the productions under the pressure of 50 atm for several months. It worked, but the workload was amazing.
    rolii1234
    I only have experience with PP, but over a dozen years, We started with Aquatherm, green pipes and fittings, now various companies are flying, sometimes even from a supermarket, there were no major problems, even when connecting elements from different manufacturers. I believe that welding is feasible even for a layman, but you have to plan everything well, in case of a mistake you can cut (shorten, lengthen, etc.) The system is cheap and simple, it is worth buying average quality, rather not in a supermarket.
  • #26 17673241
    12pawel
    Help: 207
    Rate: 697
    I, in turn, from my experience so far:
    - Fail-safe Pex system (residential, heating and compressed air installations up to 8.5 bar)
    - Galvanized twisted pipes (as above water and air), failure-free
    - Copper pipes (water installation in the house) 10 years of peace and now with 3 leaks patched.
    - PP welded pipes (water installation in the apartment) 2 times broken knee when connecting the washbasin.
    I load PEX wherever I can, the installations are even 15 years old and I don't look.
    PP, as my colleagues noticed, is a bit cumbersome to arrange due to the large dimensions of the fittings. I do not like the removal of the threads, for example, on a wall-mounted battery. In Pex, I have the option of screwing such a connector to a flat bar, such a flat bar determines the spacing of the terminals for the battery and their coplanarness. I put such a flat bar on decent pegs and then I can spin whatever I want. There is a lime in PP with this. Plastic delicate feet and later problems with sticking to the thread.
    And my colleague Zbigniewsk said a very important thing
    Pressure test. Before pouring the pipes / laying tiles, pressurize at least 120% of the pressure we will use (here it depends on the specific application and materials) and all imperfections should reveal themselves in time.
  • #27 17673877
    ^ToM^
    Help: 495
    Rate: 2939
    [quote = "rolii1234" The system is cheap and simple, it is worth buying average quality, rather not in the market. [/ quote]
    PP. It is impossible to overestimate the fact that the welding machine costs less than PLN 100 for PP, the cutters and deburrs are also cheap. The pipes are cheap, in case of a mistake we cut them off and go on. This is cool about PP.
    I recommend PP with a clear conscience to beginner plumbers.
    If I were to build a new house, I would put PP wherever I could. It is a very durable material and the polyfusion weld is like a factory cast.
  • #28 17673988
    Parowy
    Help: 55
    Rate: 227
    I read and read and ... I have a question - why the argument for choosing a system is the price?
    Renovation of a bathroom, for example, is done every 10-15 years, which is the higher one-time expenditure on more expensive (and in my opinion more reliable) systems.
    I'm not saying the PP system sucks, I don't use it. I use a system for which I can give a lifetime guarantee, which in relation to quality is not expensive at all.
  • #29 17674044
    karolark
    Help: 702
    Rate: 2517
    I do not use it either, but I think it is good, what are the disadvantages of my colleague noticing it?
    Why spend on something "better" when cheaper is just as good?
  • #30 17674059
    ^ToM^
    Help: 495
    Rate: 2939
    I am afraid that there is probably nothing more durable and reliable than PP. The fact that it will be the cheapest. Well, that's what happens sometimes. :) Just be happy.
The discussion revolves around the replacement of water pipes in a bathroom renovation, focusing on the choice between PEX and PP systems. Users share their experiences, highlighting that PP fittings are generally cheaper and simpler to implement, while PEX offers flexibility and ease of installation without expensive tools. Concerns about the reliability of connections, especially in tight spaces, are raised, with recommendations for proper tools and techniques for both systems. Users suggest purchasing materials from local plumbing stores rather than supermarkets to ensure quality. Brands like Tece and Kisan are mentioned, with a preference for proven manufacturers to avoid issues like leaks or failures. The importance of conducting a water pressure test post-installation is emphasized to detect potential defects.
