Unannounced Electricity Meter Replacement by Energy Company Employee: Is it Permissible?
chiquita24 61302 33
Can the energy company replace my electricity meter in a staircase without notifying me, and what proof should I receive afterward?
Yes, if the meter is in a common/public place like a staircase, the operator can usually replace it without your presence, but it should still issue a document/protocol with the meter data and the readings at disassembly, and leave or send a copy to you [#19666907][#8709995][#8718158] If the work requires entry into your apartment, plot, or other private premises, they should ask for permission to enter [#19666907] The thread’s practical advice is to ask your local emergency/utility office for the replacement protocol and any archived meter readings, since that is where the recorded states should be available [#8709995][#8767705] Several replies also note that the law does not require the customer to be present for a legalization replacement, especially for meters mounted in shared areas [#8718158][#8708379] In other words, the replacement itself is not automatically suspicious, but you should demand the paperwork showing the old and new meter states so you have proof of what was removed and installed [#19666907][#8708379][#18275310]
  • #1 8707673
    chiquita24
    I have a question: can an energy company employee replace the meter on his own, without the recipient's knowledge (i.e. me)?
    Today there was a very (unpleasant for me) strange situation, when I was returning home, when I noticed that in the place where the meter was (there is) (the meters in my block are in the staircase) a red light flashes. My first thought - someone broke the meter ..... I panicked a little. I tried calling ZE to explain the "disappearance" of the meter, but no one answered.
    After making a call to the Energy Emergency Service and explaining what was going on, the gentleman informed me that what was flashing is the diode of the electronic counter.
    The fact is that no one or me informed me that the meter would be replaced, nor even left any information that it was replaced. I have no confirmation of the exchange, nothing at all.
    Somewhere between the lines I read that a protocol should probably be written out of such a meter replacement and the replacement should take place in my presence, right? So what should I do in such a situation ?? How can I be sure that the old meter was properly secured after it was removed and that nobody tampered with it and that they would not accuse me of stealing electricity (which, of course, I did not do, because I do not even know how)?
  • #2 8707699
    www
    Help: 7
    Rate: 13
    The electricity meter is owned by ZE, so they can replace it whenever they want.
  • #3 8708166
    =Grzegorz=
    Help: 73
    Rate: 445
    Maybe in special cases, e.g. in the tariff for individual recipients, it is possible to replace them without their presence, of course, a protocol is written (in the EV the original and a copy should be received by mail).
    If they detected something on the old meter, they would not replace it, but arrange a check in your presence. Now, after the replacement, they will not do anything to you, even if someone discovered that the old meter was combined.
    Enjoy your new accurate electronic counter :D
  • #4 8708195
  • #5 8708379
    zbich70
    Help: 1171
    Rate: 6668
    geguś wrote:
    Unfortunately not. The energy law says otherwise.
    With what condition was the old counter removed? Someone signed that what the fitters wrote in the protocol was true? Since when is the contract concluded by only one party?
    There is not a word about it in the energy law.
    But it is here Link
    § 35. After the end of the electricity supply period, as well as in the case of replacement of the metering and billing system during its supply, the energy company is obliged to issue to the customer a document containing data identifying the metering and measuring system and the meter readings at the time of disassembly.
    It does not follow from this provision that the exchange must take place in the presence of the recipient, nor that this document must be signed.
    The method of issuing the document is also not precise, so you can practically leave it in a counter cabinet, letterbox or stick it in the door
  • #6 8708395
    dawtepl
    Rate: 14
    Exactly - right. The agreement is bilateral. Not only that - it is possible that you did not get a completely new meter, but only a "recovered" meter, after legalization. Then there is a certain amount of kWh from the previous owner "loaded" on it. And now YOU have to sign the condition from the old meter as well as the one you received. Because theoretically, they can (intentionally or not) charge you with a very large amount of energy. They seem to take pictures of the meters downloaded, but who knows them there.
  • #7 8709088
    =Grzegorz=
    Help: 73
    Rate: 445
    YES exactly and it is not the fault of some EU directive, the number of which I do not remember. So you can get a fully functional used meter with tens of thousands of kilowatts on the abacus and everything is OK
  • #8 8709474
    chiquita24
    Well, I have no idea. The counter was replaced in my absence. I have neither any replacement protocol nor even any information that the meter has been replaced.
