How to turn off subtitles for the hearing impaired
Taadeek 94364 8
  • #1 9376566
    Taadeek
    I have a UPC cable, for a few days I have had subtitles for the deaf on TVP1, TVP2 and TVN (digital). I have no idea how to turn them off. I changed teletext pages and nothing. I have a one-year-old child whose favorite toys are a set-top box and a remote control, I suspect he set something up. I am asking for help, because it irritates me terribly.
  • #2 9376637
    Hucul
    Help: 382
    Rate: 470
    They do not write anything about this in the user manual of the TV and set-top box?
  • #3 9376683
    Taadeek
    I don't know, I wasn't looking. These instructions are buried somewhere, I figured that maybe someone had already had a similar problem and it would be faster.
  • #4 9376845
    Hucul
    Help: 382
    Rate: 470
    Certainly, these instructions can be found on the Internet in pdf format and the fastest way to download and read them.
  • #5 9438802
    ziben21
    Also today I was looking for an answer to this question and I found it in the instruction manual of the remote control for the decoder ... press the "i" button and at the bottom there are options to choose Polish sound most often you can change to Polish dolby digital, for example, and below the subtitles option is Polish by default, we change the lack and the annoying subtitles disappear;] My first post, I hope I helped
    Moderated By Pablo1964:
    I give a warning for forcing points for help.
  • #6 9452648
    ziben21
    I have no idea what these points are, I was looking for an answer to this question and registered here because I found the answer myself, I wrote about it that the next one like me was easier and there is an oftop because someone littered my mailbox with a warning I have points somewhere, I want to find an answer as soon as possible to my question, but I prefer to look rather than ask questions, I may be banned because after such an approach it makes you no longer want to help
    Please correct your spelling. [Pablo]
  • #7 20596641
    piotr1429
    In turn, in the decoder for digital terrestrial television (I do not remember the name now) I turned off the subtitles for the hearing impaired in TVP INFO by entering the MENU I searched for > Polish sound and changed (other languages appeared in turn ... until I found the inscription > OFF and the subtitles for the hearing impaired disappeared. Regards
  • #8 20596707
    r103
    Level 37  
    Help: 283
    Rate: 968
  • #9 20596868
    darts
    Help: 5
    Rate: 8
    And you r103 at least helped in this topic? Because somehow I don't see, and you criticize. There are those who visit old topics and find out after a long time how the problem was solved - that is, not in two days. It happens sometimes that it lasts. For you - Wooden spade. To be buried.
The discussion revolves around how to disable subtitles for the hearing impaired on digital channels TVP1, TVP2, and TVN using a UPC cable set-top box. Users suggest checking the user manual for instructions, which may be available online in PDF format. A specific solution involves pressing the "i" button on the remote control to access audio options, where users can switch from Polish subtitles to "OFF" to eliminate the subtitles. Another user mentions navigating through the MENU on the decoder to find and disable the subtitles option.
