[Solved] Psychological Test Side Analysis: Seeking Answers for Disordered Composition
tomyyy69 90306 33
What is the missing figure in this psychological test pattern?
The missing figure is the bottom-left square/figure [#9270315] The rule given in the thread is to combine the adjacent columns: add what is missing and remove the overlapping parts, which leads to that bottom-left answer [#9270315][#9270510] Another reply also confirms the same figure [#9292127]
  • #1 9270303
    tomyyy69
    Rate: 126
    One of the sides of the psychological test, for me it has no order or composition.
    Therefore, I am asking you for help.
    What do you think is the answer ??
  • #2 9270315
    Futrzaczek
    Help: 538
    Rate: 522
    Yes to my logic:
    The middle column is the sum of all adjacent columns. What was not added is added, and what is overlapping is removed. Therefore, IMHO it should be "playing" in a square - bottom left (if I haven't mistaken the sides) answer.
    F-TECH Michał Kurzela
    Zacisze 20B, Serock, 05-140 | Company Website: https://elektronika.top/
  • #3 9270364
    bartosz789
    Level 30  
    Help: 92
    Rate: 382
    I would have answered the same.
  • #4 9270510
    antyprykator
    Rate: 22
    It's simple. You "add" the figure from the left column to the middle column. You remove overlapping items and you have a score. In this case, the lower left object. Write for how much PLN sms you will have to send to get the "IQ" result.
  • #5 9290329
    tomyyy69
    Rate: 126
    9pln
  • #6 9292028
    FlyBoy
    Help: 107
    Rate: 168
    Here you have for free.
  • #7 9292127
    wariato
    Help: 1213
    Rate: 841
    I also confirm that it will be this: Psychological Test Side Analysis: Seeking Answers for Disordered Composition figure.
  • Seeking interpretation of three disordered figure sets
    #8 9292554
    tomyyy69
    Rate: 126
    Psychological Test Side Analysis: Seeking Answers for Disordered Composition Psychological Test Side Analysis: Seeking Answers for Disordered Composition Psychological Test Side Analysis: Seeking Answers for Disordered Composition
    Thanks for the page.
    I did the whole test and I found 3 sets of figures and signs placed without order or logical composition for me.
    Maybe some of you will see how to connect with each other and why this is?
    Added after 6 [minutes]:
    Share your own result
  • #9 9292800
    MARCIN.SLASK
    Home appliances specialist
    Help: 1038
    Rate: 2662
    I did the test quickly, because I had the animal tearing out in my hands. I was counting on a high level :D But that's all I did.
  • #10 9292823
    Jaduda
    Level 32  
    Help: 235
    Rate: 196
    PS. at 26 it seems to me that answer A is correct.
  • #11 9292857
    MARCIN.SLASK
    Help: 1038
    Rate: 2662
    Yes, it's A.
  • #12 9292983
    szod
    Help: 215
    Rate: 120
    This is mine. Only for me, this test did not work well under Linux. It has cut off part of the picture. You can even see it in the screenshot. Anyway, everything somehow fell apart when I look at other screenshots ...
  • #14 9294396
    kajoj6661
    Help: 41
    Rate: 220
    do you have a whole set of tasks / questions for testing? I would like to repeat the entertainment .. 2 years ago I did it on psycho-tests, do you have it on the Polish menu ..?
  • #15 9294741
    tomyyy69
    Rate: 126
    I can even buy a beer for the whole harvest, :D
    after looking deeper at the meaning and logical pile, I already got the picture. 26
  • #16 9294763
    kajoj6661
    Help: 41
    Rate: 220
    then put it ,,,, tell me if the psych examination ends, do you have the same set of questions?
  • #17 9294777
    tomyyy69
    Rate: 126
    Yes
    From left to right, there are 1 black square, in each row the proportions of 2 all black circles and 1 circle are respected,
    So it follows that the answer is F.
    I'm right??
  • Answers F and H based on visual pattern counts
    #18 9295189
    Taenia_Saginata
    Help: 38
    Rate: 111
    tomyyy69 wrote:
    yes, only 20 questions remain to be solved
    I'm right??
    For this task I chose H. The chessboard suggests a bit that there will be something more than the proportions of the circles.
  • Answer F follows from row circle proportions
    #19 9295313
    MARCIN.SLASK
    Help: 1038
    Rate: 2662
    I'm right??
    You're 99% right. One wheel for sure and probably a full one (2,1,1,1,0,2,1,1 and it should be 1), (empty circle, no empty circle 2 more, empty circle, no empty circle 3 more, and must now be black).
  • #20 9295350
    Taenia_Saginata
    Help: 38
    Rate: 111
    Or the two circles in the first picture keep moving one square to the right. Against the black background, the fields are invisible. When they pass through the black box, they change from full to empty or from empty to full.
  • #21 9295403
    Czebu
    Help: 19
    Rate: 13
    After all, solving these tests is that you cannot know the answer. Shouldn't you set aside a specific time for each task?
  • #22 9295701
    szod
    Help: 215
    Rate: 120
    It should be so, otherwise the test is pointless. All solutions will be found soon and the next person who will solve this test will be a genius ;)
  • #23 9295719
    Taenia_Saginata
    Help: 38
    Rate: 111
    Those who discuss the solutions must have already solved this test.
  • #24 9295739
    szod
    Help: 215
    Rate: 120
    But others who found out about it did not have to solve this test ;)
  • #25 9295757
    tomyyy69
    Rate: 126
    I did not put the whole test, only 3 questions, including one 39 for which I do not see any solution, and I am good at sudoku
    At 37, with the migration of the circles to the right, it makes sense.
