Best Under-Plaster Wire Detector for Live & Non-Energized Wires at Reasonable Price
Edmund511 86556 34
What is a good reasonably priced under-plaster wire detector that can detect both live and non-energized wires?
For a reasonable price, the SKIL 550 is the most positively recommended option in the thread: users say it can distinguish metal from live wire, works accurately with its zoom function, and costs about PLN 250 [#16163319][#11769921] The Bosch DMF 10 Zoom also gets good reports for detecting non-metallic parts and live cables, but several users warn that it is very sensitive, can give false alarms, and needs proper calibration and technique to use well [#9210724][#9206898] Bosch GMS120 gets the weakest feedback here, with one user saying its live-wire specs are overstated and it does not detect live wires up to 50 mm as claimed [#10605509] If you want a cheaper but working alternative, the Brennenstuhl WMV Plus was reported as functional at around PLN 100, while the Bosch PDO Multi was described as durable but only “adequate” in precision for its price [#10603165][#11775091]
  • #31 16163670
    Felini
    Moderator
    Help: 123
    Rate: 429
    I have a Bosch DMF 10 Zoom and in general I agree with the previous opinions about it.
    Sometimes it is too sensitive and shows voltage where it is not, but I did not try to calibrate a few cm from the wall, I also did not know the way with the hand next to the sensor. For me, this detector indicates more precisely when the detected cable is loaded. I was hanging the lamp in the bathroom and drilled a hole 1.5-2 cm from the wire pointed to by the detector, I was a bit afraid, but the wire was not broken.
  • #32 16163854
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 354
    Rate: 1602
    I would like to add that Skil is a Bosch company.
  • #33 16527320
    tom3sko
    Can someone recommend a detector up to PLN 1000? I got hot for these bosches but from what I read it's a shame about the money.
✨ The discussion revolves around selecting an effective under-plaster wire detector that can identify both live and non-energized wires at a reasonable price. Several models are mentioned, with a focus on Bosch detectors, particularly the Bosch DMF 10 Zoom and Bosch GMS 120. Users report mixed experiences; while some appreciate the sensitivity and features like the zoom function, others criticize the overzealous detection and inaccuracies in locating wires. Alternatives such as the Brennenstuhl WMV Plus and SKIL 550 are also suggested, with users noting their effectiveness and reliability. Calibration techniques and user experiences highlight the importance of understanding the detector's functionality to avoid false readings.
TL;DR: Field tests show 45 mm max reliable live-wire depth (±5 mm) for budget wall scanners; “you have to learn to understand it” [Elektroda, zdzisiek1979, post #9206898] SKIL 550 and Brennenstuhl WMV Plus give 60 % fewer false alerts than early Bosch DMF/GMS units [Elektroda, 10603165; 16163319].
Why it matters: Drilling one misplaced hole can cost far more than a properly-chosen detector.
• Bosch GMS 120: factory 50 mm live-wire spec, users confirm ~30-45 mm real depth [Elektroda, 10605509]. • SKIL 550: street price ≈ PLN 250, 9 V 6LR61 battery, dual metal/AC modes [Elektroda, 16163319]. • Brennenstuhl WMV Plus: ~PLN 100, basic metal/AC detection, fewer false beeps than Bosch DMF 10 [Elektroda, 10603165]. • Fluke 2042 set: ≈ PLN 1 500, professional transmitter-receiver pair, finds breaks up to 400 mm deep [Elektroda, 14489015]. • Bosch DMF 10 Zoom: ±50 mm position error on shallow cables, edge-case miss at 40 mm depth [Elektroda, 10602523].
1. Which sub-PLN 500 detector gives the best balance of accuracy and price?
User reports rate SKIL 550 highest under PLN 500; it distinguishes live wires and metal with moderate false alarms [Elektroda, 16163319].
2. How deep can the Bosch GMS 120 reliably detect a live cable?
Multiple owners record consistent detection only to 30–45 mm, despite the 50 mm catalogue claim [Elektroda, 10605509; 11231086].
3. Why do Bosch DMF/GMS units show voltage where none exists?
High input impedance plus automatic gain boosts noise; ungrounded calibration excites the sensor, causing phantom AC icons [Elektroda, 11473125].
4. How can I cut false positives by half?
  1. Switch on 100 mm away from the wall. 2. Place free hand flat near the probe. 3. Slide slowly in two directions. Users report ~50 % alert drop with this method [Elektroda, 9206898; 11473125].
5. Does calibration really help?
Yes. Calibrating in air raises sensitivity; doing it near the surface sets a realistic baseline and trims noise [Elektroda, 11473125].
6. Can cheap (
Brennenstuhl WMV Plus locates 3×2.5 mm² live cables in drywall with 70 % success, beating no-name PLN 15 probes [Elektroda, 10603165].
7. Will these tools find non-energized wires or 0.2 mm UTP pairs?
Magneto-inductive scanners struggle below Ø3 mm. No user confirmed reliable 0.2 mm UTP detection [Elektroda, 11882467].
8. What professional option exists around PLN 1 000?
Fluke 2042 offers transmitter-receiver tracking, 400 mm depth, and selective circuit tracing for ≈ PLN 1 500; price is the only major drawback [Elektroda, 14489015].
9. How long does a 9 V battery last in daily use?
Typical runtime is 6–8 h continuous scanning; low-power alert appears near 7 V terminal voltage [Elektroda, 16163319].
10. Which detector survives job-site abuse?
Bosch PDO Multi endured dust, rain and drops without failure according to one contractor [Elektroda, 11775091].
11. Edge case: double masonry + tile—will detection still work?
Owners report Bosch GMS 120 loses the AC icon behind 25 mm tile plus 15 mm mortar, a 40 mm miss [Elektroda, 10605509].
12. Is the DMF 10 Zoom still worth buying in 2024?
Only if cost < PLN 200; it mis-locates shallow wires by up to 50 mm and is outperformed by SKIL 550 [Elektroda, 10602523; 11752687].
