No Sound Issue with Cyfrowy Polsat, Pioneer VSX-930 Receiver, and Samsung UE55MU7042 TV Setup
PiotrMikler 8955 18
Why does audio from the Cyfrowy Polsat decoder disappear when the Pioneer VSX-930 receiver is connected to the Samsung UE55MU7042 TV via HDMI, and how can it be fixed?
The problem was resolved by replacing the Cyfrowy Polsat decoder; the replacement EvoBox decoder worked correctly through the Pioneer receiver and Samsung TV over HDMI [#17710760] Another report describes similar HDMI picture and sound-routing problems that disappeared after the decoder was exchanged [#17707777] Before replacement, an optical-to-coaxial converter provided a working workaround for sending the decoder’s audio to the receiver [#16951891]
  • HDMI handshake issue when TV is connected
    #1 16949457
    PiotrMikler
    Help: 5
    Rate: 24
    I warmly welcome
    My problem is that I don't have sound from Cyfrowy Polsat connected to the Pioneer Receiver. The connection diagram looks like this:
    Polsat HD7000 Digital Decoder ------ HDMI Cable ------- Pioneer VSX-930 Receiver ----- HDMI Cable ------ TV Samsung UE55MU7042
    With this connection, there is no sound in the receiver. With the previous TV (Also Samsung) everything was ok!
    I also have Pioneer BluRay connected to the receiver and the sound is normal.
    When I unplug the cable connecting the Receiver and TV, the sound of Cyfrowy Polsat appears normally in the speakers ... When you plug the cable back into the TV, the sound disappears ... This happens on all four HDMI inputs on the TV. All HDMI-CEC and ARC options are off !!
    I am asking for help because I have no idea ...
    I know I can use the optical output on the TV but this is the last resort. I would like it to work like on the previous TV.
    Regards
  • #2 16949519
  • #3 16949581
    Polon_us
    Help: 1184
    Rate: 1280
    Polsat decoder doesn't have any HDMI-CEC settings?
  • Polsat decoder still has no sound over HDMI
    #4 16949708
    PiotrMikler
    Help: 5
    Rate: 24
    Polsat decoder has HDMI-CEC setting but I have it turned off. It worked like that with the previous TV. Changing to "On" also doesn't do anything ...
    Pioneer has only one optical input so I won't hook up Polsat because I have TV sound connected (Youtube, terrestrial tv, USB playback). That is why I wanted to have all devices connected to the Receiver as HDMI as before, and from the Receiver with one decent HDMI cable to the TV. As I wrote with BluRay, there is no problem and Polsat is ...
  • #5 16949766
    Polon_us
    Help: 1184
    Rate: 1280
    It also has a coaxial digital audio input - Coax.
    You can consider using a converter - optical to "electrical" signal for this input.
    As everything else fails.
  • HDMI connection mutes receiver speakers when reinserted
    #6 16949834
    PiotrMikler
    Help: 5
    Rate: 24
    That's right, it's a solution. It does not change the fact that we still have no answer why there is no sound via HDMI ... I searched the internet and this problem appears, unfortunately I did not find an answer to its solution ... It usually ends with the use of an optical cable. Strange, because it worked before. Something is obviously "biting", because when I take out the HDMI cable from the TV (The one between the Receiver and TV) is the sound on the speakers connected to the Receiver after a second appears. Re-inserting HDMI to the TV after a second turns off the sound ...
    Maybe someone once solved this problem ...?
  • Clarifying whether HDMI replug changes amplifier output
    #7 16949926
    Polon_us
    Help: 1184
    Rate: 1280
    Is there any change in the amplifier's display after this operation?
    Maybe a friend put pictures (clear) of the display before and after disconnecting the HDMI cable from the TV?
    Polsat decoder must be turned on :) )
    And one more thing - by "fading sound" colleague means that it does not sound at all from the decoder - amplifier and TV - or does it disappear in the amplifier and moves to the TV?
  • HDMI connection to TV disables PCM stereo output
    #8 16950323
    PiotrMikler
    Help: 5
    Rate: 24
    The sound disappears completely. As long as Polsat Decoder is connected to the Receiver, the sound is normal. After connecting the receiver to the TV, the sound disappears. And interestingly, even if the TV is off, there is no sound either. The same BluRay player is working normally and the sound is on!
    Added after 17 [minutes]:
    One picture shows the receiver's display after connecting the HDMI cable to the TV, the other after removing the cable from the TV.
