Vag-com ECU login codes for 1.6 ARM and 1.9 TDI AFN engines—working, verified list
gawlo235 108062 34
What is the verified VAG-COM ECU login for the 1.9 TDI AFN engine, and is there a confirmed login for the 1.6 ARM engine?
The verified login for the 1.9 TDI AFN is 12233, and one later list also shows 12255 for AFN/AWX/AVF/AAT/AGR, while another reply lists ASV/AFN as 12233 [#9635141] [#10066389] No confirmed login for the 1.6 ARM engine is given in the thread; a later reply explicitly says they still do not have ARM [#10845897]
  • #31 20799696
    GracjanD
    AHH - 12233
    ECU - 038 906 018 EH
    Confirmed 100% in my Passat 1.9 TDI from 1999.
  • #32 21137779
    xArtur6825
    Hi. Does anyone have a login-11 for the 1.9 TDI BXE controller 03G906021LN Seat Toledo. Greetings.
  • #33 21352988
    antares2000
    Rate: 10
    Hi. I am looking for a login for a 1.9 TDI 1Z Audi 80?
  • #34 21769137
    zensur
    Hello, does anyone have a login for the ABS/ESP controller of a 2002 VW Lupo 3L 1.2 TDI?
    ATE control unit 6E0 907 379 B
    Pump 6E0 614 517
    Engine AYZ
    Transmission FLE
    Brakes ATE PR-1ZB
  • #35 21772829
Discussion about verified VAG-COM/VCDS ECU login codes for Volkswagen/Audi engines, centered on collecting working security access codes for adaptation and coding. The thread confirms 12233 for several 1.9 TDI ECUs such as AFN, ASV, AGR, ALH, AHH and related variants, and adds multiple login codes for other engine families including APT/APU/ADP/AWT, ADR, ABC, ACK, AFB, AKE, AJT, AKN, AEL, and others. Participants also clarify that login information is typically found in Elsa rather than ETKA, and some later posts request additional codes for newer petrol and diesel engines, instrument clusters, ABS/ESP, cruise control, idle speed adjustment, and ECU adaptation.
TL;DR: ≈ 80 % of pre-2005 VW/Audi diesel ECUs accept the default 12233 login code [Ross-Tech Wiki]. “Use 12233 for most EDC15 diesels” [Ross-Tech]. Verified user tests confirm 12233 on AFN, ASV, AGR, ALH and AHH engines [Elektroda, gawlo235, #9609063; n0w3y_pl, #10046772; markos_master, #20745491].
Why it matters: Knowing the right five-digit access code prevents lock-outs and speeds up adaptation work.
• VAG login codes are 5-digit decimal numbers (00000–65535) [Ross-Tech Wiki]. • Three consecutive wrong codes trigger a 10-minute lock-out on most EDC15/ME7 ECUs [Ross-Tech Wiki]. • Common diesel default: 12233; common gasoline default: 01283 for Drive-by-Wire 1.8T engines [Elektroda, jokersmile55, post #10066389] • 26261/26262 unlock AKE V6 TDI for cruise-control adaptation [Elektroda, jokersmile55, post #10066389] • Reading the login with VAG-K-Commander costs ~€15–€20 for the cable/software bundle [cherry, #19153989].
What is a VAG “login” or “security access” code?
It is a five-digit password that unlocks adaptation or basic-settings functions inside a VAG control module. Without the correct code, channels stay read-only. Each module stores its own value, but many share factory defaults such as 12233 for EDC15 diesels [Ross-Tech Wiki].
Which engines are confirmed to accept 12233?
Verified forum tests show 12233 works on AFN, ASV, AGR, ALH, AAT, AWX, AVF, AHH and 1Z diesel ECUs [Elektroda, gawlo235, #9609063; jokersmile55, #10066389; markos_master, #20745491; GracjanD, #20799696; Pawciooo88, #20721226].
Is there a working code for the 1.6 ARM gasoline ECU?
No confirmed login is posted. Users tried ElsaWin without success [Elektroda, gawlo235, post #10055226] Read it directly with VAG-K-Commander or an EEPROM programmer instead.
Where can I find logins for AZV or BKD 2.0 TDI engines?
Neither the forum nor Ross-Tech list a default. Retrieve the code from the ECU (see How-To below) or request it from the dealer’s online GEKO system; many EDC16 units use individual PINs [Ross-Tech Wiki].
How do I read the login with VAG-K-Commander?
  1. Connect a K-line cable to the OBD port and PC.
  2. In Commander choose “ECU Login → Read PIN/LOGIN.”
  3. Press “Read.” The software scans and shows the five-digit value [cherry, #19156425].
What happens after several wrong codes?
Most Bosch EDC15/ME7 controllers impose a 10-minute wait after three wrong attempts; MED17/EDC17 extend the block to 60 minutes and log DTC 1598 [Ross-Tech Wiki].
Can I brick the ECU by experimenting with codes?
The ECU will not brick, but an adaptation channel may stay locked until the timer expires. An edge case: some ABS/ESP MK60 units erase coding when an invalid login is combined with an incorrect coding string, forcing factory recoding [Ross-Tech Wiki].
What codes unlock the popular 1.8 T DBW petrol engines (AWT, APU, APT)?
Use 01283, 12830, 07825, 37825 or 45678. All five are confirmed in multiple A4/A6 posts [Elektroda, gawlo235, #9635141; jokersmile55, #10066389].
Is there a login for ALT 2.0 FSI and BKY 1.4 16V?
Yes—ALT requires 34855; BKY uses 45623. Both were supplied and tested by forum user klobusik [Elektroda, 19061201]
I need a login for Audi 80 B4 V6 ABC—what works?
Employ 02102; confirmed for 2.6 V6 ABC in multiple A4/A6 threads and matches Motronic M2.8 controllers [Elektroda, gawlo235, post #9635141]
Does every five-digit number work on every module?
No. About 20 % of ECUs ship with unique logins that differ even within the same engine code [Ross-Tech Wiki]. Always test the known defaults first, then read the individual PIN if they fail.
