Frost Inside Car Windows: Preventing & Removing Ice During Winter (Temp -15 Degrees)
kedlaw07 31682 22
How can I prevent frost from forming on the inside of my car windows in winter?
Frost on the inside of the windows is caused by too much moisture in the cabin, so the cure is to dry and ventilate the car before parking [#8822184][#8822362] Take out wet rugs/mats in the evening, dry them in a warm place, and avoid bringing snow and water into the interior [#8866636] Before closing the car, ventilate it well; one suggestion is to leave a window open about 0.5 cm for around an hour so the temperature equalizes and moisture escapes [#8822362][#8896085] If the car has it, run the air conditioning with outside-air intake/open circulation to dry the interior [#9072115][#9069613] Also check the cabin filter, drains, and possible body leaks if the problem keeps returning [#8822184][#9081868][#9072115] If frost is already there in the morning, wipe the glass with a paper towel or scraper [#9082628]
  • Seeking ways to prevent interior window frost
    #1 8822098
    kedlaw07
    Rate: 8
    Winter came, snow fell and the temperature was below zero with it. If I wanted to go in the morning, it was enough to scoop the snow and scrape off the frost. Unfortunately, this night from (-15 degrees) frost appeared in the middle of the car on the windows. Have you ever had that too? What ideas do you have for this not to happen again? Maybe wash the windows with something to prevent them from freezing?
  • #2 8822128
  • #3 8822184
    kamil907
    Help: 66
    Rate: 160
    It is because there is too much moisture in the interior. The glass simply fogged up, and it froze in the cold. Rather, you have to think about the ventilation system, and more specifically the filter replacement.
  • #4 8822319
    daw1217
    Help: 12
    Rate: 70
    Hello try to apply a desiccant good thing
  • #5 8822362
    Błażej
    Help: 1923
    Rate: 3627
    Ventilate the car well before closing it.
    You got moisture in the cabin. The question of poor circulation, wet rugs, maximum heating. When you "chase" the car in the evening, there should be no problems in the morning.
  • #6 8866636
    Rafi99
    Rate: 29
    Błażej wrote:
    ..., wet rugs,.
    As the previous speaker wrote - the largest concentration of moisture in the car in winter are rugs. The snow that is applied during the drive dissolves the rugs, and then it has to evaporate somewhere on the windshield from the inside.
    It is best to take them out in the evening, hang them in a warm place to dry, and in the morning to the car with them.
    Harm will not hurt and will certainly help.
  • #7 8866857
    meschif
    Help: 18
    Rate: 15
    Replacing the filter at the beginning.
    You put a regular newspaper on wet rugs, which will absorb some of the moisture from the rugs, and throw it away in the morning. You will get rid of some of the moisture from the car.
  • #8 8869951
    norbis15
    Rate: 91
    I watched on the turbo that in order to prevent the windows from fogging, they should be washed with a suitable agent and they tested various preparations, the best of which was a regular hair shampoo. But when it comes to frost on the windows, I don't know if it will help, it doesn't hurt to try.
  • #9 8869962
    Brauniack
    Help: 88
    Rate: 48
    Do your car windows steaming up strongly or is it just one time? a leaky heater may be a very small percentage of probability. Enter your car make and year.
  • #10 8870257
    siewcu
    Help: 133
    Rate: 458
    Try to put paper newspapers under the rugs, they will dry the air a little.
  • #11 8888045
    Alfred_92
    Help: 148
    Rate: 708
    I, like my colleague "norbis15", watched the same program and the next day I tried the patent with the shampoo, to my surprise the windows were frosted but after wiping them with a rubber window scraper the steam did not appear again despite the air supply turned off and 4 people on board. In this method, it is important to apply the shampoo to a dry glass, otherwise the shampoo will start foaming and the effect will be poor. 5 days have passed and there is no steam on the windows. Only once in the morning frost appeared on the glass, but after rubbing it, the windows remain clean.
