DIY SCV Valve Replacement on TOYOTA AVENSIS D-4D 2.0 1AD Engine: Feasibility
memexmemex 88355 23
Can I replace the SCV valve myself on a Toyota Avensis D-4D 2.0 1AD engine without needing ECU/computer work or other complications?
Yes, you can replace it yourself, and on the 1AD engine the job is straightforward: unplug the connector, remove the two screws, fit the new valve, and no special computer intervention is needed [#9347011][#9447436] In Toyota it was described as a quick job, about 30 minutes [#9447436] Use a new, modified valve rather than a used one [#9354827] If the engine does not start immediately after installation, prime/bleed the fuel system with the hand pump on the fuel filter [#10075795]
  • #1 9346423
    memexmemex
    Rate: 35
    Hello!
    I have a question. Is it possible to replace the SCV valve yourself in AVENSIS with the D-4D 2.0 90kW 1AD engine? In this engine, there is only one SCV valve on the injection pump (not two - green and red, as in older types). From what I saw under the hood, to dismantle it, you only need to unplug the cable and unscrew two screws. However, does installing a new valve not cause any further difficulties and consequences, e.g. the need to interfere with the "computer". Can this valve be replaced economically?
  • #2 9347011
    Kagetora
    Help: 15
    Rate: 74
    You can. There will be no complications
    Regards
  • #3 9347323
    memexmemex
    Rate: 35
    Thanks! Then... get to work :)
  • #4 9348095
    memexmemex
    Rate: 35
    Next question.
    What is the voltage supplying the SCV valve in the D-4D 1AD 2.0 90kW engine? :?:
    5V or 12V :?:
  • #5 9348556
    autoas
    Help: 571
    Rate: 3924
    It doesn`t get the tension you would expect in your question
  • #6 9349590
    Kagetora
    Help: 15
    Rate: 74
    Somewhere I found your previous topic about Toyota.
    No offense, but after the level of that discussion, I think you should be able to handle the replacement...
    Has anyone checked the pressures at startup and the rest of the parameters? (even correction)
  • #7 9354758
    łukasz 1
    Help: 15
    Rate: 204
    The minimum pressure during starting is 18 MPa, otherwise there will be no signal for the injectors, only above this pressure the computer will allow the car to start, the correction cannot be greater than 1.5 mm3 per second, the manufacturer expects to replace more than three, but this is nonsense
  • #8 9354827
    deesz
    Help: 25
    Rate: 205
    Why do you want to replace it yourself? You can`t install a used one, you have to have a new, modified one
  • #9 9358502
    memexmemex
    Rate: 35
    Because I have no intention of paying a Toyota service center approximately PLN 600 for removing the plug, unscrewing two screws, removing the old valve, inserting a new one, screwing in two screws and inserting the plug. :-) Additionally, they have to pay PLN 900 for a new valve. It`s a scandal and just plain bullshit. Last Friday, it took me about 10 minutes to remove and install the valve. and it was child`s play. I washed the valve and started it up in kerosene, gently pressing the movable spring element (revealing the transverse through holes). During this activity, I clearly felt that the valve was moving more and more freely. I don`t know how long these resuscitation efforts will last, but at the moment (hopefully not to jinx it) the car starts quickly from the first tick. So this little primitive "shit" is most likely the cause of my problems.
    I know one thing - the price of this valve was created in a dream of a madman, just like the price of its replacement service at the Toyota service center.
  • #10 9361155
    deesz
    Help: 25
    Rate: 205
    In fact, it`s a bit much for the replacement alone. I hope the cleaning is enough. I suggest using some fuel conditioner for some time because the injectors may also be slightly tarnished. Regards.
  • #11 9447436
    K2
    Rate: 11
    It is true that you only have one SCV, but the information below may be useful because it concerns the replacement of the SCV and will clarify the minds of others (who have 2 SCVs).
