Which washing machine to choose LG, Samsung or Bosch?
zabcia963 31635 16
Which of these washing machines is the best choice for saving energy and water?
If you want the best pick from this list, choose the Bosch WAN2829EPL Serie 4. It was recommended as the strongest option among the five because Bosch was considered better than the competitors, and this model has a 1400 rpm spin speed [#19204686] One reply also noted that saving energy and water usually means longer cycle times and a greater tendency to fail, so efficiency has a tradeoff with convenience and durability [#19202349]
  • #1 19201685
    zabcia963
    Hello. I am thinking of buying a new washing machine. With my husband, we found a type, but we cannot decide which one will be the best. Sometimes they don't differ much, so it's hard to make a decision. In a washing machine, we want to save both energy and water. The programs are not important because probably one basic one will be used all the time. We've had a top loading washing machine until now, but it's slowly breaking down and we're thinking of one of these.
    Our types:
    1. LG Vivace V600 F4WN608S2
    2. LG Vivace F4WN408S0
    3. Samsung WW80TA026AT
    4. Bosch WAN2829EPL Serie 4
    5. Bosch WAN2428EPL Serie 4
    Any of you have one of these washing machines? How about their efficiency and savings?
    Maybe you have any other suggestions?
  • #2 19202349
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    It does not go hand in hand with the utility value. The more economical the washing machine, the longer the cycle times will be and the greater the tendency to fail. Physics can't be beat.
    From the typed washing machines, I would definitely take this one:
  • #3 19204005
    zabcia963
    [/ quote]
    Thanks for the help. But if you can, why this Bosch? Has something that those don't have?
    Because they are all in a similar price range and differ only in some functions and the brand.
    Bosch recommended for 1400 rpm spin speed
    #4 19204686
    mrice
    Help: 2213
    Rate: 6951
    Bosch, because I think it is better than the competitors, and this model because of the 1400 rpm centrifuge.
    In my opinion, Bosch still fares better than the competition. Of course, this is my private opinion formed by my professional experience and there will surely be people who disagree with me on this issue. Nevertheless, if I was told to choose from among these five, I would take position 4 without hesitation.
  • #5 19204858
    zabcia963
    Thank you very much for your help, I think I'm already related to this washing machine. I read the feedback about Bosch early on in the forums and it was really positive so I think it will be a good choice too.
  • Recommends Bosch model 4 with 1400 rpm spin
    #6 19215770
    czarny_alibaba
    Help: 5
    Rate: 151
    What model of Siemens washing machines you recommend to PLN 1400-1700
  • #7 19219367
    Piotr2608
    Help: 851
    Rate: 4487
    No, for this money you can buy a corpse, not a Siemens washing machine.
    You need to spend at least PLN 2,500 on Siemens. Let's say then it will be ok.
    Siemens is doing bulldozing and packing leftovers in these cheap washing machines - is vigorously preparing for the entry of the directive.
    ZimTech Piotr Zimny
  • #8 19222465
    czarny_alibaba
    Help: 5
    Rate: 151
    Which Bosch - Siemens model can you recommend?
  • Load capacity applies only to cotton programs
    #9 19222475
    Piotr2608
    Help: 851
    Rate: 4487
    Something in this series:
    - Siemens WT47RTE0PL iQ500
    - Miele WCA030 WCS ACTIVE
    - Miele WSA023 WCS ACTIVE
    - Bosch WAT2876SPL
    Before you buy a washing machine, think carefully about how much you wash, what you wash, how you wash and how much you wash.
    the maximum washing machine load is only for the cotton program, for the others, only half the load.
    Miele is more of a curiosity about the price of washing machines up to approx. 2.5 thousand. zloty.
    The principle on the market is simple - who buys cheap, buys twice. With a thoughtful purchase of a washing machine,
    an extended warranty is not needed.
    ZimTech Piotr Zimny
  • Serviceability and parts matter more than brand or price
    #10 19222590
    Wr841nd
    Help: 14
    Rate: 82
    Piotr, if you would visit Siemens, then ... Bosch?
    But how ? Well, yes .. (in PL it even goes down from the same line) the example of Siemens IQ100 is Bosch Classix. Siemens A10 / 12 is Bosch Maxx
    Washing machine price as a determinant of durability? Maybe 20 years ago it is, but today?
    Miele? This is a myth and not a permanent washing machine ... Yet when there was a cast iron cross, the fact was impossible to kill ... Today? Aluminum ... And the 10-year-old with a broken cross has already seen (find out what the prices are, you will turn a little pale)
    Today you have to look at:
    Ease of service: a disassembled tank (how many 3-year-old washing machines are there to be sealed and the bearings get, and the glued tank is scrap because the repair costs are high)
    Availability of parts including 2 hands / washing machine.
