Sealing Electricity Meters: Protocol & Pattern for Meter or Connection Seal Placement
dj szefunio 7080 17
Is a formal protocol required when sealing an electricity sub-meter or connection, and what information should the sealing record contain?
For an internally used sub-meter, no standard sealing form is required; prepare your own protocol recording the date, meter number, current reading, and seal number. Make two or three copies for the installer, energy seller, and buyer, and preferably have both parties sign it. [#16645997] The seal should have an identifying number or mark that can be recorded and cannot be removed without visible damage. [#16646171] A utility meter used for settlement with the distribution operator is different: the operator’s staff perform its sealing. [#16645660]
  • #1 16645624
    dj szefunio
    Hello. I have a question, is the protocol needed if a seal is placed on the meter, the meter or the connection?
    If so, please send the pattern or download link.
  • #2 16645660
    zbich70
    Help: 1171
    Rate: 6668
    Counter or sub-meter?
    These are two different things.
    The meter used for settlements with the distribution network operator is sealed by the operator's staff.
    The sub-meters used for internal settlements are sealed or not. It depends on how the parties agree.
  • #3 16645666
    dj szefunio
    All in all, I mean more about sealing the sub-meter and possibly a place to distribute this energy.
  • #4 16645675
    djlukas
    Help: 94
    Rate: 266
    And where do you get such a seal?
  • #5 16645696
    dj szefunio
    From an electrical store or an electrical wholesaler
  • #6 16645714
    zbich70
    Help: 1171
    Rate: 6668
    Maybe something from this assortment -> Link
  • #7 16645718
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3532
    And after buying this seal, what will you draw on it?
  • #8 16645725
    djlukas
    Help: 94
    Rate: 266
    Well, I forgot about it. I haven't used the seals in a very long time. The only ones I deal with at present are those from ZE.
  • #9 16645734
    dj szefunio
    It already has markings on it.
    But never mind that, gentlemen.
    I mean is there any document on which the necessary data is written. Document to be a confirmation that it was sealed in accordance with applicable regulations.
  • Need for a sealing compliance document
    #10 16645791
    zbich70
    Help: 1171
    Rate: 6668
    You sell your energy to someone, you either trust them or not.
    If you trust, then don't seal. If you don't trust then don't resell and give it up.
    Of course, it is possible to sub-sell energy. But when I see texts such as this topic, there is only one answer - take care of yourself, possibly hire a parrot.
    Suggested sealing protocol with meter and seal numbers
    #11 16645997
    mawerix123
    Help: 482
    Rate: 951
    But what rules :?:
    You can write down the protocol you want, include the date, meter number, current meter reading, seal number, make the protocol in two or even three copies for you, for the energy seller and for the buyer, sign it as the fitter, it will not hurt the signature of both parties and finito.
  • Need for a sealing report with imprint details
    #12 16646104
    retrofood
    Help: 1140
    Rate: 4798
    If it is already marked, it is not a seal, but garbage. Identification marks of the sealer's imprint that are impossible to forge should be described in the report. And how to write it, invent it yourself.
  • #13 16646136
    mawerix123
    Help: 482
    Rate: 951
    This would have to mean that Tauron and before that Enion seal with worthless plastic.
  • #14 16646148
    retrofood
    Help: 1140
    Rate: 4798
    Kind of right. So describe what seals they use.
  • #15 16646155
    Rezystor240
    Help: 689
    Rate: 1651
    What company such seals.
    The seal must be 'clean' only after the sealed meter is punched or a number or something else appears under the meter.
  • Need for numbered, tamper-evident seals only
    #16 16646171
    mawerix123
    Help: 482
    Rate: 951
    Maybe it's worth showing
    After all, in the case of the author, you do not need some unknown seal, important that it has a number that can be written down and could not be removed without damage, even the trucks of that time are sealed for transport and somehow it is done.
    At least they can make a connection to the house so that the selectivity of protection is maintained, Tauron has already grown from installation switches as a power limitation.
    I do not even mention the disconnection of the PEN, as is practiced in other regions of Poland in Tauron, such idiocy has never been used.
    Unfortunately, the technique moves forward whether the colleague likes it or not, and LEAD is harmful :D
  • Need for a numbered tamper-evident seal on the sub-meter
    #17 16646194
    dj szefunio
    Exactly what I mean should be a seal on the sub-meter and you can write down the number of this seal.
    So, in summary, there is no typical sealing document?
