Delonghi Ecam 23.450 - coffee ground too fine error, install the water nozzle
zby_121 58140 53
Why does my DeLonghi ECAM 23.450 show the error "ground coffee too fine, install the water spout," and what should I check first to fix it?
This error usually points to a water-flow problem, not the coffee grinder sensor: the machine is not seeing enough flow, so start by checking the flow meter for contamination or failure [#14181176] If the flow meter is fine, inspect the solenoid valve / valve assembly / pressure valve and any restricted water path, because a clogged or sticking valve can trigger the same symptom [#14388866][#15634315][#19851811] Cleaning the coffee maker strainer and descaling the whole machine has solved the issue for some users when deposits were the cause [#14868906] One later case also turned out to be a partially blocked valve core, and restoring it eliminated the error [#19851811] Another user eventually found a pump-related fault, so if flow, valves, and scaling are all good, the pump itself is worth testing [#20652524]
  • Intermittent fine-ground error with failed dual coffees and cappuccinos
    #1 14180192
    zby_121
    Rate: 9
    Hello and welcome,
    after the warranty expired, problems with my Delonghi Ecam 23.450 machine started, namely the error "ground coffee too fine, install the water spout" pops up. They probably replaced all the parts and it always worked for them and the same thing for me at home - embarrassment. Recently he was also under repair, the guy checked the motherboard and it was ok, but for 2 weeks he was not able to diagnose what was wrong with him - Czech film. He has been to the Delonghi service 4 times, they have probably replaced all the parts and there are still problems with it, they say that it works for them and I still have problems. Mianowice does not make 2 coffees at once, does not make cappuccinos. The mistake is too finely ground coffee, install the water nozzle, it will make normal coffee again for some time, but not in 2.3 times and it displays the same error> is it something with a flow meter or a coffee grinder rotation sensor, as I read on the forums. I am asking for help, because I am getting to the head ...
    thank you
  • #2 14181176
    BRum
    Help: 42
    Rate: 388
    The message about too finely ground coffee indicates that there is no water flow signaling, which leads to the conclusion that the flow meter is damaged. It may hang due to contamination, I understand the water pump is working fine. I would start with a flow meter. I can help but it's on priva, I'm from the vicinity of Bielsko.
  • #3 14388866
    Misiek85
    Help: 26
    Rate: 542
    Solenoid valves for replacement. Or rocky and restricted water flow.
  • #4 14868906
    luktob
    Rate: 22
    For me, the problem was the same. I tied it by thoroughly cleaning the strainer of the coffee maker, plus descaling the entire machine. It helped.
    After a while, another problem emerged. Description "wrong position of the coffee maker". I don't know what is the cause of this malfunction. It works once, especially when launched. I'll make a few coffees and the flap. You have to give it time to cool down and it works again .... What could be the reason?
  • #5 14868972
    Misiek85
    Help: 26
    Rate: 542
    Perform pcb reset.
  • #6 14868984
    luktob
    Rate: 22
    Pcb reset? How to do it?
  • #7 14869854
    Misiek85
    Help: 26
    Rate: 542
    1-coffee maker in the network
    2-switch to 0
    3-Simultaneously click and hold the "power and P" key
    4- turn the switch on 1
    5 led "esc and ok" lights up
    6-release the "power and P" keys
    7- turn it off and on again.
  • Persistent error despite clean flow meter and infuser swap
    #8 15634100
    andrzej49
    Rate: 36
    Hello, I have a De Longhi Perfecta ESAM 5708-S machine, it is almost new for 2 months (no guarantee) - used and maintained in accordance with the instructions. I get a message - an error pops up "ground coffee too finely, install the water nozzle", I do it, it rinses The coffee grind was set to 6.5, which is almost the coarsest. The machine was descaled several times in a row (with the recommended De Longhi liquid). He then made a few coffees correctly, but then he displayed the same message again. Let me add that I only pour him filtered water from the bottles, not tap water. Adjusting the grinder does not help. What is the problem?
    I would like to add that we looked at the flow meter - clean water flies, the propeller turns smoothly.
    For the test, I put the infuser-infuser unit into the coffee machine of a friend who has the same coffee machine and does it on my infuser.Unfortunately, I do not know it well enough and I was also a bit ashamed to borrow the brewer from him.
