Toyota Avensis t25 2.0 D4D 116 HP Hard Start, Rattling Noise & Jerking after Injector Regeneration
Matyjass16 14043 5
  • #1 17083559
    Matyjass16
    Level 4  
    Rate: 24
    I have a problem with my Toyota 2.0 D4D 116 HP engine. It had regenerated injectors, all 4 and replaced glow plugs. After repair, it burns hard, at first start, you hear a rattling noise for a few minutes and the engine jerks. After a few minutes, everything stabilizes and the next time it starts up, it's fine. What could it be? The mechanic said that this can happen after regeneration. Please help.
  • #2 17096337
    dawidk153
    Rate: 16
    Have the washers on the returns been replaced when replacing the injectors? There may be a leak in the fuel system and the fuel is backing up, but the injectors may be badly regenerated, and what happened, that the injectors were regenerated?
  • #3 17097575
    Matyjass16
    Level 4  
    Rate: 24
    At 160 km / H, it caused trc off errors, the check lighted up and the car did not respond to gas after restarting it, it was driving, but the errors were lit. The rubbers were replaced, the car works fine, only the first start is heavy and throws the engine for a few minutes, then everything stabilizes
    And fuel consumption increased to somewhere 1l per 100km
  • #4 17099878
    dawidk153
    Rate: 16
    I would connect the computer and check the corrective doses on the injectors, I bet on badly regenerated injectors, or if there is something wrong with at least one, it will cause uneven work for several minutes.
  • #5 17099948
    Raywood
    Help: 5
    Rate: 16
    After replacing the injectors, were they coded in the ecu? They are about correction codes.
  • #6 17100304
    dawidk153
    Rate: 16
    I clearly wrote not about coding but about correction doses on transfers, you have to look at the computer, but as the mechanics of the one who exchanged these injectors does not have a computer or does not know how to check it, you have to go to another one.
