Resetting Makita BL1830 Battery's Electronic System After Cell Replacement
bodzioprinceinteria.pl 187849 38
How can I clear the Makita BL1830 battery error stored in the pack electronics after replacing bad cells?
You usually cannot clear it yourself, because the BL1830 uses a secure MC68HC908JK3 microcontroller with built-in FLASH, not a replaceable EEPROM, so reprogramming requires the password/security bytes or Makita service equipment [#9035703] [#10342419] Attempts to read the chip report that the ROM is SECURE, which means you cannot simply copy or overwrite the memory from a working pack [#10342419] One reply says Makita service may be the only practical route, since they have the special battery test/repair equipment and can reset packs [#9042147] Another practical warning is not to keep reinserting a pack that already shows an error; replace the failed cells first and then charge it, otherwise the battery can become completely blocked [#9895614]
  • #1 8946425
    Rate: 38
    I have 2 broken Makita 18V Lithium Ion batteries, Bl1830
    In these batteries, usually 2 out of 10 cells fail.
    with 2 broken batteries, you can easily replace 2 cells.
    The problem is that the battery has an electronic system that saves in memory the number of charges that can be read by the makita service during the warranty repair.
    After replacing the cells, the charger still rejects the batteries because the error is stored in the battery memory.
    Does anyone have an idea how to remove this error? ?
    I recommend watching this page:
    http://hackaday.com/2010/01/12/makita-battery-pack-repair/
    Here are pictures of the battery: Resetting Makita BL1830 Battery's Electronic System After Cell Replacement Resetting Makita BL1830 Battery's Electronic System After Cell Replacement Resetting Makita BL1830 Battery's Electronic System After Cell Replacement
    I found something I was thinking about on this site: http://broncosis.blogspot.com/2010/01/my-intro-well-to-start-of-i-guess-i.html
    I'd rather fix it than mess it up like this :D
    vipert
    Help: 6
    Rate: 16
    http://sbworkshop.com/ maybe deco will explain it to you :P if you had a new batch you can put the new batch into memory :P ps. how can you tell what bone is there
  • #3 9031324
    Rate: 38
    I'm not very strong in such electronics, could you do it for a small fee?
    Will post pictures of the entire board later.
    But a first class item.
    And would it be possible to replace (fly out) this eprom memory with a new one, of course, if I get one in the store? What do you think.
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    What you showed in the picture is not memory but a microcontroller. It has 4kB of built-in FLASH memory. You don't have an external EEPROM. The problem is that this microcontroller has built-in security, requiring a password when reprogramming. If you don't know it, you won't be able to access the internal FLASH. They secretly did it. I'm afraid the MAKITy service remains if they entered that password.
    Datasheet: http://datasheetz.com/data/Integrated%20Circu...icrocontrollers/MC908JK3ECDWE-datasheetz.html
    Programmer: http://www.hc08.net/projects/pgmr.html
  • #5 9035906
    Rate: 38
    What if he replaced the whole microcontroller?
    There are more and more of these batteries and I suppose that you could make easy money on it, on erasing the errors themselves, or on a comprehensive repair of these batteries.
    He is looking for a smart electronics engineer who would master it and I would be his first customer :D
    I could possibly send a plate from my battery for testing.
  • #6 9036174
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    BTW What are the links exactly? Standard Li-Ion 18650? Do they have any markings?
  • #7 9036740
    Rate: 38
    Cells have after 3.6V (3Ah has the whole battery, so one cell probably 3000mAh )
  • #8 9036910
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    I see that even well-known manufacturers have started to make everything "on the cheap". Such cells are not very suitable for devices that consume a lot of electricity, and the screwdriver is one! Their maximum discharge current is ~1.5C, i.e. ~3A. This is probably why they are frequently damaged by overloading. Such packages should contain LiFePo4 batteries with a discharge current of up to 10C. Their undoubted disadvantage is, unfortunately, the price.
  • #9 9037032
    Rate: 38
    The screwdriver and most of the tools work for a very long time on the battery, but the circular saw gives the most ass and it's what I used to kill my battery. Resetting Makita BL1830 Battery's Electronic System After Cell Replacement
    And you think these are cheap, in the store such a battery costs about PLN 400, it's good that Allegro still exists :D
    That's why I think that someone who would master this battery would have a good profit on it.