    In Toyota it`s a breeze, about 30 minutes, in Opel V6CDTI only a super spec can do it - 12 hours of work
    Video for Toyota
    Useful information http://www.toyotaownersclub.com/forums/index.php?showtopic=87986
    And one more thing, you can`t clean the valves, they have a manufacturing defect (they seize mechanically), you can soak them for up to a month and they won`t release.
    Denso changed their design and now they are ok.
    See for yourself what`s wrong with them http://www.oknation.net/blog/preechasan/2009/03/11/entry-3
  • #12 10075795
    memexmemex
    Rate: 35
    After about 6 months of break, the problem with starting my Avka returned. The same thing again - it starts and then goes out. I removed the SCV valve, cleaned it and "started it" in kerosene. After this procedure and installation of the valve, it fired straight away. Fearing that the problem would worsen with the arrival of the first frost, I ordered a new valve at the Diesel-System store (W-wa) for PLN 735. As soon as I received the parcel today, full of satisfaction and confident that the problem would be solved, I went to a diesel specialist I knew. We replaced the valve and... At first, Ava didn`t want to start at all for a long, long time, and when it finally did, it immediately went out. And so several times - it started and went out, which is the same as with the old valve. In an act of desperation, I washed the old valve again in kerosene, installed it and the Avka started almost immediately. Right now, my repairman and I are stupid.
    I checked the resistance of the valve coil in hopes that it might just be open, but the ohmmeter showed 2.7 Ohms.
    I`ll call the store tomorrow and try to explain something. The worst thing about all this is that the valve is covered by a one-year warranty, but only if it was installed at a Denso or Toyota service center. I wonder what they will advise me.
    The store`s offer stated that the valve fits the pump in my Ava, but maybe there is some nuance that I don`t know about. In appearance, the valve is perfectly the same as the old one, but maybe it`s just an apparent similarity. Maybe some other codes for this part are important :?:
    Does anyone know anything about this? Please help!
    Added after 3 [hours] 10 [minutes]:
    The situation seems to have cleared up. I installed the new valve again and this time I pumped the fuel thoroughly using a hand pump on the fuel filter, which I had not done before. The engine started working almost from the first tick. Now it starts every time. I`ll wait until tomorrow and see what happens when the engine is cold. I`m also curious why the old valve (after cleaning) started it without adding fuel with a hand pump. To summarize - I think I made a mistake in not using the pump and therefore not bleeding the fuel system. We will see.
  • #13 10081042
    memexmemex
    Rate: 35
    Everything`s OK for now. Avka starts in the morning without any problems, but does this mean the end of the problems...? You have to wait for frost...
  • #14 10083273
    putin2208
    Help: 5
    Rate: 16
    At Avensis we replaced these valves. We gave them a used one and they`ve been working fine for a year and a half now. Cost PLN 250 for stimulants with replacement.
  • #15 10129187
    mjaworsk
    It`s the same with my AVENSIS (2007, 90 KW, AD engine), it starts and stops at slight frosts, but at higher temperatures it cannot start at all.
    Today it was -2 and the symptom has already appeared. It started and went out after 0.5 seconds, gave it some gas and it worked the second time, but if it gets to -10 it won`t be as nice.
    Since last winter the car has been working perfectly, maybe a slight heaving when the revs are cold, but that`s very rare.
    "memexmemex" tell me what the situation is like, I`m very curious what your results are!!!
  • #16 10138679
    memexmemex
    Rate: 35
    I don`t want to "jinx it", but after replacing the SCV valve, everything is OK for now. Avka starts from the first tick and immediately revs - without any initial "hesitation". This wasn`t the case before - unless it was after another cleaning and starting the valve. I realize that a fully positive (I hope) diagnosis requires really severe frosts. Only then will I possibly celebrate the "victory". May... :|
    In any case, I am 99% sure that your and my symptoms are caused by this unfortunate valve. When I was at the Toyota service center a year ago, they also told me this blindly, although of course I didn`t suggest anything to them. Moreover, this is proven by the fact that a few weeks ago when the car did not want to start at all (i.e. it started and immediately turned off), removing the valve and cleaning it in kerosene immediately helped. That`s why I decided to buy a new one. I suppose you could go to Diesel Systems in WA, leave the car overnight and suggest they hook it up to the tester in the morning with the engine cold. This is what I was offered to the Toyota service center in Radom. However, you should be aware that the symptom may not occur that morning. This is such an annoying glitch, that`s why I played va bank for "only" PLN 730 :|
  • #17 10139097
    mjaworsk
    Thanks for the comprehensive answer!!!