  • #9 8709641
  • #10 8709899
    =Grzegorz=
    Help: 73
    Rate: 445
    Let's deal specifically, I will ask for quotes ...
    By the way, I do not understand who it bothers and why to do the problem when it is not there.
  • #11 8709995
    karolq
    Help: 44
    Rate: 131
    The meter may be removed without the recipient's knowledge, but only in specific cases. When replacing the meter, the protocol is described in duplicate. The original goes to the plant, the copy for the recipient (usually by mail). I personally try to arrange with the owner, but it is not always possible, then, with the consent of the owner, other people who sign the protocol may be present at the exchange.
    Oh, and the states are available for inspection at the emergency department in your area.
    In summary, the fitters could inform about the replacement, but if they had access, they replaced it without the owner knowing.
  • #12 8710021
    =Grzegorz=
    Help: 73
    Rate: 445
    The example from Białystok shows that it can be replaced, similarly, we have been exchanging such meters for a long time. Therefore, I would like to ask you to provide specific records ...
  • #13 8710180
  • #14 8711352
    zbich70
    Help: 1171
    Rate: 6668
    geguś wrote:
    Me, fart. Such laziness already reigns here? Article 6.1 (2).
    This article uses the following keyword: control . Let's not overinterpret the law because we will fall into paranoia - legalization replacement of the meter is not a control. If so, the collector reading the meter should also meet the procedures required for the inspection (authorization, ID, protocol, signatures, presence of the recipient, etc.)
    Secondly - in case of falsification of meter readings during replacement - what interest would a serial fitter have? If so, he could lower the readings of the removable meter or inflate the indicated reading, take a bribe and worry about how it will be settled in the plant. But for this you need the presence of the recipient! The opposite action (i.e. to the disadvantage of the recipient) is completely pointless because who will pay the installer? That he will be fired for a mistake sooner!
    I would like to add that replacing during the absence is practicable when meters are available, because the most important thing is the number of pieces and meeting deadlines.
  • #15 8711890
  • #16 8713167
    =Grzegorz=
    Help: 73
    Rate: 445
    It is in the best interest of the recipient to admit a ZE employee to the meter.
    In addition, the exchange referred to in this topic concerns the meters of G11 tariff customers and systems LOCATED IN THE COMMERCIAL PLACE, such as a staircase, etc. Here, Article 6.1 does not apply.
    If the meter readings are false to the disadvantage of the recipient, a separate company would benefit: ENERGY SELLER who takes the cash from YOU.
    The fitter and the company he works for do not get a penny for a possible increase in condition.
    @ Geguś:
    After replacement, the meters do not disappear, because nobody throws them away on the second day, after removing them, the meter passes by a few more people who also write down the states.
    When a stranger wants to enter the cage, he usually says "MAIL".
    The fitter is responsible for his mistakes, if he has a wrong connection and something goes wrong, he has to pay.
  • #17 8713313
    zbich70
    Help: 1171
    Rate: 6668
    You're me buddy dude amused.
    The most important thing is that the presence of the recipient when replacing the meter will prevent a possible exchange of L with N. According to you, each recipient is an experienced electrician and by looking over the fitter's shoulder is able to detect it ???
    I am also surprised by people who spend a lot of money on doors and intercoms and let them in on a word. What if a thief comes and pretends to be a collector?
    And you have wondered why, during new connections and modernizations, the meters are installed outside the buildings and even on the property border? Well, so that the ZE staff have direct access to them!
  • #18 8713516
    kkas12
    Help: 1076
    Rate: 4313
    Hello!
    I don't know how you can blithely treat all the ideas of the EC as unquestionable binding law. The presence of the tenant whose meter replacement concerns is most desirable due to checking in his installation whether there was a mistake mentioned by a colleague dude and his (the tenant's) knowledge of electrical engineering is not essential at all.
    Requirements to install meters outside buildings are slowly starting to become an unjustified siphon of money from electricity users as energy suppliers are increasingly beginning to use accounting estimation. By caring for and limiting their expenses, they also force expenses of other people or business entities.