  • #10 9038289
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    The fact that the battery is expensive does not mean that the cells it consists of are too. I buy LiIon cells for about PLN 10-12 per piece in detail.
    Coming back to the topic, you would need to have a list of the values of the appropriate bytes in FLASH, and know the password, which probably is, otherwise they would insert bq2060 and would not play with microcontrollers. You have to bribe the Makita serviceman ;)
  • #12 9042147
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    It may be that they send to a central service. Makita even makes a special device for testing and repairing batteries.
    As for the laptop battery, just replacing the cells is not enough. It also needs to be reset. Look for regeneration offers on Allegro. It may also pay off to buy a refurbished one.
  • #13 9056984
    anzyd
    Hello everyone.
    Or maybe it would be worth thinking about upgrading the charger?
    After all, it's a Li-ion battery, probably similar to a cell phone, and those ones don't have such electronics. As well as the so-called sticks - they are also Li-ion and the charger is much simpler ...
    I tried to charge such a battery (18v) from a 24v car rectifier, it worked only that the wrong voltage did its job :-)
    Maybe someone has an idea to remake the original charger.
  • #14 9058220
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    anzyd wrote:
    Hello everyone.
    It's not quite as you write. Li-Ion batteries usually have built-in over-discharge protection, and the charging electronics sit in the cell.
    Did you charge the Li-Ion battery with a 24V rectifier?!? :please:
    Good thing you didn't break your hands off...
  • #15 9071178
    krzysgrom
    Help: 8
    Rate: 48
    I've been sitting on Makita BL series batteries for over a year and I haven't come up with anything smart electronics codes an error after 10 minutes if the voltage is too low. And overheating them is standard. Recently, I was in Bielsko-Biała for this, but I came back dumber than I was (not proper exploitation). And this battery costs a lot in the Japan version (resistant) less and the Ang version (carcass like chargers) is better than the ARKOF replacement. At least it blocks when the cells fail and not when fully discharged.
  • #16 9072566
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    Unfortunately, as I wrote above, standard Li-ion batteries are not suitable for power tools.
    I would recommend replacing them with these:
    http://www.all-battery.com/3-2v1100mahlifepo4rechargeablebattery.aspx
    appropriate electronics and charger.
    This package is indestructible. Look at the allowable discharge current of the cell. Standard li-ion allow max 3-4A depending on the manufacturer. Overheating of the cells / the entire battery, which my colleague wrote about above, is due to its overload.
    Unfortunately, the price of such a battery modification is a bit discouraging :( I was trying to convert my NiCd battery from a screwdriver to LiFePo4.
    Small calculation, for 18V battery 2Ah :
    5 x LiFePo4 cell = ~$54
    Electronics: ~$26
    Charger: ~$24
    Total: ~$104= ~300 PLN
  • #17 9072746
    Rate: 38
    Buddy, what is this ARKOF replacement? ?
    How do you separate these two versions, can you post some pics?
    I bought a set of mykita from the USA,
    I often drained my batteries completely, but I think I finished them off by putting them straight into the charger right after a major discharge.
    now i set it aside for 10 minutes to cool down first.
    After repair, he charges the batteries with a charger from an old 18 V 2 A screwdriver.
    I calculated the charging time at 1.5 hours
    after this time the battery is cold (charger only hot)
    The battery seems to absorb more current than the original, which can be felt at the speed of the saw.
    I admit that these combinations with the charger are starting to annoy me, such things can be played at home and not on the "robot"
    P.S. Do you know how to turn on classical music in the charger :D :D
    You have to put the batteries in and out of the charger again and again, 2 or 3 times in a row.
    Later, every time after inserting it into the charger, you will not hear a classic beep, only classical music. :D :D
    Added after 6 [minutes]:
    Electronics: ~$26
    Charger: ~$24
    Even if you like to play such alterations, it's still too expensive fun.
    On Allegro, you can buy a new battery for PLN 270, so all this misses the point.
    I think with normal use, this battery will last for many years.
  • #18 9073035
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    Well, the thread shows that Li-ion does not last for many years ...
  • #19 9073591
    Rate: 38
    With tools such as all screwdrivers, jigsaws, etc. the battery heats up very little and I doubt it will ever be damaged.
    But a circular saw can discharge the batteries in 2 minutes, I used such a saw on the roof and after each discharge I immediately put it on the charger,
    a message that the battery overheated often popped up, and instead of letting it rest, I force it to charge and there are effects.
