Maximum permissible crossover cable length for direct Ethernet card-to-card connection
prez8s 45551 15
What is the maximum permissible length of a crossover Ethernet cable for a direct card-to-card connection?
A crossover Ethernet cable has the same maximum permissible length as a normal Ethernet cable: about 100 meters [#3664596][#3664944] The standard cited in the thread says 96 m for the permanent link plus 4 m for patch panel and user connections [#3665054] Longer runs may sometimes work in practice, but they are outside the standard [#3665054]
  • #1 3664549
    prez8s
    Help: 69
    Rate: 334
    I have a question, I can't find anywhere, what is the maximum permissible length of a crossover cable in the connection between two network cables?
  • #2 3664596
    Platon
    Help: 744
    Rate: 170
    Same as uncrossed.
  • #3 3664944
    PICIA
    Help: 185
    Rate: 248
    about 100 meters
  • #4 3664984
    turbolover
    Rate: 13
    The length of the twisted pair / rj45 / ethernet: I have experience with efficient networks with a length of about 300 m (cables soldered several times along the way) and works at 100 Mbp / s :D . Only four wires are enough, by the way, save money!
    Application:
    theory = theory
    practice = practice
    theory ? practice :!:
    Moderated By jankolo:
    I punish my colleague with a WARNING for writing out obvious nonsense
  • #5 3665054
    adikbo
    Help: 77
    Rate: 37
    In fact, standards are made to be broken! Why follow the recommendations of manufacturers and guidelines of standardization organizations !! After all, they are thieves and tricksters !! The standard specifies 4 pairs in a twisted pair, but two are enough - why buy more expensive cables?
    Following your line of reasoning - why buy a Mercedes? Toddler rides too !!
    The Ethernet standard allows 96 meters for a uniform connection + 4 meters for connections in patch panels and user connections.
    adikbo
    PS. The first two paragraphs are hypocrisy - the knife opens in your pocket when you read such "tips".
  • #6 3665106
    prez8s
    Help: 69
    Rate: 334
    Exactly, because I have a problem with edimax network cards, it is crap unmerciful, if the cable is longer than 20m, there is no connection, they do not even see each other, but on other power cables it is ok, those built into motherboards are already heaven better. Do not buy this crap, in the store they cost about PLN 16 / item, shit it is unmerciful. I am talking about it: http://www.proline.com.pl/shop.php?prodid=EDIMAX+EN-9130TXL
  • #7 3665679
    elektronik321
    Help: 29
    Rate: 51
    These 4 pairs of wires are used in 1Gbits networks where there must be 8 wires, and in 2 pair networks, if something happens with one wire, you can replace it with unused pairs. building new network 100 mbits / suddenly everyone goes to 1 gbits you have to cut walls to replace all cables
  • #8 3665763
    starob
    Help: 128
    Rate: 137
    elektronik321 wrote:
    if something happens with one used wire, you can replace it with unused pairs
    Of course, the whole pair is not just one strand.
  • #9 3665854
    turbolover
    Rate: 13
    There was no gigabit only about 100Mbps. 2 pairs are enough without any problem. This "swapping" is just nonsense. For what? As she was already alive, it is possible, but the probability is extremely low!
    I do not agree with the warning, I am writing about what I know. I have been working with networks for several years and I do not wish criticism from the theoreticians. The fact that a colleague is a moderator does not mean that he knows everything about everything. A little humility towards practitioners!
  • #10 3665895
    Elektryk80
    Help: 89
    Rate: 61
    I agree with the previous speaker. He also works on building a network, I connect buildings and I know that 100m is not the limit! Of course, with a cable of poor quality, there is no need to combine it with lengths (sometimes even 60m or less are losses), but the devices also need good parameters. I know that the 8-port "Compex" switches connected to the 8-port with each other with the "madex" cable work flawlessly even on the 170-180m section.
    4 pairs in a twisted pair are a good solution because on one cable you can easily run two computer stations, or in the event of failure of one pair or even two, you always have a spare two more and you do not need to replace the cable.
  • #11 3666372
    prez8s
    Help: 69
    Rate: 334
    and I do not agree with the previous speaker, the topic is about crossover cables, I checked and the 4-core cable is not suitable, there are errors, packets are lost, maybe in straight cables it will be ok, but not in crossover cables.
  • #12 3668170
    marian1977
    Help: 12
    Remove the twisted pair insulation (and possibly the shield in ftp) on the 10m cable, unroll the special cables so that they all go straight, pinch the ends, you will see if it will walk. I guess it's normal that 100m is a deprecated value, but let's not exaggerate. Turbolover can be seen for a really nice couple of years you've been in the networks since you write the Mbp / s unit.
  • #13 3668336
    prez8s
    Help: 69
    Rate: 334
    So you want to say that usually untwisted wires will be ok? Boshee, people like you do in networks, give it a rest, because then they will have to correct you for you and you will make a laughingstock for yourself. Although I do not start a network, I have the appropriate professional qualifications and I have experienced a bit with networks, so that I can write such fucking, to develop a twisted pair, it does not fit in my head :O . Try using such a "cable" to play a video stream, for example a divix .... All you need to do in a good quality cable is mistake the wires when crimping and you will have transmission errors !!!!!!!!!!!!!!!!!! much less unwinding the twisted pair :O This is the laugh in the room :D :D :D
  • #14 3668393
    woogoo111
    Rate: 17
    And I will agree and disagree ... at the same time !!!!
    I agree that the theory does not coincide in practice, and I will not agree with breaking the standards.
    Not that someone writes this "nonsense" to stretch and rip the money (although probably also), but probably also to guarantee any quality, reliability and compatibility. So what if the net will become unusual, on 300m, or on one pair. In five years, something will "shake" and even the contractor himself will have a problem with finding the fault, not to mention someone who will have to rummage in such a structure after him.
    Granted, you can not use the standard, but I think you can't take responsibility in that case, and a little bit of information out there that something is unusual.
  • #15 3668791
    marian1977
    Help: 12
    prez8s wrote:
    So you want to say that usually untwisted wires will be ok? Boshee, people like you do in networks, give it a rest, because then they will have to correct you for you and you will make a laughingstock for yourself. Although I do not start a network, I have the appropriate professional qualifications and I have experienced a bit with networks, so that I can write such fucking, to develop a twisted pair, it does not fit in my head :O . Try using such a "cable" to play a video stream, for example a divix .... All you need to do in a good quality cable is mistake the wires when crimping and you will have transmission errors !!!!!!!!!!!!!!!!!! much less unwinding the twisted pair :O This is the laughter in the room :D :D :D
    I was hoping that intelligent people (not offending anyone) would browse this forum and understand that it was ironic, but oh well. And the comparison of the conversion of veins with the "unraveling" of the twisted pair in general threatens your way of thinking.
  • #16 3668821
    prez8s
    Help: 69
    Rate: 334
    I close the topic, you only make points with hopeless posts, soon you will write that you have a net on a string from a binder. Greetings.
The discussion centers around the maximum permissible length of crossover cables used for connecting network devices. The consensus suggests that while the standard length is approximately 100 meters, practical experiences indicate that lengths up to 300 meters can work under certain conditions, albeit with potential reliability issues. Some participants argue against strict adherence to standards, citing that two pairs of wires can suffice for 100 Mbps connections, while others emphasize the importance of using all four pairs for better performance, especially in gigabit networks. Concerns are raised about the quality of specific network cards, particularly Edimax models, which reportedly fail to maintain connections over longer distances. The conversation highlights the tension between theoretical standards and practical applications in networking.