  • #19 8713529
  • #20 8714561
    stomat
    Help: 257
    Rate: 1982
    Some follow Kali's philosophy. You can often read how the ZE interferes with its affairs, penetrates into the recipient's installation and how bad it is. Now it hasn't penetrated and it's also bad. What's the problem anyway? You, gentleman, felt undervalued? If they change the weight in the store, do they also notify customers? And in the telephone exchange, how do they change the meters? This is the distributor's counter and he can change it whenever he wants. A colleague Geguś can take off the meter, there is the "R" tariff as a lump sum.
  • #21 8714832
  • #22 8717893
    tomus2k
    Help: 89
    Rate: 218
    art. 142 p 2 of the Civil Code, the collector has the right to enter our premises without our consent to read the meter. This also applies to the ZE service.
    We have art. 385'3 p. 11 of the Civil Code. The following provisions are considered illegal: I quote "they only grant the customer's contractor the right to state compliance with the contract"
    The meter is part of the contract and its number is written on f-vat, changing the meter is a unilateral contract change, and changing it without knowing the value before disassembly is a unilateral breach of contract terms. What is the conclusion? You can disagree with the next invoice and terminate the contract, and the consequence will be borne by ZE.
    But are you sure ?
    If it were not for the monopolistic position of ZE, it could be done, but who will supply us with energy to our home, plant?
    So we tighten our belts, the carrots in our mouths and write a letter to the Ombudsman asking him to come forward with the initiative to change the energy law.
    And if someone has been deceived, he is left with a case for the reporter and a request to the plant to spread the debt into installments. The mere submission of the bet to the Court does not release us from paying (on the part of the contract), otherwise ZE has the right to disconnect the lines and terminate the contract.
    And please respect each other and do not challenge honestly working ZE service technicians from the thieves because they did not create this law, it is better to direct your anger in the right direction ... but please, I mean a legislative initiative, not a gun.
  • #23 8718158
    stomat
    Help: 257
    Rate: 1982
    Not true. The meters are periodically removed for legalization and it is not a contract change. On the other hand, the Ordinance of the Minister of Economy of May 4, 2007 on the detailed conditions for the operation of the power system in paragraph 43 section 7 says: "In the case of replacement of the metering and billing system during the supply of electricity, and also after the end of its supply, the energy company issues a document to the recipient. containing data identifying the metering and billing system and the meter reading status at the time of disassembly. " There is no obligation to inform the customer about the replacement of the meter.
    But we still don't know what's the problem ?
  • #24 8718329
  • #25 8767648
    mimimim4m
    And that's where I have a problem, a very serious one. In March, the meter was replaced and the protocol was left in the mailbox. The initial state of the report is "0". The counters are in the corridor in a locked chest. When the annual settlement came in September, it turned out that the meter is 10500kWh and fv for PLN 5500 (previously I used about 1000kWh per year, and here for a period of 6 months 10500kWh). The meter was sent for testing and it turned out to be operational. I suspect that the installed meter was not new and the initial state was different from zero, and the installer made a mistake in entering the initial state, or the meter itself is defective. The expert opinion confirmed the correct counting, but the report does not mention the correct operation of the display, or the reading from the memory or errors from the meter register. I'm trying to fight the Vattenfall but they got me in ... there is an indication of pay. I am afraid that I will not be able to deal with it, and I see no reason to give them PLN 5,000. The installation was checked and everything is ok. The average consumption in this period was 2kWh / h. I wrote another complaint about proving by Vattenfal that the meter was "0" and I am waiting for a response. I don't know what to do next, maybe someone will suggest an idea?
  • #26 8767705
    karolq
    Help: 44
    Rate: 131
    Go to the nearest emergency room in your area and explain the matter. They have assembly cards with the meter reading from the photo written down. Maybe such an invoice is the result of a badly written old meter or, as you say, "new" was not new but legalized. The installer wrote 0 and in fact it could have been a bit more, but he should know what the dangers of such action are :) #
  • #27 8767829
    =Grzegorz=
    Help: 73
    Rate: 445
    If it was an electronic counter, all the history is there, it is enough to read the states and dates. Since it was tested, it means it was done.
    If it was an inductive meter, it could not be hung again if it was already hanging by someone and it could not have states greater than a few kWh.
    If the meter for testing has been replaced, you now have a new meter by which you can assess how much you use. Convert how much you have per day IT'S VERY EASY! write down the meter readings, what devices you have at home.