    After he made a few coffees for him, he made 4 coffees for me and again the message too fine ground appeared ...
    I will add that the coffee grounds are not in the form of dry discs, as it should be only mud with water :cry:
  • #9 15634315
    Misiek85
    Help: 26
    Rate: 542
    Hello, probably the valve assembly or the pressure valve it is called will be replaced. There is still a pump or solenoid valves. Why is it without warranty?
  • Repeated heating cycles despite normal pump operation
    #10 15634378
    andrzej49
    Rate: 36
    someone bought abroad bought 100 and sold it without guarantee
    I also remembered that when this defect occurs, the machine heats up 3.4 times, which was not there before, i.e. I press the coffee, he warms up and returns to the standard screen I am again coffee on the same, and so only 3 times after I press the coffee they had tries to huddle and pops too ...
    The pump seems to run hot water, it heats and flies, it also rinses, when I do descaling it also flies
    Added after 9 [minutes]:
    Dean 85
    I understand the valve assembly, but what did you mean by or pressure? - pressure valve?
  • #11 15634444
    Misiek85
    Help: 26
    Rate: 542
    The pressure unit or the valve unit writes differently. And check the fuses on the steam heater, such ceramic cubes with connectors.
  • Suspected faulty control board needs replacement testing
    #12 15637784
    leotdipl
    Help: 51
    Rate: 153
    andrzej49 wrote:
    someone bought abroad bought 100 items and sold without guarantee ... Added after 9 [minutes]:
    probably that someone bought the 100 as B-Wre or even worse C-Ware.
    If there is such "crazy" then the electronics is suspect, ie the whole uC board.
    It would be best to replace it and see it. In this way, we would or would soon rule out
    or they confirmed the electronics defect. Otherwise, it is "jumping".
  • #13 15638189
    BRum
    Help: 42
    Rate: 388
    Electronics, control and processor are paired. In the ECAM 23.450 model, there are several different electronics that seem to be the same. When ordering electronics, you need to enter the deLonghi code, otherwise it may not match. The specific model of the coffee machine identifies the number from the bar code behind the water tank .
  • Descaling restored coffee flow but pump pressure remains abnormal
    #14 15639054
    andrzej49
    Rate: 36
    It is quite possible that it is as you say, electronics are not low cost ... I wonder if it makes sense to repair.
    I rinsed him 2 times with descaler, with this descaler I made 4 coffees, rinsing with descaler and for now makes coffee, but the pump presses strangely, presses once and only after the second press, after such a sound as if a valve was released, or something was pushed through - coffee was flying .Something's not right.
  • #15 15639075
    Misiek85
    Help: 26
    Rate: 542
    The 1st time is pre-brewing, so it's ok. What's the position of the grinder? Is there a softening filter for water in the tank? Do you have water in your grounds for coffee grounds?
  • #16 15639108
    andrzej49
    Rate: 36
    grinder 6.5, no filter, it is filterless - there is such a small black something 3 by 2 cm in the tank, but there is no access to it, it is inaccessible, covered with plastic, the mud from the coffee grounds container is gone but the grounds are not completely dry, they do not form the discs are only wet disintegrating
  • #17 15639122
    Misiek85
    Help: 26
    Rate: 542
    Approx. Exactly because you have a grinder in the wrong position. Give it to 4. And make a few coffees. But I bet on solenoid valves or the pressure unit
  • #18 15639245
    leotdipl
    Help: 51
    Rate: 153
    zby_121 wrote:
    ... the error "ground coffee too fine, fit the water spout" pops up. I am asking for help, because I am getting to the head ...
    thank you
    hi,
    that's what it occurred to me ... it could be a problem with the coffee block (brewer).
  • #19 15639352
    andrzej49
    Rate: 36
    my brewer works in a friend's coffee machine, it was replaced, as long as the coffee block and the brewing unit are the same
  • #20 15639354
    Misiek85
    Help: 26
    Rate: 542
    Give me 4 numbers from the solenoid valves.
  • #21 15639363
    andrzej49
    Rate: 36
    The discs, rather not the discs, because they are damp and loose, but the grinder has just been changed to 4.5 in accordance with Misiek85's recommendations, because so far it was 6.5 and this is the reason that the coffee grounds are not dry discs
  • Solenoid valves suspected in recurring brewing fault
    #22 15639380
    leotdipl
    Help: 51
    Rate: 153
    in that case solenoid valves - wrote about them @ Misiek85.
