Lubrication of gaskets at squeaky side window in hot weatherы
Tani najlepszy 22950 10
How can I stop a side window from squeaking in hot weather without dirtying the glass, and do I need to replace the mechanism?
Try cleaning the window/seals first, then apply a small amount of silicone grease, Vaseline, or thick shampoo to the rubber guide/seal, keeping it sparing so it does not end up on the glass [#18864795][#18865434][#18866419] The squeak often gets better when the glass is wet, and one user reported that washing both sides of the window made the problem disappear [#18866419] Avoid WD-40 on rubber parts, because it is a petroleum distillate and may harm the seals [#18864931][#18864917] If the noise comes from the lift mechanism rather than the seal, lubrication may only help for a short time, especially on cable/roller mechanisms where worn pins or the cable itself are the real problem [#18864931][#18868391] In that case, the mechanic’s advice to replace the mechanism may be the more lasting fix [#18864931][#18868391]
  • #1 18864770
    Tani najlepszy
    My windshield squeaks terribly when opening and closing. Especially when it is hot outside. The mechanic recommended that I replace the whole mechanism. I don't know if it's not a matter of friction against these door seals. Maybe it's possible to lubricate it with something, to strain it to try. I just don't know what with, so that it doesn't in turn dirty the glass.
    sylweksylwina
    Help: 1882
    Rate: 2355
    Maybe some silicone grease or, for example, Vaseline.
  • #3 18864856
    Tani najlepszy
    And won't it leave greasy marks on the glass? Generally when it's wet it squeaks less because it has a slip, so I think something like this would help. A lubricant like WD-40?
    Blank gray image with a picture icon in the center. .
    I sell a summerhouse in the Bieszczady Mountains. Details on PW .
  • #4 18864917
    sylweksylwina
    Help: 1882
    Rate: 2355
    If it leaves a mark on the edge it's probably not a problem. Anyway, it has to be applied in moderation and not splashed around ;) WD-40 is also greasy, but I would be afraid to apply it to gaskets.
    tzok
    Help: 3175
    Rate: 6546
    What kind of car/what kind of window lift mechanism is it. Either way, I'd rather listen to a mechanic, because if it's a cable mechanism (VW group for example) then the cable will soon break, and lubrication will help for a while. The nylon rollers squeak, not the glass, and they squeak because they have rubbed in and/or corroded their pins. If it's a Skoda, I suggest you put up the extra 50 zloty and buy the whole mechanism, not just the guides, and save yourself the trouble of stretching and riveting the thing.
    WD-40 is a petroleum distillate (paraffin) and should be kept away from rubber parts!
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Germany recommends a thick shampoo.
  • #7 18866208
    Tani najlepszy
    Gerri wrote:
    Germans recommend a thick shampoo.
    Some glass cleaner has also come to my mind. I know it's for a while, but when it's wet it doesn't squeak.
    As for the make, it's a Renault Megane II Convertible Coupe. I don't know what it's like at the front, but the rear windows do swish a bit and there you have to buy the whole mechanism with guides to replace the motor. I think one costs something like PLN1,500. Both at the rear are in poor shape already reconditioned. At the front, I don't know what it's like to replace them, but it could be similar, and probably more expensive. Maybe something used, but generally these cars are not too many. I wanted to sell it last year, but the idea of building a house and buying a plot of land was born, so I held off. With that said, I prefer to limit myself to replacing essentials.
  • #8 18866408
    tzok
    Help: 3175
    Rate: 6546
    The slides alone cost PLN120, the whole mechanism (with backing plate) PLN200.... There is some of this on Allegro.
  • #9 18866419
    babat
    Help: 45
    Rate: 44
    I also had a squeak and it diminished when wet, so I didn't try anything but washed the windows on both sides and the problem disappeared.
  • #10 18868242
    Tani najlepszy
    tzok wrote:
    The slides alone cost PLN120, the whole mechanism (with backing plate) PLN200.... there is a bit of it on Allegro.
    I have indeed seen a few on Allegro. The rear ones for the convertible unfortunately only for the III, but the front ones there were a few auctions for the II at prices like you write.
    babat wrote:
    I also had a squeaking noise and it diminished when wet so I didn't try anything but washed the windows on both sides and the problem disappeared.
    They were already washed but I will try some of that thick shampoo.
    For me, in the heat, it squeaks so badly that my brain lashes out.
  • #11 18868391
    tzok
    Help: 3175
    Rate: 6546
    In my dad's Octavia they were also squeaking.... I cleaned, lubricated and it helped for a few days, maybe a week. When it rained, the window would go quietly, when it was warm and dry it would squeal or even jam. Eventually the cable broke, I replaced the mechanism and it's been quiet ever since.
The discussion revolves around a squeaky windshield issue in a Renault Megane II Convertible Coupe, particularly in hot weather. The user is considering lubrication options instead of replacing the entire window lift mechanism as suggested by a mechanic. Various lubricants are discussed, including silicone grease, Vaseline, and WD-40, with caution advised against using WD-40 on rubber gaskets due to its petroleum distillate content. Some participants suggest that cleaning the windows or using a thick shampoo may alleviate the squeaking. The conversation highlights the potential for temporary relief through lubrication, but also the risk of long-term damage to the window mechanism if not addressed properly.