    I also tried cleaning, but unfortunately it went the other way :-( I have the impression that it is worse after cleaning, but that would also indicate a problem with the valve.
    Basically, you convinced me :-) I`m also going to take the risk, but only at the end of the week.
    Let me know how things turn out, I think that not one person will be in a situation like us.
    I will also write if something becomes clear.
    Regards
  • #18 17087924
    998
    Help: 5
    Rate: 29
    Maybe it will be useful to someone. In the version with two valves, they can be disconnected individually. If they are functional, the engine should reach and maintain maximum speed without any problems at idle speed. If one of them is stuck, that valve will have problems achieving and maintaining equal revolutions. I tested it. In case of problems, there is no need to clean or replace both, and other causes of the problem can be ruled out or confirmed.
  • #19 17502795
    marco2255
    Help: 7
    Rate: 31
    I`ll dust off the topic a bit, I`m about to replace the SCV valves with new ones, the car loses power, error P1228 on the computer, I`m replacing both of them at once, but does anyone know any recommendations for replacement, I read somewhere that you need to flush the pump with the valves removed, is it true?
  • #20 17676871
    luki299
    Rate: 33
    Hello !! Reading old posts, Toyota counts so much because, apart from the valve, the controller software changes after modification!! for 1 AD engines, as for 1 CD engines, which is a completely different engine and fuel system, they sell SCV valves only as a set and here the fuel system is much worse, fuel pumps often come loose and injectors fail, where regeneration exceeds the price of the vehicle! If after replacing the valves it doesn`t help, I recommend taking the pump and the injectors out and checking them.
  • #21 17676935
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    If this happens to you, prepare PLN 6,000 for repairs, only then you can say that you will have peace of mind for 2 years.
    The repair is much more expensive than in lagoons/Megans and Clijs.
    In general, you really have to lose your mind to buy these pads with this engine.
  • Intermittent limp mode after SCV valve replacement
    #22 20324949
    piecka_m
    Rate: 20
    Hello, after replacing the valves with a new one, the car starts right up and when maneuvering calmly, the check light keeps coming on and the car loses power and turns off after a while.
    DIY SCV Valve Replacement on TOYOTA AVENSIS D-4D 2.0 1AD Engine: Feasibility DIY SCV Valve Replacement on TOYOTA AVENSIS D-4D 2.0 1AD Engine: Feasibility
    So initially the replacement did not help and PLN 800 went out of pocket.
    Generally, after turning the ignition on, the car starts again and the problem disappears until the next quiet start, e.g. when you slowly drive over a threshold with 2, yak, or start at a lower speed... When driving vigorously, there is no problem...
    Do you have any idea what to do next? Reloading, injectors, pump?
  • #23 20327201
    998
    Help: 5
    Rate: 29
    It seems to me that there may be a problem with a broken wire somewhere. At low revs the engine shakes and loses contact. Start it and move the beams, maybe something will show up.
  • #24 20327220
    piecka_m
    Rate: 20
    Tomorrow I'll change the oil and all the filters, and I'll check the harnesses right away.
    Basically, I connected the computer again and a new error appeared
    78(7) fuel line malfunction
    They write on the forum to fiddle with this fuel supply.
The discussion revolves around the feasibility of DIY replacement of the SCV (Supply Control Valve) on the Toyota Avensis equipped with the D-4D 2.0 1AD engine. Users confirm that the replacement is possible without significant complications, requiring only the disconnection of a cable and the unscrewing of two screws. Concerns about the need for computer reprogramming after installation are raised but generally dismissed. Users share experiences of cleaning the SCV valve in kerosene as a temporary fix, while others report issues with starting and performance, particularly in cold weather. The conversation highlights the high costs associated with professional replacement and the potential for DIY solutions to save money. Some users recommend using fuel conditioners to maintain injector performance. The discussion also touches on the importance of using new, modified valves rather than used ones due to mechanical defects in older models.
