Audi A6 C5 1998 1.9 TDI: Coding New Clocks (4b0 919 880G) & Adapting IMMO - Full Cash Process
mimax1 9378 13
How do I code replacement clocks and adapt the immobilizer in an Audi A6 C5 1998 1.9 TDI, and do I need to replace the transponders?
You do not need new transponders; the old ones should work, and the procedure is to synchronize the cluster with the ECU first, then adapt the immobilizer using the PIN [#16292400][#16292405] Read the EEPROM with VAG EEPROM Programmer or VAG K+CAN Commander to obtain the PIN [#16268569] In VCDS/VAG-COM go to Instruments, Login, and enter the PIN with a leading zero if needed (for example 1234 becomes 01234) [#16268569] Then use Adaptation, channel 00, test/save/OK to synchronize the clocks with the ECU [#16292400] After that, go to Adaptation channel 21 and enter the number of keys you want to adapt; cycle each key until the immobilizer light stops flashing [#16268569] For the 1998 Passat/Audi-style setup mentioned in the thread, the same procedure applies and the old ID48 transponders are fine [#16294864]
  • Seeking guidance on cluster coding and immobilizer PIN adaptation
    #1 16264231
    mimax1
    hello, how to code new clocks with full cash, I have an analog watch with 4b0 919 880G designation, so I do not have to replace the tablets or do I have to for what?
    pomorze someone when adapting immo and reading the pin, not quite i am checked in vagcom and downloaded eeprom.
    , hope enough for these operas? , usually I only did error reset, dose setting and injection angle after replacing the timing.
    car Audi A6 C5 1998 1.9 TDI
    vin cars
    4BZWN163069
    ori counter no
    8L0 919 2 / 2A
    i am not sure about the first digits in the ori numerator
    _________________
  • #2 16267198
    invector
    Help: 24
    Rate: 103
    The pin of the new clocks is needed. Upload the batch on the forum as soon as you "downloaded" it, we'll see.
  • #3 16267419
    kris-644
    Help: 39
    Rate: 74
    Give a pin or a batch or do immo off.
  • #4 16267473
    mimax1
    I have a new counter, you can write how to download the batch,
    UCY 7400
    Help: 37
    Rate: 75
    For this you need vag eeprom programer or vag k + can Commander. You read the eeprom and the program itself practically displays the pin.
    With the pin you are doing the adaptation of the tablets to immo.
    Vagiem or vcds.
    Select
    Instruments
    Login - here you enter the pin preceded by a zero. So if you have a pin 1234, enter 01234. Approve.
    The immo control stops flashing and lights up permanently.
    Then Adapation
    You enter channel 21
    You type in the number corresponding to the number of keys you intend to adopt.
    You approve
    After a while, the immo goes out (it means that the key has been adapted)
    You insert the next key and wait for the light to stop flashing.
    You take out, put the next one, etc. until the last key
  • #6 16292081
    mimax1
    Vagiem or vcds.
    Select
    Instruments
    Then Adapation
    You approve
    thanks, friend, I will try to do as you wrote, from what I managed to determine I have this new clock with immo 1,
    that is, I have to buy new ID13 single-coded transporters, and then follow your instructions,
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Old transponders will fit.
    They are not single-coded.
    You just assume a different counter.
    You still need to synchronize the meter with the ECU.
    So in the adaptation entry counter, channel 00, test, save, ok.
  • #8 16292405
    UCY 7400
    Help: 37
    Rate: 75
    Exactly. No new seeds are needed.
    First, synchronization of clocks with the ECU and then according to my description.
  • #9 16292534
    mimax1
    that is, the guy told me that I have clocks with immo 1 and the car with immo 2 does not have a problem?
    1. adapts the numerator
    2. reads pin eeprom
    3.robie adopts immo
    and it should flicker
  • #10 16292539
    UCY 7400
    Help: 37
    Rate: 75
    You're reading the pin
    Adaptation on channel 00
    You stick with a pin
    Adaptation on channel 21
  • #11 16292629
    mimax1
    ok, thanks if I don't know something during the work, I will write.
    I still have a question apropo passata b5 1998 1.9tdi
    i bought it with one remote control,
    I can buy a second used remote control and code it in this car myself. in the audi a6 c5 I could do so without any problems. I add Audi A6 C5 1998 1.9 TDI: Coding New Clocks (4b0 919 880G) & Adapting IMMO - Full Cash Process photo of the pilot
    grala1
    Help: 1495
    Rate: 5052
    Yes you can.
    Only the remote control with the same frequency - 433MHz.
    Preferably the same no.
  • #13 16292813
    mimax1
    do you remember what the coding procedure was?
    if not, a funeral on the net
    Added after 2 [hours] 3 [minutes]:
    "grala1
    Yes you can.
    Preferably the same numbers. "
    ok, the pilot, I already have everything, the tip too, I just have to fill and encode and immo I can do it in this pass or do I have to buy new transponders?
    Added after 1 [hours] 23 [minutes]:
    Vagiem or vcds.
    Select
    Instruments
    Then Adapation
    You approve
    question apropo passata b5 98r
    the immo adaptation procedure is the same?
    I dismantled the key and there is a glass transponder, is it a one-time coding and I have to buy a new clean one?
    grala1
    Help: 1495
    Rate: 5052
    98 it will be immo2 and old transponders will come.
    There should be ID48.
    The procedure is the same.
The discussion revolves around coding new clocks (4B0 919 880G) for an Audi A6 C5 1998 1.9 TDI and adapting the immobilizer (IMMO). Users emphasize the necessity of obtaining the PIN from the new clocks, which can be read using VAG EEPROM programmer or VAG K+CAN Commander. The adaptation process involves entering the PIN in VCDS, synchronizing the clocks with the ECU, and adapting keys through specific channels. It is clarified that old transponders can be used, and the procedure for adapting a second remote control for a Volkswagen Passat B5 is similar, requiring the same frequency for compatibility.
