Polsat Evobox decoder - after switching off the decoder the time disappears
fotosing 12057 6
  • #1 16778489
    fotosing
    Rate: 20
    I have a problem, because after turning off the decoder after about a minute it turns itself off, the hour disappears and that's it. To run it, it must reinitialize. How to change that? The indicator from red changes to white. Standby / sleep in the settings menu is automatic ...
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Change the power saving mode setting
    In the Settings / User Settings / Energy saving menu set QUICK START.
  • #3 16778855
    fotosing
    Rate: 20
    Thank you. I'll do it soon. I will write back tomorrow in the morning.
  • #4 16779451
  • #5 16780234
    fotosing
    Rate: 20
    Thank you, netTv helped me, because even from the polsat service in this hole where I live, they urged me to replace the decoder and this one is already the 2nd of the same company. Everything works so far. The hour does not disappear. As for the menu, it is in Polish but the instruction manual is very modest. If there was something in this topic, I would read it.
  • #6 16780795
    netTv
    Level 32  
    Help: 193
    Rate: 579
    I recommend the SUBSCRIBER AREA menu to your attention and then HELP
  • #7 16781190
    fotosing
    Rate: 20
    Thanks for the advice, but I don't cut myself in because my wife is the Subscriber and only this defect disturbed me ... :)
The discussion revolves around an issue with the Polsat Evobox decoder, where the time display disappears after the device automatically turns off. A user seeks a solution to prevent the need for reinitialization upon powering it back on. A helpful response suggests changing the power saving mode to "QUICK START" in the settings menu. The user later confirms that this adjustment resolved the issue, and they express dissatisfaction with the lack of comprehensive instructions, particularly in Turkish. Other users recommend exploring the Subscriber Area menu for additional help.
