Bosch KGV 2604 Schematic or SMD Side Photo Needed for Burnt 9.981.310.017-1 Board
pietkas 9686 2
  • #1 1313229
    pietkas
    Help!
    Burnt driver 9.981.310.017-1 after overvoltage in the network.
    Burned resistors: r31-r33, zd1, c3 torn, burned paths from the smd side near the triac - efficient unit.
    I need a schematic or photo plate from the smd side to fix the connections and recognize the elements.
    Kos
    Here are the photos.
    • BOSCH KGV-2604.rar (4.36 MB) You must be logged in to download this attachment.
  • #3 6670524
    kapitan_ameryka
    Hello, just 2 days ago I had such a case.
    Burned hole in the processor.
    For now I have replaced the electronics with a 50/50 percent time switch. Where can you buy such a module. Or maybe it will go without a processor? The rest seems to work.
    I have the type 9.981.310.017-1 and I saw the ending -4 or -2
    can it be used.
    I do not have a thyristor on my segment to control the bulb.