    After removing the cable, the PCM icon appears and the symbols L and R, i.e. it recognizes two speakers, because Polsat usually broadcasts in 2.0
    Re-connecting the HDMI cable to the TV causes PCM, L and R to disappear in the loudspeakers.
    • No Sound Issue with Cyfrowy Polsat, Pioneer VSX-930 Receiver, and Samsung UE55MU7042 TV Setup 20180110_163719.jpg (869.6 KB) You must be logged in to download this attachment.
    • No Sound Issue with Cyfrowy Polsat, Pioneer VSX-930 Receiver, and Samsung UE55MU7042 TV Setup 20180110_163742.jpg (933.14 KB) You must be logged in to download this attachment.
  • Check decoder audio mode and HDMI AMP setting
    #9 16950565
    Polon_us
    Help: 1184
    Rate: 1280
    Well, something is already known ...
    Please check in order as I wrote below:
    - check audio settings in the decoder and change to Dolby or Auto - just PCM!
    - having the situation that the sound has disappeared, enter the Audio settings of the amplifier and check the HDMI (HDMI Audio) parameter.
    It should have been set to "AMP". You can also change them to the opposite and go back to "AMP"
    - could a friend do a test by connecting Polsat's decoder to a socket that uses BR?
    And so off the beaten track ...
    A friend is sure that HDMI Control is turned off? From what I read in the manual, the "S.RTRV Sound" function (shown in the picture) can work when HDMI Control is active.
    Also, something here does not match the colleague's "testimony" :) ))
    After disabling these functions, did a colleague do something quite prosaic, such as disconnecting all equipment from the power supply for a few minutes?
    After changing the HDMI settings, this procedure is recommended.
  • #10 16951365
    PiotrMikler
    Help: 5
    Rate: 24
    So yes: in the decoder sound output - HDMI, Auto mode, HDMI-CEC off
    In the Receiver, I do not have the option of HDMI Audio settings, HDMI Control function disabled
    HDMI-CEC off in TV ...
    I unplugged the equipment for a few minutes ... no changes, unfortunately
    Connecting to another HDMI IN socket on the receiver (including BR) - the same effect - no sound
    I am slowly running out of strength ... :-) We wanted to exchange TV for newer and bigger ones :-) And on the previous one everything was flashing beautifully as I wanted ...
  • #11 16951621
    Polon_us
    Help: 1184
    Rate: 1280
    Hmm ...
    PiotrMikler wrote:
    In the Receiver I don't have the option like HDMI Audio settings,
    I enclose the manual of this receiver - please look at page 86.
    I am already starting to run out of ideas, but I would like to check one thing.
    Can a colleague connect the decoder to the TV directly for testing purposes?
    I am interested in whether the sound will be heard in the TV speakers.
    And privately, I'm not convinced that all HDMI-CEC controls have been turned off.
    If unplugging the HDMI cable from the TV results in immediate reaction of the amplifier, then something must be enabled in the HDMI settings.
    • VSX-930.pdf (19.47 MB) You must be logged in to download this attachment.
  • #12 16951891
    PiotrMikler
    Help: 5
    Rate: 24
    welcome back
    First of all, I want to thank my colleague for your interest in the topic :-)
    In fact, in the Audio options of the Receiver this is the HDMI setting you are writing about and is set to AMP.
    Polsat decoder connected directly to the TV with an HDMI cable obviously produces normal sound. Except that I meant to get rid of this one cable ... Besides, when I connect the Decoder directly to the TV and the sound to the Receiver with an optical cable from the TV, it is first of all quieter than from the Decoder connected directly to the Receiver, and the second is the sound more "flat" less dynamic. That's why I care so that the Decoder was plugged into the Receiver ...
    Added after 1 [hours] 12 [minutes]:
    On page 85 of the manual there is also the SIGSEL (Signal Select) option in the audio settings of the Receiver. It was set to Auto, but even if I "force" the HDMI settings, there is no sound ... As I gave on Digital, this is sound through Coax. I just brought the Optical-Coax converter and it works. Extra cables, power supply but works, and the sound is better than with Optical on the TV.
    As for HDMI, I fell ... I tested all the possibilities and configurations, in turn I turned on and off HDMI-CEC in each of the three devices and nothing .... Massacre.
    But I am still waiting for my friend's help, maybe some idea will be born ... ;-)
  • #13 16952049
  • #14 16952075
    PiotrMikler
    Help: 5
    Rate: 24
    I've already done it a few times ...
