Avensis 2.2 D-Cat 2005 Power Drops, No ECU Errors, ESP light, Slow Turbine Pressure, Fuel System
cardoctor 18915 19
Why does my 2005 Avensis 2.2 D-CAT lose power intermittently with no ECU fault codes, slow turbo pressure rise, and an ESP warning?
In the thread, the car was ultimately fixed by replacing the ECU, which stopped the intermittent power loss and the no-error condition [#17621362] Before that, people suggested checking the DPF differential-pressure hoses/lines and the hose behind the filter, because the exhaust pressure signal can cause this kind of behavior [#17620731] Another suggestion was to inspect the thin vacuum line near the intake/EGR control sensor and the swirl flaps, since a cracked line can cause intermittent limp behavior without codes [#21833154] A similar Avensis case was also cured by replacing the fuel filter, so that is worth verifying if it has not already been ruled out [#17617058]
  • #1 16166260
    cardoctor
    Help: 20
    Rate: 183
    Car from 2005 130kW. He came to me with a problem of power drops. I diagnose him with a carman. At first it goes ok as cold (the owner said that not always). After light heating, when I take gas and add it, it has a total power drop. ESP lights up which in errors tells to check the engine but no errors in ecu. Parameters if there is no strength and I keep pressed the pedal into the floor is max.pmp pressure fuel, turbine pressure increases slowly from 1300mbar to 2000mbar but the car does not drive. When the car has strength, the turbine at 2150mbar captures up to 2000mbar. 145Mpa fuels. Egr clean. Throttle walks lightly. When driving with silted and pressed gas, sometimes something gives him a bounce and goes like a rocket, but just declutch and change gear and already lime. The car had a dpf dumped six months ago, physically and electronically. Since then, the customer has not had problems until now. I suspect the denso cr3 fuel system on piezaki. (Filling valve in the pump, control on the rail or injection) I am surprised by the lack of errors in ecu. What do you say?
  • #2 16173762
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    It seems, however, that the EGR is jamming, treat with spray oil, you will see the effect.
  • #3 16174767
    manta
    Help: 463
    Rate: 1533
    Do you have an emulator or soft?
  • #4 16174814
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    How EGR clean can it blinded?
  • #5 16175046
    MobilTruck
    Help: 139
    Rate: 965
    If it is blinded it will be a bug (checked).
    On the other hand, in the 2-liter E1CD, I had a bug that generated after a few days. To be sure, close the valve and drive over, as it will be normally continuous, you have the reason.
    I had the same behavior as yours, after replacing EGR with a stimulant the problem stopped.
  • #6 16175293
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    In 2.0 l D4d 1CD-FTV ECM does not "see" the blinded EGR.
  • #7 16175316
    MobilTruck
    Help: 139
    Rate: 965
    He sees and I can prove it in my free time.
  • #8 16175989
    lugi666
    Help: 17
    Rate: 158
    Or maybe an error table has been thrown on DPF :)
    Unpin the flow or other sensor and see if the error will generate
  • #9 16176555
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    In that case, my car has a dumber computer, which is very good for me.
  • #10 16176856
    MobilTruck
    Help: 139
    Rate: 965
    Or removed from the table of errors. Corolli Verso, after blinding signals an error.
    Maybe there is actually other software.
  • P2002 after DPF delete causing limp mode
    #11 17609227
    Launch78
    Help: 22
    Rate: 162
    Hello, today I got the same problem with a car that was dumped FAP a year ago by a company that deals with it and they are great professionals, everything was ok I got the org batch I uploaded it and it emits error P2002 Particulate trap efficiency below threshold BANK1, the car behaves like in the post above , it loses power and it recovers. what colleagues have already mentioned in other workshops, a new EGR org, a second induction pump, these activities did not help, the barbell from the turbine works smoothly, if someone has already done such a defect, I am not sitting in Toyota, so I prefer to ask.
  • #12 17614196
    lugi666
    Help: 17
    Rate: 158
    Do you have differential wires connected?
  • #13 17614242
    Launch78
    Help: 22
    Rate: 162
    yes, weżyki stapled with differential
  • #14 17615505
    lugi666
    Help: 17
    Rate: 158
    Then unplug the one behind the filter and check
  • #15 17617001
    Launch78
    Help: 22
    Rate: 162
    I have already unhooked the tubing before, there was no change, the tubes are unobstructed
  • #16 17617058
    marek0712
    Level 19  
    Help: 26
    Rate: 114
    I have such an Avensis at home, in that year he began to jerk, mulch, sometimes as cold and there were cold freezing symptoms. . Due to the fact that this is my wife's car, I rarely drive it, but after a year of jerking I drove it for a week and immediately something did not play for me with 180km left 90km, that's an impression. First, I changed the fuel filter and it was a shot in 10, now the car is whirling as before.
  • #17 17617065
    Launch78
    Help: 22
    Rate: 162
    previous workshops have already replaced all Filters with new ones.
  • #18 17620731
    lugi666
    Help: 17
    Rate: 158
    I don't know if we understand each other well. The point is for the differential to see some pressure on the exhaust. Therefore, connect the hose before the DPF and the other into the atmosphere
  • #19 17621362
    Launch78
    Help: 22
    Rate: 162
    Yesterday I replaced the ECU and everything is ok, I got a hint from the service that it was the same problem and the ECU was to blame and in my case it turned out to be the same. Thank you all for valuable advice
  • Cracked vacuum line near EGR causing intermittent power loss
    #20 21833154
    Bppitbull
    Hi, cardoctor to my eye, check the swish flaps, or at the intake manifold there is a thin vacuum line going to the control sensor (can't remember what exactly anymore - sclerosis). It is located near the EGR, it is connected by this hose, I had the same symptoms, it turned out it was cracked and sometimes the car drove normally and sometimes it got a yob, then it didn't give any errors. If there is a fault with this sensor, it will throw errors, but this is not necessarily Toyota - it does what it likes
The discussion concerns a 2005 Toyota Avensis 2.2 D-CAT with intermittent power loss, ESP warning, no ECU fault codes, slow turbo boost rise, and unstable fuel pressure under load. Initial suspicions focused on EGR sticking, DPF/FAP deletion or software changes, differential pressure sensing, vacuum hoses, intake flap control, and fuel system issues in the Denso CR3 common-rail system. Suggested checks included EGR blocking, sensor and hose inspection, differential pressure line verification, fuel filter replacement, and ECU/software evaluation. The reported fix was replacement of the ECU, after which the vehicle returned to normal operation.