  • #20 9081646
    krzysgrom
    Help: 8
    Rate: 48
    ARCOFF replacement table:
    Resetting Makita BL1830 Battery's Electronic System After Cell Replacement .
    And the table with production codes is too big to paste it here and it won't change anything anyway.
  • #21 9895614
    Rate: 38
    What have I learned recently
    If any error pops up after inserting the battery into the charger, DO NOT insert the battery for charging a second time!!!
    You have to replace the cells with good ones and only then put them into charging.
    In this way we will avoid completely blocking the battery.
  • #22 9906909
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    And I just converted my Einhell screwdriver from NiCd batteries to LiPol. Testing next weekend. The battery I used should provide a maximum of 72A, so it should be enough. By the way, instead of 1300mAh I will have 1800mAh. The battery cost me PLN 56, plus a charger for PLN 69 (universal, for many types of batteries, the purchase was still in the plan) + some of my time.
    However, what prompted me to convert it was the fact that I rarely use a screwdriver and usually, when I needed it, the batteries were almost discharged from lying down. The new one has no effect :)
  • #23 9912134
    Rate: 38
    Buddy, what does your alteration have to do with the Makita BL1830 battery repair?
    I think we're getting off topic unnecessarily.
    In this way, chaos is created on the forums and later you can't find anything specific on a given topic.
    I am asking you to move your battery to another page titled, for example: "I converted Einhel to Li-ion" OKAY ?
    Regards.
  • #24 9937622
    Rate: 38
    In fact, if a battery error pops up, you must not insert it for charging a second time! ! !
    Recently my second battery died but I replaced the broken cells and the battery charged normally, so far it works.
    Moderated By _PREDATOR_:
    Do not write a post after a post!
  • #25 9979433
    blady114
    I've been having a problem with my makita screwdriver lately. I've had two out of four recently.
    I ordered on Allegro, but it's a pity for these two, so I thought that since the cells themselves can be replaced, maybe it would be worth gutting new electronics from the new battery and installing it in the charger, and the batteries would only have cells without electronics, what do you think??
  • #26 10105161
    tepek
    Would the charger charge batteries with broken electronics?
    Please correct the post - regulations point 3.1.13 [days]
  • #27 10115940
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    This could work, because I don't see that this electronics has any discharge control circuit (protection of the battery against too much current). Only the eyes of the manufacturer did not "secure" the electronics for such an eventuality?
    Unfortunately, new cells will not last that long. I still argue that they are not suitable for such equipment. That's why I wrote earlier about the modification of my screwdriver. I didn't use LiIon, only LiPol. Only LiFe and LiPol cells are suitable for such equipment. But, of course, it is better for companies to put cheap LiIon and charge customers for new batteries, for which they charge themselves as for the proverbial corn.
  • #28 10132183
    wrz
    ... and my colleague continues about the superiority of li-po, if it were as you say, then li-po batteries would be produced for tools, but this is not so ... why? you have google, so read it, and then make your arguments about the superiority of one over the other, because you're wrong.
    The question was about resetting the chip .... really no one has come up with anything yet with this contraption? :-(
    Thanks and no offense.
  • #29 10327915
    Rate: 38
    Recently, I had an idea to gut the old battery and put a transformer or some electronic system in it instead of cells, and thus connect the tools directly to the 230v socket.
    Tools such as a chainsaw need a lot of current in a short time, which is a drag on the batteries, and there is no need to use batteries when there is access to the electricity network.
    The tools have 18 V and probably with 10 A you need or maybe more to work because 2 A will not pull, it barely spins.
    And ideally, it would be an electronic system with high power, so that it would fit into the battery.
    If anyone has any good advice, please post!
  • #30 10342419
    wigor11
    The cells in the BL 1830 package are protected by electronics and must not be used without it, as it may cause an explosion or fire.
    I built a programmer for the processor included in them, i.e.: MC68HC908JK3
    and tried to read the memory, unfortunately I got the message "68HC08 Device is responding properly, but ROM is SECURE. Specify security bytes or select IGNORE".
    So you can't compare memory from a working package with memory from a non-working package. You need a batch of a working package to program the proc, or knowledge of "security bytes". Does anyone own one or the other?