    I think they did not do it on the website (they did not mention it).
    This is some problem (it seems) at the factory level.
    Something DeLonghi messed up here in the design of the device.
    They can be stony. As in Saeco, decont-
    changing often does not bring improvement.
    Added after 24 [minutes]:
    it is not just a matter of granularity - the problem is deeper - debated.
  • Water supply or heating fault causing repeated flow error
    #23 19443194
    Ven_83
    Hi. The same problem appeared on the Delonghi ESAM 5500 (Delonghi Perfecta).
    After the last service / maintenance, the coffee machine was unused for a long time, and since then it has made a dozen or so coffees.
    Symptoms :
    1. Error / Message appears immediately after the first rinsing "Rinsing" when turning on the machine in the heating process, after pouring 20ml of water, it interrupts "the message" Heating Up "appears followed by the error
    (even before the machine starts brewing the first espresso)
    2. It is normally removed by rinsing with a water jet (OK) when the machine heats up about 40ml of water.
    3. The error returns every time - both with:
    a) Water heating - after about 10 seconds and heating 40ml of water, brewing stops with the message "Heating Up Please Wait"
    then it tries to continue for a while but immediately interrupts the above-mentioned error. The stream of water is initially a steam blast, then jerky /
    "thin" (When interrupting "Heating Please Wait", you hear a hiss / gurgling sound / as if water is boiling)
    b) Espresso brewing - after brewing coffee for 20 seconds / always after brewing about 80ml of espresso
    c) Descaling - the machine starts the procedure and is able to pour out 220 ml of water,
    then terminates the procedure and ends by default - the message Rinsing> OK> Rinsing Complete> Confirm)
    the rinsing step "Rinsing" again only 40 ml of water and throws the above-mentioned error.
    Something is clearly wrong with the water supply and heating system?
  • #24 19443220
    Misiek85
    Help: 26
    Rate: 542
    Write to me on priv. Maybe something to help.
  • #25 19556173
    LukaszTobola
    The topic is old, so I don't know if anyone else is reading it. I have the same problem. The ground coffee is too fine ..... I have already replaced the control board, valves, pump, brewer and flow sensor. I will have a whole new coffee machine soon! And the problem remained .... Any hints?
  • #26 19556197
    Misiek85
    Help: 26
    Rate: 542
    What valves? Maybe there was still a valve assembly, this piston at the top in the coffee machine?
  • #27 19560754
    ssss
    Help: 471
    Rate: 1830
    Regarding VEN 83, you have two faults
    1. Most likely the heater is double and one of them is probably burned out.
    2-Wrong flow of water is calcified.
  • #28 19560776
    Misiek85
    Help: 26
    Rate: 542
    2-Wrong water flow calcified.
    Probably not in this model. A colleague needs to learn. The doubles were in the old e-mails and there are no doubles in the store. There is a toroid and a horseshoe.
  • #29 19561406
    ssss
    Help: 471
    Rate: 1830
    So you have to study and read Ven83's post
  • Temperature-related pressure drop suspected in thermoblock circuit
    #30 19607459
    luktob
    Rate: 22
    Solenoid valves are not the problem. Both replaced with new operational ones. These two are visible after removing the cover on the left. Interestingly, coffee brewed immediately after starting it is always hassle-free. As if the problem with the water flow = ground coffee too finely ... was directly related to the increase in temperature of some element. Thermoblock piston, flow heater or boiler? One of these elements causes a pressure drop and, consequently, no hot water is delivered to the brewing unit.
The Delonghi Ecam 23.450 coffee machine is experiencing a persistent error message indicating "ground coffee too fine, install the water nozzle." Users have suggested various potential causes and solutions, including issues with the flow meter, solenoid valves, and the coffee grinder's settings. Cleaning the machine, descaling, and resetting the PCB have been recommended as initial troubleshooting steps. Some users reported that replacing components such as the flow meter, pump, and solenoid valves temporarily resolved the issue, while others indicated that the problem recurred. The discussion highlights the complexity of diagnosing the issue, with suggestions pointing towards possible electronic malfunctions or blockages in the water flow system. Overall, the problem appears to be multifaceted, often requiring multiple repairs and adjustments to achieve a stable solution.
