Maximum Ethernet Cable Length: Internet Cable Limits & 20-25m Considerations
Turbo.Arek 28587 7
  • #1 11453620
    Turbo.Arek
    Rate: 26
    What is the maximum length of the internet cable? Is 20-25m too much?
    predom
    Help: 84
    Rate: 64
    The standard provides, as far as I remember, 100m. But with bad cables, it can also be a problem with 50m.
    electro_Nick
    Help: 218
    Rate: 203
    If someone sells such a cable, why should it not work? Yes, it will be good, but you haven't even written what you want to connect with it.
  • #6 11453694
    Turbo.Arek
    Rate: 26
    I would like to connect the Internet (from the router) to the N TV set-top box
    predom
    Help: 84
    Rate: 64
    It should work, although PLN 0.55 / m is a suspiciously low price ...
  • #8 11453741
    Turbo.Arek
    Rate: 26
    I see. Thanks.
The maximum length for Ethernet cables, according to standards, is typically 100 meters. However, issues can arise with lower quality cables at lengths around 50 meters. A 20-meter Ethernet cable is generally considered acceptable for connecting devices, such as a router to a TV set-top box. Concerns were raised about the low price of a specific 20-meter cable, suggesting that quality should be verified before purchase.