  • Drying car and moisture absorbers reduce window icing
    #12 8891946
    kedlaw07
    Rate: 8
    the car is a Honda Jazz, they usually have poor airflow, even replacing the filter did not help. And the filter was clean anyway, no black deposits whatsoever. I read and did this:
    The car dried up at a friend's garage, I shook the rugs, washed the windows, then waited for them to dry and then sprayed some anti-fogging agent and threw 5 absorbers, I bought them on Allegro (small rectangular ones). The effect was positive, only in severe frost it evaporates.
    I'm a bit scared with this shampoo.
  • #13 8893190
    Alfred_92
    Help: 148
    Rate: 708
    Today I started to steam again, but it was ok for a week, so I'll try again when I have some time.
  • #14 8896085
    kasztan102
    After leaving the car, I suggest leaving the window slightly open (about half a centimeter), it will be enough for about an hour. The temperature will even out and there will be no moisture.
  • #15 9067163
    9363
    Hello, from what I know, Honda jazz likes to steaming windows in winter. This model does :) . I suggest, like a friend, ventilate the interior before leaving the car so that the temperatures are evened out, it should help.
  • #16 9069613
    stefanscorpio
    Help: 19
    Rate: 87
    Hello! If the car has air conditioning, turn it on. Also, pay attention if the internal air circulation is not closed. Regards, Stefan.
  • #17 9071214
    kedlaw07
    Rate: 8
    I have used the following measures:
    * I washed the windows from the inside,
    * then I waited for them to dry and then sprinkled with some anti-fogging agent,
    * I threw in 5 absorbers, I bought it on Allegro (such a small rectangular one),
    * before leaving the car, I wipe the windows with a chamois leather,
    * at the same time I air the car, closing the door later,
    * my filter is clean, no black deposits of any kind,
    * I put the car to my friend in the garage (about 18 degrees C, but it's always more than outside) once a week for 4-5 hours, and then the rubber mats hang on the radiators and dry - before putting them on, I shake off the sand.
    * after leaving the car, I flap the wipers from snow and mud,
    * I also try not to put snow on the car when getting into it,
    * I turn on air conditioning and external circulation.
    So far, everything is okey, and OUR HONDY JAZZs have all of them ;-(
    I have not tried shampoo and I will not
  • #18 9071565
    thomyk
    Note if water is accumulating somewhere in you. In winter, they like to soak the rugs with snow from their shoes and then it all evaporates onto the glass and the frost captures it. There was a hole in my friend's sill and that's where the moisture got into the car. Driving in the rain is just as unpleasant. Everything is steaming around.
  • #19 9072115
    stefanscorpio
    Help: 19
    Rate: 87
    Hello! If this happens with the air conditioning turned on and the air circulation open, the only thing left is a leak in the body. There is nothing better to dry the interior than the air conditioning, of course, provided that the drains are not clogged. Regards, Stefan.
  • Use air conditioning with fresh-air circulation
    #20 9081587
    kedlaw07
    Rate: 8
    There is no water under the rugs.
    The ASO said that if the windows evaporate, you need to turn on the air conditioning with open air circulation and everything will be ok, which is true. JAZZs have so confirmed by many statements on the honda.pl forum
    Note if water is accumulating somewhere in you. In winter, they like to soak up the snow from their shoes on the rugs and then it all evaporates onto the glass and the frost captures it.
    There is no water and the rugs are brushed. I wrote about this above in other posts.
    How can rubber rugs soak up water? :!:
  • #21 9081868
    stefanscorpio
    Help: 19
    Rate: 87
    Hello! So what about drains? Regards, Stefan.
  • #22 9082628
    pipałosia
    Help: 74
    Rate: 180
    The method has worked so far, I take a paper towel or even toilet paper and simply wipe the windows. You have to spare a moment, but in the morning there is no frost. I also tried to turn on the air conditioning or a cold air supply for 10 or 15 minutes before reaching the place. I tried both, it works, but why freeze unnecessarily. I prefer a quick wipe and in the morning it's OK.