  • #15 16952112
    Polon_us
    Help: 1184
    Rate: 1280
    Well, I'm already exhausted of ideas :( ((
    Just out of curiosity - are there any obstacles to using ARC?
    In this case, the connections:
    - optical from TV to amplifier
    - decoder with amplifier via converter
    are unnecessary.
  • #16 16953694
    PiotrMikler
    Help: 5
    Rate: 24
    At this moment I gave up :-)
    It stayed like this:
    Receiver ------ HDMI ----- TV
    Polsat decoder ---- HDMI (Picture) and Optical to Coaxial (Sound) ----- Receiver
    BR player ----- HDMI ----- Receiver
    So let's say how it was supposed to be ...
    And then Optical from TV to the Receiver to listen to YouTube and DVB-T
    Thank you for your help, but I'm not closing the topic yet :-) (Maybe some idea will come up) :-)
  • #17 17707777
    michnik84
    I had the same problem. I additionally had an artifact of the type: I turn on the hd5000 decoder on the channel e.g. 1 + ampli vsx-s520 on the TV appears the image from channel No. 1. Then I switch to channel No. 5 and then on TV I have the image from channel No. 1 and the sound from ampli from channel 5. After a while, the picture on the TV is lost and the info is displayed. "No signal. In addition, all the problems you describe. I fought this month. I returned to the site. They exchanged for another and everything is ok
  • #18 17710760
    PiotrMikler
    Help: 5
    Rate: 24
    For me, the problem disappeared after ...... exchanging the Polsat decoder! There is no problem on the new EvoBox decoder! Everything works as it should! :-)
  • ARC likely required for TV audio output
    #19 19976891
    kocurek5B
    Level 4  
    PiotrMikler wrote:
    So yes: in the decoder, the sound output - HDMI, Auto mode, HDMI-CEC off
    In the receiver I do not have such an option as HDMI Audio settings, HDMI Control function off
    On TV HDMI-CEC disabled ...
    I unplugged the equipment for a few minutes ... unfortunately no changes
    Connecting to a different HDMI IN jack on the Amplifier (including under BR) - same effect - no sound
    I'm slowly starting to run out of strength ... :-) We wanted to replace the TV with a newer and larger one :-) And on the previous one, everything flashed beautifully as I wanted ...
    I think wtv should be on arc. I also have no sound, if I turn off the arc.
The discussion revolves around a sound issue experienced with a Cyfrowy Polsat HD7000 digital decoder connected to a Pioneer VSX-930 receiver and a Samsung UE55MU7042 TV. The user reports that sound is lost when the HDMI cable connecting the receiver to the TV is plugged in, despite the Polsat decoder producing sound when directly connected to the receiver. Various troubleshooting steps are suggested, including checking HDMI-CEC settings, audio output settings on the decoder, and HDMI audio settings on the receiver. The user confirms that all relevant settings are correctly configured, but the issue persists. Suggestions include using an optical connection as a workaround, testing with different HDMI ports, and even considering a factory reset of the decoder. Ultimately, other users share similar experiences, indicating that the problem may be related to the Polsat decoder itself, with some resolving the issue by replacing the decoder.
TL;DR: One confirmed fix was replacing the Cyfrowy Polsat decoder; “Everything works as it should!” after swap. [Elektroda, PiotrMikler, post #17710760]
Why it matters: This FAQ helps you quickly restore HDMI audio when a set-top box, AV receiver, and Samsung TV stop playing nicely.
How do I fix “no sound” from Cyfrowy Polsat through my Pioneer VSX-930 to a Samsung TV?
Start by turning off HDMI‑CEC/ARC on all devices. Set the AVR’s HDMI Audio to AMP and SIGSEL to HDMI. Fully power‑cycle TV, AVR, and decoder. If audio still drops when the TV HDMI is connected, test the decoder directly to the TV for sound. Many users ultimately fixed it by replacing the Polsat decoder. [Elektroda, PiotrMikler, post #17710760]
Why does sound appear when I unplug the AVR→TV HDMI, then vanish when I reconnect it?
The HDMI handshake with the TV changes the audio path, which mutes the AVR input from the decoder. Users saw the AVR’s PCM and L/R indicators appear with the TV unplugged and disappear when reconnected, confirming the handshake issue. [Elektroda, PiotrMikler, post #16950323]
What settings should I check on the Pioneer VSX-930?
