Maximum Length for Twisted Pair Cable for LAN Output Between Two Routers
Bracket 18686 16
How long can an Ethernet twisted-pair cable be when connecting two routers in a home network?
An Ethernet twisted-pair link can be up to about 100 m if you use a properly made cable and terminations [#9070140][#9070861][#9082414] For a two-floor home run, that length should normally work without problems [#9070147] Use a decent cable, ideally real copper Cat5e or better, because poor-quality aluminum/steel cables can fail even at shorter distances [#9070861][#9070526][#9082414] One user reported a 30 m link working after re-terminating an old UTP cable, which shows that the cable condition and plugs matter as much as the distance [#9086048] If you need much more than 100 m, the thread suggests fiber as the practical alternative [#9070861]
  • #1 9069998
    Bracket
    I want to connect the network at home to a second router 2 floors below. (WLAN does not reach)
    At what length of twisted pair cable can be used for LAN output?
    Brack.
  • #2 9070140
    bogiebog
    Help: 2569
    Rate: 1530
    100m
  • #3 9070147
    Wafer
    Help: 29
    Rate: 59
    If a good cable (read 100% copper) then from what I remember up to 100m.
    In any case, 2 floors will work for sure without any problems, even on a poor quality twisted pair.
    Greetings.
  • #4 9070526
    wajsxy
    Level 19  
    Help: 31
    Rate: 32
    I once bought 50m of copper cable, connected two apartments and how surprised I was that the network does not work,
    why we reprimanded to find what is wrong, I called the store to ask if maybe the cable is of poor quality,
    the seller claimed that he had from a verified source and is of very good quality,
    only by accident we noticed that a piece of broken wire stuck to the magnet,
    I scraped the longer piece with a knife and it turned out that under the top layer of copper sits a normal steel wire,
    I thought that the dung in the store I will smash, the same day the guests from the store connected two apartments with a new real copper cable.
  • #5 9070547
    T.O.M.M.Y
    Rate: 123
    For two floors it will definitely work as my colleague wrote earlier twisted pair up to 100 meters then the signal fades at my longest link was 90 meters and it worked without any problems
  • #6 9070861
    blues
    At what length of twisted-pair cable can be used for LAN output?
    Brack
    Cat.5e cable when done correctly, according to the standard, the ends should safely pull 100m. More you will not normally get.
    at one time 3Com declared on its equipment with cat.5 cabling maximum range of 300m, but after some time they withdrew from this, because there were problems with it. Nevertheless, if you need that much range you can try to strike in that direction (3Com 905 for example).
    And preferably fiber optic. These days it's no longer expensive equipment, and you get any range you want in practice.
  • #7 9070876
    piterus99
    Help: 1084
    Rate: 328
    Don't be so forward with the light anymore - you need to buy 2 mediaconverters and what's most troublesome - the right length of cable with the ends made. Now if you have a twisted-pair cable, even with a hammer and screwdriver you will tighten it, the light even requires skillful laying.
    On the cable you will also let go 1Gbps over such a distance. It is less cumbersome for connecting two floors than light, so let's not exaggerate.
  • #8 9071030
    blues
    piterus99 wrote:
    Don't be so forward with the light anymore - you need to buy 2 mediaconverters and what is most troublesome - the right length of cable with the ends made. Now if you have a twisted-pair cable, even with a hammer and screwdriver you will tighten it, the light even requires skillful laying.
    On the cable you will also let go 1Gbps over such a distance. It is less troublesome for connecting two floors than light, so let's not exaggerate.
    No exaggeration - I use fiber optics every day and once laid it is much less problematic than copper. With copper always something happens and only with it I practically have problems.
    True that making the ends is problematic, but just order a patchcord of the right length with even a large margin, because the distance matters less here. It does not cost more than copper.
    Problems with laying? you need the same as with copper to be careful not to bend.
    And converters? new cost 100/pc - you can buy used much cheaper, especially multimode.
    There is no need to be afraid of fiber optics, it is a simple technology.
  • #9 9071827
    Wafer
    Help: 29
    Rate: 59
    ...a colleague asked for 2 floors and a piece of twisted-pair cable, and ended up with +300m and 1Gbit fiber. :crazyeyes: .
  • #10 9072685
    blues
    Wafer wrote:
    ...a colleague was asking for 2 floors and a piece of twisted-pair cable, and ended up with +300m and 1Gbit fiber optic cable. :crazyeyes:
    One time - he did not specify the parameters. I had 2 floors that together with the corridor had 90m of line length after a lot of combinations on how to shorten the line, so...
    Two - he got the full details of what he asked and an alternative solution.
    Three - gigabit is currently _very_ cheap, so why not use it?
    Therefore I don't understand where these comments come from....
  • #11 9072697
    witux
    Help: 390
    Rate: 252
    At what length of twisted pair cable can I use the LAN output?
    Brack
    Look at Link .
  • #12 9072733
    blues
    witux wrote:
    See Link .
    Fine table - just out of obligation I will mention that for fiber optics the distances given and the legend to them are nonsense. Standard distances are much larger.
  • #13 9072751
    witux
    Help: 390
    Rate: 252
    I didn't mean fiber optics.
  • #14 9082414
    recki-quadra
    Help: 16
    Rate: 59
    According to the standards, the maximum distance is about 100 meters (I do not want to look for it exactly, but I think it was 93 or 97 meters?) in practice, I have even seen sections coming quite close to 200 meters - packet losses varied, but for "home" use it was not very troublesome, for sharing the Internet it worked well. As the previous speakers wrote - it is important to give good cards and, of course, at least a decent cable (on the market is a mass of aluminum cable - copper - this one is not even decent)
  • #15 9086048
    Bracket
    May I speak up(I finally started a topic)
    Thanks for all the replies.
    Distance I had to connect -30m.
    Cable I had UTP - but already a bit old (some 10-12 years).
    No contact. I 'rewound' the cable, there is a transition. Once again I cut the plugs carefully tightened - it works. Three more Lan's to the computers
    After a hard day, the network works.
    Next time I will buy a new cable (preferably FTP).
    Greetings.
  • #16 9086463
    dozowacz
    Copper rusts and does not have the same conductivity, and on top of that the storage conditions also do their part, well that's okey.
  • #17 9087548
    blues
    dozowacz wrote:
    copper rusts and does not have such conductivity and on top of that storage conditions also do their own thing ,well that already okey.
    Not only that - 10-12 years is the outer coating is already hard and brittle (unless the twist was once from a really top shelf and adapted to outdoor conditions).
The maximum length for twisted pair cable (such as Cat.5e) used for LAN connections is generally accepted to be 100 meters, with some users reporting successful connections up to 200 meters under specific conditions. Quality of the cable is crucial; 100% copper cables are recommended to avoid issues with signal degradation. Users shared experiences of using older cables and the importance of ensuring proper connections. Alternatives like fiber optics were discussed, highlighting their advantages in terms of distance and reliability, although they require more careful installation and additional components like media converters. The discussion emphasized the need for good quality cables to ensure effective network performance, especially over longer distances.