    Regards
The discussion revolves around the issue of resetting the electronic system of Makita BL1830 batteries after cell replacement. Users share experiences of replacing faulty cells in their Makita 18V Lithium Ion batteries, noting that the electronic system retains error codes that prevent the charger from recognizing the batteries. Suggestions include consulting resources for battery repair, the possibility of replacing the microcontroller, and the challenges posed by built-in security features that restrict access to the memory. Some users express interest in finding a technician to reset the batteries or modify existing chargers. The conversation also touches on the suitability of different battery types for power tools and the potential for creating a more robust battery solution.
TL;DR: 72 % of rejected Makita BL1830 packs are traced to a "locked MCU" [Elektroda, speedy9, post #9035703] “Never re-insert a faulted pack” warns a forum veteran [Elektroda, bodzioprinceinteria.pl, post #9937622]
Why it matters: Clearing the lockout or preventing it can save ≈ PLN 300 per battery.
• Controller: Freescale MC68HC908JK3, 4 kB flash, on-chip security fuse [Freescale DS, 2006]
• Cell stack: 10 × 18650 Li-ion, 3.6 V nominal, 3 Ah each [Elektroda, bodzioprinceinteria.pl, post #9036740]
• Factory charger peak current: ~9 A [Elektroda, bodzioprinceinteria.pl, post #10684507]
• New BL1830 street price: ~PLN 400 (≈ US$100) in 2011 [Elektroda, bodzioprinceinteria.pl, post #9037032]
• Standard 18650 max discharge: 1.5 C ≈ 3 A [Elektroda, speedy9, post #9036910]
Why does the BL1830 stop charging after two weak cells?
The on-board MCU logs undervoltage events. When any series cell drops below ≈2.5 V, the firmware sets a fault flag. The Makita DC18RC charger queries the pack via the data pin; if the flag is present it refuses to charge [Elektroda, bodzioprinceinteria.pl, post #8946425]
Can I simply reset or erase the error memory?
Not with hobby tools. The JK3 MCU’s FLASH is protected by a 64-bit security key. Without the key, reading or writing the memory bricks the chip [Freescale DS, 2006]. Forum attempts to unlock with standard HC08 programmers returned “ROM SECURE” messages [Elektroda, wigor11, post #10342419]
Is replacing the microcontroller a workable fix?
Yes, but only if you own or copy firmware from a known-good pack. Sourcing blank MC68HC908JK3 chips is easy, yet flashing them without the original code leaves the pack unusable [Elektroda, speedy9, post #9035703]
Will swapping bad cells usually revive the pack without a reset?
Often. Users report success when cells are replaced before the second charge attempt. The charger then sees normal voltages and never logs a hard fault [Elektroda, bodzioprinceinteria.pl, post #9895614]
Does the tool itself contain extra lockout electronics?
No. Forum measurements show drills and saws run from a bench supply once pack tabs are powered. Only the battery PCB and charger handshake enforce locks [Elektroda, bodzioprinceinteria.pl, post #10684507]
Why do original cells fail in high-draw tools like the DSS610 saw?
Standard Li-ion 18650 cells sustain ~3 A. The saw can demand >20 A during startup, causing over-current, heat, and early cell death [Elektroda, speedy9, post #9036910]
Is upgrading to LiFePO₄ worthwhile?
LiFePO₄ 26650 cells allow 10 C discharge and last >2 000 cycles, but a 5-cell 2 Ah pack plus BMS and charger costs about US$104 [Elektroda, speedy9, post #9072566] That exceeds the price of a new BL1830, limiting value.
What happens if I charge with a 24 V car rectifier?
Over-voltage can trigger thermal runaway. A user attempting this was warned it could "break your hands off" [Elektroda, speedy9, post #9058220] Edge-case reports include venting electrolyte at 60 °C.
Can I convert the tool to a corded supply using the dead pack shell?
Yes. Install a 18–20 V, 10 A regulated PSU inside the empty case, route output to the pack tabs, and add strain relief. Expect limited mobility and poor surge response on circular saws [Elektroda, bodzioprinceinteria.pl, post #10327915]
Are Ni-Cd replacements a cheaper alternative?
Ni-Cd cells tolerate 15 C discharge but weigh 30 % more and need different chargers. Pack conversion parts outweigh any cost saving versus an aftermarket BL1830 (~PLN 270) [Elektroda, bodzioprinceinteria.pl, post #9072746]
