DELONGHI Coffee Maker: Clogged Strainers Solutions - Cleaning Brushes, Citric Acid, Valves
sebastikantus 60101 20
How can I fix a DeLonghi coffee maker when the filter/strainer is so clogged that no coffee comes out even after brushing and soaking in citric acid?
If cleaning and descaling do not restore flow, the fault may be in the pressure valve inside the black filter base rather than in the holes themselves; in this thread the machine was fixed by straightening the twisted spring-loaded part in that valve assembly [#9654885][#9655105] The filter on this DeLonghi EC 300 is a crema filter made of several elements, so it can be disassembled and cleaned, including the boiler outlet and the small holes in the metal filter [#9651049] If cleaning still does not help, the advice was to replace the filter/strainer assembly, which was said to cost about PLN 35 [#9651495]
  • #1 9650609
    sebastikantus
    Rate: 40
    Listen, I don't know what to do anymore.
    Everything points to the fact that my sieves are so clogged that there is no coffee coming out at all, the water pressure is for sure because only pure water is released with the sieves removed, the valves, as I do not know. I scrubbed these strainers with brushes, soaked in citric acid and nothing.
    What other options are left for me ????
  • #2 9650666
    gayetan
    Help: 16
    Rate: 75
    1 / Buy new strainers on the site.
    2 / Check with a different type of coffee
    Ev. service as it may be too low vapor pressure. What you can not check "by eye".
  • #3 9650713
    sebastikantus
    Rate: 40
    Hmmm, but the water does not run even when only the strainers without coffee are inserted.
    Let's see, I will try 1 strainer first with the purchase
  • #4 9650730
    gayetan
    Help: 16
    Rate: 75
    Well, 95% - bad news - damaged pump. I think it will be difficult without the service ... but because this is bad news, maybe someone else will have an idea ..
    Good luck
  • #5 9650747
    MARCIN.SLASK
    Home appliances specialist
    Help: 1033
    Rate: 2642
    What exactly is this coffee machine?
    The strainer (with holes) is clogged or the Crema filter?
    How old is the coffee machine?
    What is the hardness of the water?
    What coffee do you use for this machine?
  • #6 9650787
    sebastikantus
    Rate: 40
    The coffee machine is a Delonghi 300, the screens where you put the coffee are clogged, as I looked at them under the magnifying glass, each hole is surrounded by a small black border.
    The coffee machine is about 3-4 years old.
    As I wrote, the water flies without a problem when there is no strainer
    I use coffees intended for the coffee machine
    I do not know the hardness of the water
  • #7 9650800
    MARCIN.SLASK
    Help: 1033
    Rate: 2642
    So it's the EC 300, the strainers, it's a Crema filter ( Link ).
    Did you disassemble and clean it regularly?
    A total of 3-4 years, it's probably a filter to be replaced. The pump will be rather operational.
  • #8 9650882
    sebastikantus
    Rate: 40
    Well, I don't know where the filter is, is it the strainer that is kept underneath in the coffee machine by a small screw ???
    Yesterday I unscrewed this screw, took out the strainer, cleaned it and screwed it on again.
  • #9 9650923
    MARCIN.SLASK
    Help: 1033
    Rate: 2642
    The filter is the one you pour your coffee there (unless you have a different one). There were these filters for 1 or 2 cups.
  • #10 9651014
    sebastikantus
    Rate: 40
    Well, but in this filter there is probably nothing to get clogged because there are 2 large holes and a recess into which these strainers are packed in such a metal housing.
    Something in this filter needs to be cleaned ????
    The best part is that I have the instructions, but no drawings.
    This is a quote from a manual I found on the web:
    "cover.
    o Remove the gasket.
    o Rinse all components thoroughly
    clean the metal filter wiping with warm water
    brush (fig. 23).
    Check that the holes in the metal filter are not
    clogged. If so, clean them with
    pins (see fig. 24).
    o Reinstall the filter and the gasket on the plastic
    the dial as shown in Figure 25.
    Be careful when inserting the plastic plug
    on the blade into the seal hole indicated by the arrow on the
    Figure 25.
    o Put the received set into the steel adapter
    onto the filter (fig. 26), making sure that the pin remains
    correctly inserted into the base (see arrow
    in fig. 26).
    o Finally screw on the cover by sliding it
    clockwise (Fig. 27).
    The warranty will be void if the above
    cleaning will not be performed regularly
    carried out.
    CLEANING THE BOILER OUTLET
    The boiler outlet should be cleaned at approximately every 300 coffees
    as follows:
    1. Make sure the coffee machine is not hot and
    the plug is removed from the socket.
    2.Use a screwdriver to loosen the fixing screw
    espresso boiler outlet filter (fig. 28).
    3.Clean the boiler thoroughly with a damp cloth.
    4.Clean the boiler outlet thoroughly using warm water and
    rub with a brush.
    the pins (fig. 24).