TL;DR: Typical polypropylene (PP) plumbing materials cost 30–50 % less than comparable PEX systems [BuildPrice, 2023]; “PP is simple for an amateur and cheap” [Elektroda, robig, post #17672180] Choose PP for cost-efficiency, PEX for flexibility and fewer fittings. Why it matters: Picking the right pipe system lowers renovation cost while reducing leak risk.
• Pressure rating: PEX-AL-PEX 16 × 2 mm pipe is certified for 10–16 bar at 95 °C [TECE Datasheet, 2023]. • PP-R hot-water pipes handle 70 °C continuous at 10 bar (ISO 15874). • Entry-level PP welding kit (1500 W) costs PLN 150–170 [Elektroda, Ssaab, post #17668206] • Manual PEX crimper rental ≈ PLN 30/day; electric ≈ PLN 100/day [MarketRent, 2023]. • Pressure test: hold ≥ 1.2 × working pressure for 2 h [Elektroda, 12pawel, post #17673241]
1. Which pipe system is cheapest for a typical bathroom refit?
PP usually wins. Materials cost about one-third less than PEX and tools are cheaper or rentable for PLN 20–30/day [Elektroda, karolark, #17668213; MarketRent, 2023].
3. What tools are required for PEX installations?
A calibrator/deburrer and a crimping tool. Calibrators cost PLN 30–60 [Elektroda, 12pawel, post #17668254] Manual crimpers start at PLN 300; electric versions exceed PLN 1500 [ToolPrice, 2023].
4. Can I hide PEX threaded or crimped joints inside walls?
Avoid it. Installers report hidden threaded joints leaking over time [Elektroda, Romulus7874, post #17668296] Crimped sleeves are more reliable but still should remain accessible for inspection [TECE Guide, 2023].
5. How do I minimise leaks when using PEX?
  1. Calibrate every pipe end.
  2. Slide sleeve fully past notch marks.
  3. Perform a 1.2 × pressure test for two hours. These steps meet manufacturer guidelines and forum advice [Elektroda, 12pawel, #17668254; #17673241].
6. Are PP connections mechanically robust?
Yes, but the material is stiffer. Two users reported broken PP elbows only after misuse during basin installation [Elektroda, 12pawel, post #17673241] Proper support and expansion loops stop stress failures.
7. Is copper still worth considering?
Copper solders cleanly, yet edge cases show pin-hole leaks after five years in hard-water areas [Elektroda, nuszek, post #17672841] Material costs are also 2–3 × PP [BuildPrice, 2023].
10. Do I need aluminium-stiffened (stabi) PP for domestic hot water?
Not for short bathroom runs under 2 m. Standard PP-R class 2 pipe suffices up to 70 °C [ISO 15874] and saves money [Elektroda, Ssaab, post #17675507] Stabi helps only on long, exposed lines.
11. What statistic shows PEX durability?
A 2007 PEX system cited on the forum has run 16 years without failure [Elektroda, Strumien…, post #17681281], aligning with lab tests showing 50-year life at 70 °C [PEX Standard, 2022].
12. What common failure should I watch for?
Dezincification of brass PEX fittings can cause cracks within 5–10 years in mineral-rich water [Elektroda, andrzej lukaszewicz, post #17680875] Choose dezincification-resistant (DZR) brass or polymer fittings to avoid this.
13. How do I make a leak-free PP weld?
  1. Cut pipe square and mark 14–16 mm insertion depth.
  2. Heat pipe and fitting on 260 °C sockets for 5 s/Ø20 mm.
  3. Push together without twisting and hold 10 s. Result: uniform bead without internal lip [PP-R Manual, 2023].
14. Does pipe thickness matter when chasing walls?
Yes. PP-R Ø20 mm with fitting needs ~40 mm cover, often thicker than tile adhesive. PEX-AL-PEX Ø16 mm with sleeve needs ~25 mm, easier to hide [Elektroda, Plumpi, post #17676493]
15. What expert advice summarises the choice?
“I load PEX wherever I can; PP when I have to” [Elektroda, 12pawel, post #17668214] Use that rule when balancing flexibility versus price.