    Part unification (e.g. WAE cross fits Siemens A series)
    And the less fancy wifi / nfc / couple / the better.
    The washing machine has to work, not to dance and sing.
    Mrice: 1400 rpm and 800 is only a few% of residual moisture less and:
    The laundry is not swept out of the dog's throat.
    The service life of the washing unit increases.
    Of course, there are more errors that cause washing machines even for 3,000 people.
    If it wasn't for the fact that there was a washing machine user for PLN 800 .. she put a ton of powder and rinse liquid, I would wash in it until today and today the washing machine would be 16 years old, and the cross was turned off after 12 years and despite the fact that Removable washing machine, you would have to buy an inner drum with a combined cross for PLN 400 (the repair is not very profitable) but the cross itself did not exist, and if it was for PLN 120, I would not just think about it.
    And spending more than 1300 for a washing machine is ok, I don't defend it ..
    But you can buy 1 for 2500, which will last for about 10 years, and I will buy this one for 2 500 and I have 20 years of use ..
    Or even 3 piles. And even when it falls, I have 3 new art for the same price as you spent on one ...
  • #11 19222615
    Piotr2608
    Help: 851
    Rate: 4487
    You are wrong, and you are very wrong. I'm not going to get you out of that belief.
    There are foreign technologies at Siemens from Bosch.
    It's like comparing a Skoda or VW to a Porsche or Audi - it's also a VW concern.
    ZimTech Piotr Zimny
  • Bosch and Siemens share many same components
    #12 19222675
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1068
    Motors, drain pumps, heaters, washing drums, shock absorbers are the same. The controller is different and the washing logic. I have Elektrolux time Manager 6kg and when some idiot did not stick to the tank instead of twist and for God's sake he used some better quality sealant, I do not want another washing machine. 10 years and perfect washing.
  • #13 19222700
    czarny_alibaba
    Help: 5
    Rate: 151
    Piotr2608 wrote:
    There are foreign technologies from Bosch at Siemens.
    In your opinion, which is better to invest in?
  • Bosch and Siemens differ in repairability and motor faults
    #14 19222723
    Piotr2608
    Help: 851
    Rate: 4487
    People want to buy cheap and it is killing the industry ...
    Someone will buy a corpse for PLN 1,500 out of fear, will buy a 5-year guarantee and pay PLN 2,300.
    Whatever corpse he buys, he will wash it.
    Now I had a client with an 18-year-old Siemens, the display was dead. A washing machine 18 years ago cost 4 thousand. zloty
    that is over 4 minimum wages. Today you buy Siemens for one and you still need a vacuum cleaner.
    Looking at the quality of this Siemens for 1.5 thousand. PLN that it would be technologically equal to the old one - the new one would have to be
    cost about 9 thousand. zloty. At this price, we have:
    - quality
    - profitability of repair
    - less rubbish in landfills
    Added after 15 [minutes]:
    Currently, if I had to choose, I would buy Siemens. Different washing culture, the drive motor works differently.
    He does not work for BSH or for BSH. Currently, the simplest equipment under repair - as someone understands the operation of the BSH group equipment.
    In cheap Boschach drive motors melt. In the higher models of Bosch or Siemens this fault is missing,
    after despite (as a colleague Mierzejewski46 stated), they are the same engines.
    ZimTech Piotr Zimny
  • #15 19222817
    czarny_alibaba
    Help: 5
    Rate: 151
    This model is a Washer Dryer?
  • #16 19222871
    Piotr2608
    Help: 851
    Rate: 4487
    I was wrong - I gave you a dryer model instead of a washing machine.
    e.g. WM14UR00PL
    ZimTech Piotr Zimny
The discussion revolves around selecting a washing machine among LG, Samsung, and Bosch models, specifically the LG Vivace V600 F4WN608S2, LG Vivace F4WN408S0, Samsung WW80TA026AT, Bosch WAN2829EPL Serie 4, and Bosch WAN2428EPL Serie 4. Users express a preference for Bosch due to its perceived reliability and efficiency, particularly highlighting the 1400 rpm centrifuge of the Bosch WAN2829EPL. Concerns about energy and water savings are raised, with some users noting that more economical machines may have longer cycle times and higher failure rates. The conversation also touches on the importance of ease of service and the availability of parts, with a general consensus that investing in quality is preferable to purchasing cheaper models that may not last. Suggestions for Siemens and Miele models are also mentioned, but Bosch remains the favored choice among respondents.
