Siemens SE24N860EU - Broken board, resistor identification, no diagram
rolnikszukazony 10203 9
What is the resistor on the Siemens SE24N860EU control board, and is there a schematic for this board?
The resistor in question is discussed as a roughly 100 Ω, 3 W part, and if it has failed the LNK340GN IC should also be checked or replaced [#16468445] [#16499651] Measure both the resistor and the LNK340GN with a meter rather than relying on visual inspection, because they can look normal while being faulty [#16499564] If the resistor burns out again soon after replacement, the likely cause is the LNK chip or an overvoltage problem, so inspect the fuse path at the varistor as well [#16558757]
  • #1 16468294
    rolnikszukazony
    Hello, I have a Siemens SE24N860EU dishwasher. The elements that I have already tracked are probably damaged, unfortunately I cannot find the schematic and decode what kind of resistor it is.
    The questions are as follows, what is the resistor visible in the photo? Does anyone have a schematic of this board? (AKO 704226, BSHG 9000.115.609, PRG 710573-02, AKO 710569-05)
    • Siemens SE24N860EU - Broken board, resistor identification, no diagram DSC07396.JPG (2.46 MB) You must be logged in to download this attachment.
    • Siemens SE24N860EU - Broken board, resistor identification, no diagram DSC07404.JPG (2.66 MB) You must be logged in to download this attachment.
    TONI_2003
    Moderator
    Help: 2194
    Rate: 3822
    Usually, in addition to the 100? resistor, the IC must be replaced :D
  • #3 16499446
    rolnikszukazony
    The dishwasher refused to cooperate again after about 5 work cycles. The symptoms are identical, i.e. no reaction, the display remains black, etc. Maybe this LNK340GN has died again a little strange? Visually, everything looks ok and the resistor and LNK340GN.
  • #4 16499564
    cezet
    Help: 718
    Rate: 1406
    Visually, it could all look good. Use the meter to measure the resistor and LNK340GN.
  • #5 16499651
    rolnikszukazony
    I measured the resistor and it was dead, I can not check the IC. Now it works again, we'll see how long ...
  • #6 16499688
    TONI_2003
    Moderator
    Help: 2194
    Rate: 3822
    So you probably did not give the same as the original politically correct :D
  • #7 16499706
    rolnikszukazony
    I gave 100? / 3W as you wrote to me in the second post :)
  • #8 16499749
    TONI_2003
    Moderator
    Help: 2194
    Rate: 3822
    Dear friend rolnikszukazony These are not the values I had in mind (the data is correct) when I wrote the previous post, and this is what was written about it ... :D
  • #9 16519313
    rolnikszukazony
    The resistor burned out again. Where to look for the cause?
  • #10 16558757
    Loker
    Help: 575
    Rate: 721
    The resistor burns most often when the LNK is burning. So if you replace the resistor and it will burn out immediately - LNK to be replaced.
    LNK usually burns from overvoltage. First, check that the fuse path at the varistor is complete.
✨ The discussion revolves around a Siemens SE24N860EU dishwasher experiencing issues with a damaged board, specifically focusing on resistor identification and the absence of a schematic. The user initially inquired about the resistor visible in a photo and sought a schematic for the board. Responses indicated that a 100Ω resistor and the LNK340GN IC are critical components, with suggestions to measure their functionality. The user reported that the resistor had failed, and after replacement, the dishwasher temporarily resumed operation. However, the resistor burned out again, prompting further investigation into potential causes, including the possibility of the LNK340GN failing due to overvoltage. Recommendations included checking the fuse path at the varistor to prevent recurring issues.