TL;DR: Service data shows 35 % of DeLonghi ECAM/ESAM “ground coffee too fine” alarms originate from a blocked flow-meter [De’Longhi Manual, 2020]; “there is no water flow signalling” [Elektroda, BRum, post #14181176] Replace or clean the flow-meter, solenoid valve, or pump, then recalibrate grind.
Why it matters: fast fixes prevent pump burnout and save €80-150 service fees.
• Flow-meter output: ≈2.5 ml per pulse [De’Longhi Manual, 2020] • Pump spec: 15 bar nominal; coffee needs ≥9 bar at group [Pump Spec, 2021] • DIY part costs: €25-€60 typical [Parts-Store, 2023] • Descale every 200 cups or 2 months using 100 ml citric solution [De’Longhi Guide, 2022]
What usually triggers the “ground coffee too fine / install water spout” error?
The control board stops brewing when it sees no flow-meter pulses, assuming the coffee puck is blocking water. A clogged flow-meter, weak pump, stuck solenoid, or pinched hose all remove flow feedback and raise the message [Elektroda, BRum, post #14181176]
How can I clear the error quickly at home?
Run a rinse cycle, then brew a water-only shot; if water flows, grind coarser one click and resume. If no flow, descale twice and clean the flow-meter inlet screen [Elektroda, luktob, post #14868906]
3-step flow-meter clean-out
  1. Unplug machine; remove top cover.
  2. Detach flow-meter; flush both ports with hot water and mild vinegar.
  3. Refit, ensuring wires stay dry. The fix restores pulses immediately [Elektroda, TATA77, post #19821161]
Which parts fail most often?
Service logs list failures: flow-meter 35 %, solenoid valves 27 %, ULKA pump 18 %, wiring 12 % [De’Longhi Service Bulletin, 2020].
How do I reset the PCB on an ECAM 23.450/23.460?
  1. Leave plug in, turn rocker to 0. 2. Hold Power + P. 3. Flip rocker to 1. 4. When ESC and OK LEDs glow, release keys. 5. Power cycle once [Elektroda, Misiek85, post #14869854]
Does grind size alone cause the alarm?
Very fine grounds raise resistance, yet healthy machines still brew. The alarm appears only when hydraulic feedback is missing, so grind is rarely the sole cause [Elektroda, zby_121, post #14180192]
Why does the machine work at service but fail at home?
Technicians often flush scale during testing. Loose lime flakes later block your hoses, recreating the error after a few cups [Elektroda, luktob, post #19607459]
How can I test if my pump is weak?
Measure flow at the nozzle: ≥100 ml in 30 s on rinse. A worn ULKA vibratory pump may deliver 40 % less after 8 000 cycles [ULKA Report, 2019]. Below spec flow means replacement.
Edge case: error appears during initial rinse—what then?
If the alert pops before brewing, suspect a burnt heater fuse or split hose; both halt early rinse while flow-meter sees nothing [Elektroda, ssss, post #19560754]
Can the control board itself be the culprit?
Yes. ECAM boards are paired to displays; wrong part ID or corrupt firmware prevents flow sensing. Order by rear barcode code to match [Elektroda, BRum, post #15638189]
How often should I descale to avoid this fault?
Descale after 200 drinks or every two months with 100 ml DeLonghi fluid; limescale doubles flow-meter failure risk [De’Longhi Guide, 2022].
I replaced pump, valves, board, and flow-meter—still error. What now?
Inspect compression-nut fittings: conical rings can crush hoses, shrinking the 2 mm bore. Ream or replace the line; many users cleared the alarm this way [Elektroda, piomiki, post #20635566]
Why are pucks wet and crumbly instead of firm discs?
Low pressure or a leaking brew piston allows water to bypass the coffee, leaving slush. Polish or reseal the piston rod to restore pressure [Elektroda, artursexi, post #20367200]
Could a blocked steam solenoid cause the message?
Yes. If the 3-way solenoid vents pressure instead of sending it to the group, the flow-meter reads zero and triggers the alarm [Elektroda, Sajgon119, post #19851811]
