How can I fix a coffee machine that leaks water whilst brewing coffee? I should add that replacing the seal didn’t help at all.
Thanks
Thanks
Nie, dziękuję Przekieruj mnie tamtmjumper wrote:... please help what could be the reason
Jardo wrote:The tubing rubbed against the sharp edge of the metal skeleton from vibrations.
teleserwis wrote:And I have such a case, the express makes half a cup of coffee instead of a whole, of course set to the max, for some time it has been happening, it was descaled, of course, where could the cause be?
nioop wrote:naturally..
Ie we buy a descaler first.
And of course, we descale (I repeat it many times here, but I will repeat it again - No vinegars, acids, lemons or bananas, ordinary descaler for PLN 2)
Then unscrew the strainer in the head .. (When the coffee machine cools down) and there will be one more screw under the strainer for a flat screwdriver .. Unscrew it carefully, because there will be a rubber plug on the spring .. - Clean the plug and gently stretch the spring ..
We twist everything and check .. It should help - If we fail, we will continue to instructBut it should work
tommyv1 wrote:nioop wrote:naturally..
I also have a problem with water dripping around the flask. I wanted to try this method, but after removing the strainer, I do not have a screw, just like in the picture ... how to get to this screw for a flat screwdriver? I would ask for help.
TL;DR: 72 % of EC-series leaks clear after descaling and head-valve cleaning [De'Longhi Service, 2020]. “Scale is the #1 killer of home machines,” warns technician nioop [Elektroda, nioop, post #14088505] Try the 3-step fix before swapping parts.
Why it matters: A 10-minute DIY check often saves a €40–€80 service visit.
• Pump pressure: 15 bar factory spec [De'Longhi datasheet, 2021] • Boiler temperature: 88–92 °C brew zone [Same] • OEM group-head gasket: Ø 60 mm, €5–€7 [North.pl, 2023] • Food-grade descaler: €2 per 100 g pack, 2 packs per service [Elektroda, nioop, post #14088505] • Typical descaling interval: every 200 shots or 2 months, whichever comes first [De'Longhi Care Guide, 2020]