    5.Rinse the boiler outlet under running water, always
    wipe.
    6. Reattach the boiler outlet.
    carried out.
    DESCALING
    It is recommended to descale the machine
    after about 200 coffees or a maximum of
    two months of use.
    It is recommended to use special products for
    descaling espresso coffee machines that are
    available on the market.
    If these products are unavailable, you can take
    following steps:
    1. Pour about 0.5 liters of water into the water tank.
    2. Dissolve 2 tablespoons (about 30 g) of acid in it
    lemon (available at pharmacies).
    3. Press the On / Off button and
    wait until the OK indicator light comes on.
    4. Make sure the filter adapter is not
    attached and place the receptacle under the outlet
    devices.
    5. Press the brew button, allow
    half of the solution contained in w drained out
    container (turn the knob from time to time
    steam and drain a small amount of solution), a
    then press the brew button again.
    6. Switch off the device.
    7. Let the solution run for approximately 15 minutes
    minutes and then switch the machine on.
    8. Press the brew button until complete
    emptying the tank.
    9. To remove residual solution and sediment
    calcium deposits, rinse the reservoir well,
    fill it with fresh water (do not dissolve it
    citric acid) and put in its place.
    10. Press the brew button and let the solution
    it flowed all the way out of the reservoir.
    11.Contain the flow of water and again
    repeat steps 9 and 10. "
    MARCIN.SLASK
    Help: 1033
    Rate: 2642
    Wrong.
    Link this is a grip / stock.
    Link it is a filter.
    The photos may be slightly different as this is just to explain what what is.
    The filter consists of three basic elements (as shown earlier). At the bottom, you unscrew the black cap and push the center of the filter out of the metal housing.
    Normally, every dozen or so coffees should be unscrewed and washed the filter elements. But now, it only remains to replace it with a new one.
    I add drawings - how to clean:
    • kons.pdf (669.15 KB) You must be logged in to download this attachment.
  • #12 9651084
    sebastikantus
    Rate: 40
    Oh, thx now at least i know what's what.
    So it remains to buy a new strainer or the entire filter and how much does it cost ???
    MARCIN.SLASK
    Help: 1033
    Rate: 2642
    You can still try to open it and clean it. If it doesn't help, it's new. Price around PLN 35 total ( Link ).
  • #14 9654588
    sebastikantus
    Rate: 40
    The best thing is that when released by the strainers itself, it flies without any problems, but the flow of water is blocked by the black element on which the strainer lies and sticks tightly to it.
    What could that mean ???
    I checked it many times, it is sure that the filter is properly assembled and cleaned
  • #15 9654885
    MARCIN.SLASK
    Help: 1033
    Rate: 2642
    This item includes a pressure valve. It is probably damaged.
  • #16 9655080
    sebastikantus
    Rate: 40
    How to check it ???
    What should be seen, here is a photo please
    I just don't know if they will be visible
    It is intentionally brightened
    • DELONGHI Coffee Maker: Clogged Strainers Solutions - Cleaning Brushes, Citric Acid, Valves DSC00271.JPG (205.38 KB) You must be logged in to download this attachment.
  • #17 9655105
    sebastikantus
    Rate: 40
    Look, I fixed it !!!
    There is a spring in this black one and it holds something that was twisted and I corrected it and it works !!!
  • #18 9655881
    gayetan
    Help: 16
    Rate: 75
    Well then congratulations! Good to know! Always a few zlotys in your pocket!
  • #19 9656109
    sebastikantus
    Rate: 40
    Heh thanks, but I tried to figure out what happened.
    I wanted to give up and buy new ones, but I went by elimination.
    The coffee machine is cleaned like never before :)
  • #20 18367664
    oznaczone
    Hey, I had a problem with a clogged strainer DELONGHI Coffee Maker: Clogged Strainers Solutions - Cleaning Brushes, Citric Acid, Valves
    I knew that it was a strainer, and not another fault, because the second strainer, which was included in the set, could make coffee.
    I put the strainer into boiling water with citric acid. I held for a few minutes and it works as before.
  • #21 18488480
    bartishii
    I, in turn, treated the strainer as above after clogging with all the specifics and nothing helped. Finally, it helped to make the strainer red hot over the gas, hold it for a few minutes for the muck to burn out and then throw it into cold water. Works like new. Kisses
✨ The discussion revolves around issues with a clogged strainer in a Delonghi EC 300 coffee maker, where the user experiences no coffee flow despite water passing through without strainers. Various solutions were proposed, including purchasing new strainers, checking the pump, and cleaning the filter components. The user confirmed the machine is about 3-4 years old and uses appropriate coffee types. After troubleshooting, it was discovered that a spring mechanism in the pressure valve was misaligned, which, once corrected, restored functionality. Other users shared their experiences with similar clogs, suggesting methods like boiling with citric acid or heating the strainer to clear blockages.