    I suspect that the first meter was faulty which is not such a rare case. The meter could hang for 15 years with the bridge down / loose or two! and it did not catch it, then an electronic exchange comes and suddenly the invoice grows 2 or 3 times
  • #28 8769108
  • #29 8769894
    mimimim4m
    Yes, it's exactly about my Dad (72 years old). He lives alone in a block of flats, uses an 11W bulb and a 100W TV. The report of the expert opinion does not mention anything about the readings from the meter's memory or the error log. It was only checked that the meter measures correctly at a load of 60A, 0.5A and 1A.
    https://www.elektroda.pl/rtvforum/topic1799456.html
  • #30 8769964
    =Grzegorz=
    Help: 73
    Rate: 445
    You requested the meter expertise and it turned out well, which does not surprise me.
    I would ask the ZE for a protocol for reading the meter memory with archival indications.
    What you can do now is read the current meter every day and calculate the average daily consumption.
    If the previous meter was defective or the employee made a mistake, then everything should be OK on the current meter
The discussion revolves around the permissibility of an energy company employee replacing an electricity meter without the recipient's knowledge. Users express concerns about the legality and protocol of such actions, citing energy laws that govern meter replacements. Some responses indicate that while the energy company (ZE) owns the meter and can replace it, proper notification and documentation (protocol) should ideally be provided to the recipient. There are mentions of specific articles from the Energy Law and Civil Code that address the rights of both the energy company and the recipient regarding meter access and replacement. Users also share personal experiences related to meter replacements, highlighting issues with incorrect readings and the lack of transparency in the process.
TL;DR: Polish distribution operators may swap your electricity meter any time during its ~8-year legalisation cycle, but they must leave a written reading record—“the energy company is obliged to issue a document” [Elektroda, zbich70, post #8708379] Failing to do so can trigger billing disputes of up to 10 500 kWh [Elektroda, mimimim4m, post #8767648]
Why it matters: Missing paperwork shifts billing risk and proof burden onto the consumer.
• Legal verification cycle: typically 8 years [Elektroda, bergkamilzur, post #19666907] • Operator must issue a removal-reading document (§35, Rozporządzenie MG, 04-05-2007) • Entry to private premises requires ID + written authorisation (Energy Law, Art. 6) • Re-legalised meters can start above 0; opening reading gets recorded [Elektroda, dawtepl, post #8708395] • Largest forum-reported error: 10 500 kWh, ≈ 5 500 PLN extra charge [Elektroda, mimimim4m, post #8767648]
Who actually owns my electricity meter?
The distribution company (ZE/DSO) owns the meter; it is only installed on your property [Elektroda, www, post #8707699]
Can the operator replace the meter without notifying me first?
Yes, if the meter is in a common area or fence box. The Energy Law lets authorised staff perform “works related to operation or repair” after showing ID [Energy Law, Art. 6].
What paperwork should I receive?
You should get a two-number slip showing old and new readings plus meter serials. It may be left in the cabinet or mailbox [Elektroda, karolq, post #8709995]
What if no protocol was left?
Report it to the local emergency/service office and request the assembly card photo; these cards archive every swap [Elektroda, karolq, post #8767705]
Can a “new” meter already show kilowatt-hours?
Yes. Legalised second-hand meters often retain earlier totals. The installer records that figure as your start state, so billing stays fair [Elektroda, dawtepl, post #8708395]
Could the fitter wire the meter incorrectly?
It happens. Swapping phase and neutral can trip protection or damage appliances [Elektroda, Anonymous, post #8711890] Always test sockets after a swap.
What steps should I take right after an unannounced replacement?
  1. Photograph the new display and serial number immediately.
  2. Compare old vs. new readings on the slip; report mismatches.
  3. Keep daily readings for seven days to spot abnormal drift.
How do I dispute a sudden spike like 10 500 kWh?
Request a memory read-out and lab test of the removed meter. If results show correct accuracy, compare your new meter’s daily average; large differences support a billing correction [Elektroda, mimimim4m, post #8769964]
Does meter replacement change my energy contract?
No. The contract remains; only the device identifier updates in the operator’s database [Elektroda, stomat, post #8718158]
Can I refuse entry to the installer?
If the meter is inside your flat, you can delay once. Persistent refusal lets the operator terminate supply for breach of Art. 6 obligations [Energy Law, Art. 6; Elektroda, bergkamilzur, #19666907].