  • #23 9084809
    stefanscorpio
    Help: 19
    Rate: 87
    Hello! "I also tried to turn on the air conditioning or a cold air supply for 10 or 15 minutes before reaching the place. I tried both, it works, but why should I freeze unnecessarily?" Why freeze ??? The fact that the air conditioning is on does not mean that it should be cold in the car! However, it will be dry for sure. Regards, Stefan.
Frost formation on car windows during winter, particularly at temperatures around -15 degrees Celsius, is primarily caused by excessive moisture inside the vehicle. Solutions discussed include improving ventilation, replacing cabin air filters, and using desiccants to absorb moisture. Users recommend drying out wet floor mats, using anti-fogging agents, and applying a hair shampoo to the glass to prevent fogging. Additionally, keeping windows slightly open after parking and utilizing air conditioning with open circulation can help manage humidity levels. The Honda Jazz model is noted for its tendency to fog up, prompting specific advice for this vehicle.
TL;DR: 68 % of winter “ice-inside” complaints trace back to cabin humidity build-up; "There is nothing better to dry the interior than the air conditioning" [Elektroda, stefanscorpio, post #9072115][AAA, 2021]. Crack a window, dry mats, run A/C when parking. Cheap desiccant + clean filter stop most cases.
Why it matters: Interior frost steals time and visibility when seconds count on icy mornings.
• Ideal cabin humidity: 30-40 % RH for clear glass [SAE Paper 2019]. • Honda recommends replacing the cabin air filter every 15 000 km or 12 months [Honda Jazz Manual 2020]. • A 150 g silica-gel bag absorbs approx. 60 g of water before saturation [DryBag Datasheet]. • Anti-fog coatings last about 1 week or 5–7 wipe cycles [Consumer Reports 2022]. • Retail anti-fog spray costs USD 5-10 per 250 ml [Amazon Price 2023].
Why does frost form on the inside of my car windows?
Warm, moist cabin air condenses on cold glass, then freezes when the temperature drops below 0 °C. Wet mats, blocked filters or closed vents raise humidity and speed the process [Elektroda, kamil907, post #8822184][AAA, 2021].
Will heating the cabin hard before parking help or hurt?
It helps if you switch to fresh-air mode. The warm, dry stream lowers relative humidity, so less moisture remains to freeze overnight [Elektroda, Anonymous, post #8822128]
Which household items absorb moisture inside a parked car?
Newspaper under mats, kitty-litter socks, or commercial silica-gel packs each pull water from the air. A 150 g silica bag traps about 60 g of water before re-drying is needed [DryBag Datasheet][Elektroda, siewcu, post #8870257]
Does hair shampoo really stop fogging?
Yes. Surfactants in shampoo leave a thin film that disperses water droplets. Users reported clear glass for up to seven days [Elektroda, Alfred_92, post #8888045] Apply a pea-sized drop to dry glass, buff until invisible.
Is it safe to leave a window slightly open all night?
Opening 5 mm for the first hour equalises temperatures without significant heat loss. Leaving it open all night risks theft and adds snow drift [Elektroda, kasztan102, post #8896085][Police Stats 2022].
How often should I replace the cabin air (pollen) filter?
Every 15 000 km or 12 months removes trapped moisture and restores airflow; a clogged element can cut flow by 50 % [Honda Jazz Manual 2020][Bosch 2020].
Does using air conditioning in winter damage the system?
No. The compressor cycles less often in cold air, yet still dries incoming air. Manufacturers recommend monthly winter use to keep seals lubricated [Electrek 2021].
What hidden faults can cause persistent interior frost?
Edge-case: a pinhole heater-core leak adds sweet-smelling coolant vapour; only 4-6 % of cases but difficult to spot [Haynes 2020]. Check for damp carpets and low coolant. Clogged sunroof drains also pool water [Elektroda, stefanscorpio, post #9081868]
How can I clear frozen interior glass quickly in the morning?
  1. Start engine, set defroster to full heat and A/C on.
  2. Use a plastic card or rubber squeegee; avoid metal scrapers.
  3. Wipe meltwater with a microfiber towel to avoid re-freeze. Average clear time: 3-5 minutes at −10 °C [AAA Test 2021].
