#1 16625606 04 Aug 2017 22:00 Blade77 Blade77 Level 2 Posts: 4 » | Topic author Post #1 16625606 04 Aug 2017 22:00 Hello, I have a question about what program I can read immo PIN from Bosch meter
#2 16625784 05 Aug 2017 00:11 sadek1979 sadek1979 Cars specialist Posts: 2569 Help: 237 Rate: 1423 » | Helpful post? (+1) Post #2 16625784 05 Aug 2017 00:11 I see you are using commander 3.6 so you should read the pin without any problem.
#3 16625971 05 Aug 2017 08:51 Blade77 Blade77 Level 2 Posts: 4 » | Topic author Helpful post? (0) Post #3 16625971 05 Aug 2017 08:51 There is a small problem because when I enter the instrument / immobilizer I do not have to choose this type of meter and when I choose the VOD type it still thinks and does not finish reading.
#4 16626592 05 Aug 2017 17:17 Jurek220 Jurek220 Level 31 Posts: 1367 Help: 159 Rate: 256 » | Helpful post? (0) Post #4 16626592 05 Aug 2017 17:17 This is an RB8 counter, if you have nothing else to read, the programmer and on the table will be the fastest. Pozdr.