In Audio options, set HDMI Audio to AMP. Then set SIGSEL (Signal Select) to HDMI rather than Auto if needed. After any HDMI setting change, disconnect all devices from power for a few minutes to reset handshakes. “After changing the HDMI settings, this procedure is recommended.” [Elektroda, Polon_us, post #16950565]
Does enabling or disabling HDMI‑CEC (Anynet+, Kuro Link) matter here?
Yes. Conflicting CEC commands can reroute audio to the TV when the HDMI link becomes active. Disable HDMI‑CEC on the decoder, AVR, and TV, then hard power‑cycle all equipment to clear cached states. If behavior persists, proceed to decoder testing or replacement. [Elektroda, PiotrMikler, post #16951365]
Should I turn on ARC on the TV/receiver to fix it?
ARC can restore audio for some TVs and AVRs, but it may also complicate routing. One user reported no sound with ARC off and sound returning with ARC on, so testing both states is worthwhile. Document which state yields stable audio. [Elektroda, kocurek5B, post #19976891]
Is the decoder itself a known root cause?
Yes. Two reports show the issue disappearing only after replacing the Polsat unit. One user battled a month before a service swap fixed it; another reported immediate success with EvoBox. Replacement was the definitive cure. [Elektroda, michnik84, post #17707777]
Blu‑ray works over HDMI, but the Polsat box doesn’t—why?
The Blu‑ray’s HDMI conforms cleanly to the AVR/TV EDID and CEC states, while the decoder’s HDMI triggers a conflicting handshake. The TV link then mutes the AVR’s PCM input. This mismatch explains why Blu‑ray audio remains normal. [Elektroda, PiotrMikler, post #16950323]
What quick diagnostic proves it’s an HDMI handshake issue?
Connect the decoder to the AVR and leave the TV HDMI unplugged. If AVR audio appears and its PCM/L/R icons show, then connecting the TV cable and losing that display confirms the handshake conflict. [Elektroda, PiotrMikler, post #16950323]
Can I get sound even when the TV is off?
In the failure state described, no. Users observed that even with the TV powered off, having the TV HDMI connected suppressed audio from the decoder into the AVR. That edge case confirms a control-layer conflict, not user volume settings. [Elektroda, PiotrMikler, post #16950323]
What’s a practical workaround without replacing the decoder?
Send the decoder’s video to the TV via HDMI, and its audio to the AVR via an optical‑to‑coax converter into the receiver’s digital coax input. Users reported better dynamics than routing optical from the TV. [Elektroda, PiotrMikler, post #16951891]
How do I run a 3‑step HDMI handshake reset?
  1. Disable HDMI‑CEC/ARC on TV, AVR, and decoder.
  2. Unplug all devices from AC for several minutes; reconnect decoder→AVR→TV.
  3. Set AVR HDMI Audio=AMP and SIGSEL=HDMI; test again. [Elektroda, Polon_us, post #16950565]
What is HDMI‑CEC in this context?
HDMI‑CEC lets devices control each other over HDMI, which can silently change audio routing. The Polsat decoder includes an HDMI‑CEC toggle; users tested both states while troubleshooting. Disable it first to reduce conflicts. [Elektroda, PiotrMikler, post #16949708]
What does PCM 2.0 on the AVR display indicate?
PCM 2.0 means the AVR is receiving two‑channel uncompressed audio from the source. In this issue, PCM and L/R icons appear only when the TV HDMI is unplugged, proving the audio path is intact until the TV link alters it. [Elektroda, PiotrMikler, post #16950323]
What is SIGSEL (Signal Select) on Pioneer receivers?
SIGSEL chooses which input signal type the AVR uses. Setting SIGSEL to HDMI forces the receiver to take audio from HDMI rather than Auto or Digital (coax/optical), which helps isolate routing problems during tests. [Elektroda, PiotrMikler, post #16951891]
Will a factory reset of devices help?
Factory resets of the decoder and AVR can clear persistent control states, yet users reported no change in some cases. If resets and power‑cycling fail, consider a decoder replacement as the lasting fix. [Elektroda, PiotrMikler, post #16952075]
Is swapping to Cyfrowy Polsat EvoBox a reliable fix?
Yes. A user replaced the older decoder with EvoBox, after which HDMI audio worked normally through the Pioneer to the Samsung TV. “Everything works as it should!” [Elektroda, PiotrMikler, post #17710760]