  • #18 16646263
    Darom
    Help: 231
    Rate: 588
    Do as col. Mawerix123 wrote to you in post No. 11. Preferably, however, with the signatures of both parties. Nothing else is needed.
    kisses
    - GIFT-
The discussion revolves around the protocols and practices for sealing electricity meters, particularly sub-meters used for internal energy distribution. Participants clarify that sealing is typically performed by the distribution network operator for settlement meters, while sub-meters may or may not be sealed based on mutual agreements. The conversation highlights the importance of documenting the sealing process, including meter numbers, readings, and seal numbers, to ensure compliance with regulations. Suggestions for obtaining seals include electrical stores and wholesalers, and the need for a clear protocol is emphasized, although no standardized document is provided. The discussion also touches on the reliability of seals and the necessity of trust in energy transactions.
TL;DR: For sub‑meters, create a simple sealing protocol logging 4 basics (date, meter number, reading, seal number). “You can write down the protocol you want.” [Elektroda, mawerix123, post #16645997]
Why it matters: This FAQ helps installers and landlords document sub‑meter seals clearly so disputes and tampering claims don’t derail billing.
Do I need a protocol when I seal a sub‑meter?
Yes. For sub‑metering, document the seal with a simple protocol. Include date, meter number, current reading, and seal number. Prepare two or three copies for the seller, buyer, and your records. Sign as the fitter; both parties should also sign. “You can write down the protocol you want.” [Elektroda, mawerix123, post #16645997]
Who is responsible for sealing the utility meter versus a sub‑meter?
The distribution operator seals the main settlement meter. Sub‑meters used for internal billing are sealed—or not—based on agreement between the involved parties. Operator seals and procedures do not apply to private sub‑metering. [Elektroda, zbich70, post #16645660]
What fields must I include in a sub‑meter sealing protocol?
Record at least four items: date of sealing, meter identification, current meter reading, and unique seal number. Create two or three identical copies. Sign as the installer, and obtain signatures from both parties receiving and paying for energy. [Elektroda, mawerix123, post #16645997]
What kind of seal should I use on a sub‑meter?
Use a numbered, tamper‑evident seal that shows damage if removed. This enables you to record a unique identifier and detect interference. Plastic indicator seals with serial numbers are common for this purpose. [Elektroda, mawerix123, post #16646171]
Are pre‑marked plastic seals acceptable?
Pre‑marked seals without unique sealer identification are weak controls. Strong practice is to ensure the sealer’s unique identification is described in the report, so forgery is difficult. [Elektroda, retrofood, post #16646104]
Where can I buy seals for sub‑meters?
Buy tamper‑evident indicator seals from electrical stores or wholesalers. Ensure each seal has a unique number suitable for recording in your protocol and on handover documents. [Elektroda, dj szefunio, post #16645696]
What should I inscribe or imprint on the seal?
Do not rely only on factory markings. Your protocol should reference the seal’s unique number and, if used, your unique sealer identification described in the report. This links the physical seal and documentation. [Elektroda, retrofood, post #16646104]
How many copies of the sealing protocol should I make?
Make two or even three copies: one for you (the fitter/installer), one for the energy seller, and one for the buyer/tenant. All copies should be signed identically. [Elektroda, mawerix123, post #16645997]
Is a formal, standardized template required by regulations?
No specific standardized form is required in this context. A clear, signed protocol with the key fields and copies for each party is sufficient confirmation of proper sealing. [Elektroda, Darom, post #16646263]
How do I actually seal and document a sub‑meter? (3‑step How‑To)
  1. Install a numbered tamper‑evident seal so removal causes visible damage. 2. Record date, meter ID, reading, and seal number; prepare 2–3 copies. 3. Sign as fitter and collect signatures from both parties; hand out copies. [Elektroda, mawerix123, post #16645997]
Can I use the utility company’s seals on my sub‑meter?
No. Utility seals are applied only by the operator’s staff to the settlement meter. Sub‑meter seals and rules depend on the agreement between the private parties. [Elektroda, zbich70, post #16645660]
What if I skip sealing and just trust the tenant?
Sealing is optional for sub‑metering and reflects trust between parties. If trust is low, use a seal and protocol; if trust is absent, consider not reselling energy. [Elektroda, zbich70, post #16645791]
What’s an acceptable tamper‑evidence standard here?
Choose seals that cannot be removed without damage and have a unique serial number. “Important that it has a number that can be written down and could not be removed without damage.” [Elektroda, mawerix123, post #16646171]
Edge case: Are factory pre‑numbered seals safe against forgery?
Risk remains if the sealer’s unique identification is not captured. Mitigate by documenting the identification marks of the sealer’s imprint within the protocol, as forging plain pre‑marks is easier. [Elektroda, retrofood, post #16646104]
What’s a practical statistic I can use to audit installs later?
Track the four recorded fields per install and the number of copies issued. Audits can confirm that 2–3 copies and all four fields were completed for each sealing event. [Elektroda, mawerix123, post #16645997]
If I follow these steps, is anything else needed to be compliant?
No additional paperwork is needed for private sub‑meter sealing beyond a clear, signed protocol capturing the essentials and party signatures. [Elektroda, Darom, post #16646263]