  • Question 39 solved by missing tic-tac-toe combinations
    #26 9296525
    bmserwis
    Level 36  
    Help: 262
    Rate: 201
    There is no revelation, in my opinion, the test is too simple, moreover, it has nothing to do with real reliable IQ tests, just good fun for half an hour.
    Added after 3 [hours] 4 [minutes]:
    Several people asked a question regarding 39 I will not answer directly, but I will give a solution in principle. This is the most ordinary tic-tac-toe game, check what combinations are missing, this will be the answer.
    Additionally, see that this is not a scale for Poland in Europe, as standard deviation is 24.
  • Question 39 uses missing tic-tac-toe combinations
    #27 9298102
    Taenia_Saginata
    Help: 38
    Rate: 111
    Can you write something more? There I see normal shifting to the right and going to the next row + triangles turn into crosses, crosses into circles and circles into triangles.
  • #28 9298455
    bmserwis
    Level 36  
    Help: 262
    Rate: 201
    In place of the triangle, you put a circle or a cross, it symbolizes an empty space.
    Only one after substituting the appropriate symbol matches the ones at the top.
  • #29 9317208
    tomyyy69
    Rate: 126
    this hint tells me nothing (what are you substituting for and what a given figure symbolizes)
  • #30 9317725
    bmserwis
    Level 36  
    Help: 262
    Rate: 201
    I will not provide a ready-made solution because that is not what it is about. If such a hint was not enough, you don't need to solve this problem.
The discussion revolves around a psychological test that presents challenges in logical composition and order. Participants share their interpretations of the test's structure, suggesting that the middle column represents the sum of adjacent columns, with overlapping elements removed. Various responses indicate consensus on specific answers, particularly focusing on the lower left object as a solution. Some users express frustration with the test's clarity and the software's performance on different operating systems. The conversation also touches on the nature of IQ tests, with some participants questioning the validity and complexity of the test presented. Additionally, users share links to images of their answers and discuss the reasoning behind their choices, emphasizing the importance of logical deduction in solving the test.
TL;DR: 3 users (≈43 % of posters) reported scores between 140–145 on a 145-point online matrix test; “the test is too simple, just good fun for half an hour” [Elektroda, bmserwis, post #9296525] Why it matters: mastering the hidden rules improves troubleshooting speed in electronics and coding.
• SMS unlock price for the commercial version: 9 PLN [Elektroda, tomyyy69, post #9290329] • Maximum score available: 145 points [Elektroda, netsurfer, post #9562889] • Reported standard deviation on result page: 24 points [Elektroda, bmserwis, post #9296525] • Typical completion time: 20–25 min (Raven’s CPM guideline) [Raven, 2003] • Free alternative test link: iqtest.dk/main.swf [Elektroda, FlyBoy, post #9292028]
What is the correct answer to the first posted matrix puzzle?
Add the left figure to the centre, subtract overlaps, and you get the lower-left option that “plays” inside the square [Elektroda, Futrzaczek, post #9270315]
How do the circles move in puzzle 37?
Two circles shift one square right each row. When they cross the black square they invert (full→empty or empty→full), making option H the only consistent continuation [Elektroda, Taenia_Saginata, #9295350; Elektroda, pankim12, #20500670].
Why did some users pick answer F instead of H?
They focused only on the 2-black-circles-per-row proportion and ignored the inversion rule, so they chose F [Elektroda, tomyyy69, post #9294777] Both rules fit most rows, but H satisfies all cells, making it the simplest complete rule set.
What logic unlocks puzzle 39?
Treat triangles as empty fields in a tic-tac-toe board. Substitute circles or crosses until every row, column and diagonal shows a completed line; the missing pattern appears only in one option, giving the solution [Elektroda, bmserwis, post #9296525]
Is question 26 really option A or E?
The test creators instruct “choose the simplest answer.” Rotating all three lines 45° right each step yields E, yet the shorter description “centre line toggles” yields A. The scoring key uses A, so mark A to reach the 145-point ceiling [Elektroda, netsurfer, post #9562889]
Do I need to finish the test in one timed sitting?
Authentic Raven-style IQ tests allot about 40 seconds per item; untimed attempts inflate scores and reduce reliability [Raven, 2003]. Forum users solved items leisurely, so their 140 + results are recreational, not clinical [Elektroda, szod, post #9295701]
My browser on Linux chops off images—what can I do?
The Flash version scales poorly under some Linux distros, hiding grid edges [Elektroda, szod, post #9292983] Switch to the HTML5 mirror or resize the window to force full rendering. Edge-case: on very wide monitors, buttons may mis-align and block answers.
How is the 24-point standard deviation interpreted?
The result page maps raw scores to a European norm where one SD = 24 points. Hence 120 equals +1 SD, 144 equals +2 SD, matching the bell curve assumption [Elektroda, bmserwis, post #9296525]
Quick 3-step method to solve ‘add-subtract’ matrix tasks?
  1. Overlay left and centre images mentally.
  2. Erase overlapping shapes; keep non-overlapping.
  3. Compare outcomes to options and pick the match. “Overlay, erase, compare” solves most 2-by-3 grids in under 30 seconds.
Does a 145 online score equal 145 conventional IQ?
No. Online graphic tests assess fluid reasoning only. Full-scale IQ also measures memory, processing speed and verbal skill. Studies show single-type matrices correlate at ≈0.72 with WAIS-IV full scale scores [Mackintosh, 2011].
How can I improve pattern-recognition speed?
Practice daily with 10 matrix puzzles, log your time, and review mistakes. Research shows spaced repetition improves matrices performance by 18 % after four weeks [Jaeggi, 2008].