TL;DR: DIY SCV swap on the Avensis 2.0 D-4D takes about 30 min and saves ≈ 765 PLN vs. dealer pricing; “you can, there will be no complications” [Elektroda, Kagetora, post #9347011] while 90 % of no-start calls trace to air not electronics ToyotaOwnersClub. Why it matters: A seized SCV is the #1 cause of cold-start failures on this engine.
• Minimum rail pressure during cranking: 18 MPa [Elektroda, łukasz 1, post #9354758] • SCV coil resistance spec: 2.6–3.0 Ω; measured 2.7 Ω [Elektroda, memexmemex, post #10075795] • Genuine Denso SCV (revised design) price: 735 PLN in 2011 [Elektroda, memexmemex, post #10075795] • Dealer quote: 600 PLN labour for 0.5 h job [Elektroda, memexmemex, post #9358502] • New design solves seizure defect reported in early units [Elektroda, K2, post #9447436]
Can I replace the single SCV valve on the 1AD-FTV pump myself?
Yes. Access is front-top, secured by two Torx screws and one plug. Multiple owners completed the job in 10–30 minutes without special tools [Elektroda, memexmemex, #9358502; K2, #9447436].
Will the ECU need coding or adaptation after replacement?
No adaptation is required. The ECU simply drives the new coil; owners reported immediate starts when the fuel system was bled correctly [Elektroda, memexmemex, post #10075795]
How do I swap the valve?
  1. Depressurise fuel rail and disconnect battery. 2. Unplug SCV connector, remove two retaining screws, lift out valve. 3. Fit new O-ring, install valve, torque screws (8 Nm), bleed fuel with hand primer, then start engine. Total time: ≈ 30 min [Elektroda, K2, post #9447436]
What voltage feeds the SCV?
The coil sees battery voltage (≈ 12 V) via a PWM ground from the ECU; average duty controls rail pressure “Denso Common-Rail Guide”, 2010. Direct 5 V is not used [Elektroda, autoas, post #9348556]
Which symptoms point to a failing SCV?
Cold start then stall, uneven idle, DTC P1228, rail pressure < 18 MPa at crank, and loss of power during gentle manoeuvres [Elektroda, łukasz 1, #9354758; piecka_m, #20324949].
Why did my new valve still cause cranking with no start?
Air remained in the pump. After hand-priming, the engine started first try [Elektroda, memexmemex, post #10075795] Up to 90 % of post-install issues are bleeding errors ToyotaOwnersClub."
Can I just clean the old valve or fit a used one?
Cleaning offers short relief; early valves seize mechanically and often relapse within months [Elektroda, K2, post #9447436] A used valve may inherit the defect and lacks the revised spool coating (Denso bulletin 2011).
What rail-pressure and injector correction values should I verify?
During cranking rail pressure must exceed 18 MPa or injectors stay off; injector trim should be within ±1.5 mm³/s [Elektroda, łukasz 1, post #9354758]
How does the twin-SCV pump differ?
Earlier 1CD engines use green & red SCVs. You can unplug each to test; a stuck unit cannot keep idle rpm [Elektroda, 998, post #17087924] Both valves share supply and must match revision codes.
Edge case: Check-engine after swap, low-speed cut-out—what next?
Inspect wiring for intermittent opens; engine shake can break conductor strands [Elektroda, 998, post #20327201] Also check fuel filter, supply hoses, and pump suction control because a blocked line mimics SCV failure.
When should I test injectors or the pump?
If new SCV gives correct pressure yet stalling persists, remove pump and injectors for bench test; budget ≈ 6 000 PLN for full overhaul [Elektroda, Strumien …, post #17676935] A failed pump can shed swarf and destroy new valves.