TL;DR: Shortlist Bosch WAN2829EPL for its 1400 rpm spin; "better than the competitors" at this price, said a pro. [Elektroda, mrice, post #19204686] Why it matters: If youre comparing LG, Samsung, and Bosch for efficient, reliable washing, this FAQ turns forum expertise into clear picks and practical buying checks.
Which washer should I pick: LG, Samsung or Bosch?
From your shortlist, pick Bosch WAN2829EPL Serie 4. The expert chose it for its 1400 rpm spin and brand track record. "I would take position 4 without hesitation." If you value efficiency and serviceability, this model balances both. Verify dimensions and delivery access before purchase. [Elektroda, mrice, post #19204686]
Do energy- and water-saving washers have longer cycles or more issues?
Yes. Greater efficiency targets often extend cycle times and can raise failure tendency. "Physics can't be beat." Expect longer runtimes with eco-focused designs. Offset risks by choosing proven brands and avoiding unnecessary complexity. Plan your washing schedule around longer programs. [Elektroda, mrice, post #19202349]
Is 1400 rpm spin really worth it over 1200 or 800?
The dryness gain from 800 to 1400 rpm is only a few percent. Lower spin speeds are gentler on fabrics and bearings. Very high speeds can stress the wash unit. Balance faster drying against wear and fabric care. [Elektroda, Wr841nd, post #19222590]
What Bosch model did the thread recommend?
Bosch WAN2829EPL Serie 4. It was selected for its 1400 rpm spin and perceived reliability compared with similarly priced LG and Samsung picks. Confirm local parts and service support before buying. [Elektroda, mrice, post #19204686]
How much should I budget for a reliable Siemens washer?
Aim around PLN 2,500 or more. At PLN 1,400700, an expert called options a "corpse," not comparable to higher lines. Paying more improves build, repairability, and lifespan potential. Consider total cost of ownership, not just sticker price. [Elektroda, Piotr2608, post #19219367]
Are Bosch and Siemens basically the same inside?
Many components are shared. Motors, pumps, heaters, drums, and shock absorbers can be identical. The controller and wash logic differ. That affects behavior, options, and user experience more than core hardware. [Elektroda, Mierzejewski46, post #19222675]
Why might someone still choose Siemens over Bosch?
An expert would currently pick Siemens for washing behavior and motor control. He warns cheap Bosch models can have "melted" drive motors. Higher Bosch and Siemens tiers avoid that fault, even with similar motors. Check the series level before deciding. [Elektroda, Piotr2608, post #19222723]
Is Siemens WT47RTE0PL a washer-dryer?
No. Thats a dryer. The corrected front-load washer shared was Siemens WM14UR00PL. Always verify product type and series before ordering. [Elektroda, Piotr2608, post #19222871]
Is Siemens WM14UR00PL at about PLN 2,199 worth shortlisting?
Its a 9 kg, 1400 rpm, A+++ washer that a user found around PLN 2,199. Those specs fit many family needs. If the price and warranty suit you, add it to your shortlist. [Elektroda, czarny_alibaba, post #19222909]
How do I choose the right capacity and programs?
Start with your laundry volume and fabric types. The rated maximum load applies to cotton cycles. For synthetics and mixed cycles, plan roughly half load.
  1. Estimate typical kilograms per load.
  2. Map to the cotton rating.
  3. Halve for non-cotton programs. [Elektroda, Piotr2608, post #19222475]
Do I need an extended warranty if I choose well?
Not necessarily. "With a thoughtful purchase, an extended warranty is not needed." Buy on quality, not only on price. The goal is a machine you wont need to insure heavily. [Elektroda, Piotr2608, post #19222475]
Are smart features like Wi-Fi worth paying for?
Prioritize core performance and serviceability. "The washing machine has to work, not to dance and sing." Simpler machines are often easier and cheaper to fix. Extra features can add complexity without cleaner clothes. [Elektroda, Wr841nd, post #19222590]
What should I check for serviceability before buying?
Look for a split tank so bearings are replaceable. Check parts availability and whether components are shared across models. Avoid glued tubs; a bearing failure can make a three-year-old machine uneconomical. Simpler designs tend to outlast complex ones. [Elektroda, Wr841nd, post #19222590]
Do older premium washers really last longer?
One reported case: an 18-year-old Siemens only needed a display repair. The expert argues newer budget units arent equal to that build. The older unit originally cost over four minimum wages. Durability often follows original quality and repairability. [Elektroda, Piotr2608, post #19222723]
