LG M2262d Monitor: Persistent White Screen Displaying v3.15.0 After Power On
ZoooN 27171 2
  • #1 9680113
    ZoooN
    Hello, I have a problem with the monitor. After switching on the screen is white and at the top a rectangle with the text v3.15.0 shifts. The monitor does not respond to the buttons and only the power cut off it. Does anyone know what this is caused by? Is it damaged or has any service function activated?
  • #2 9764490
    Sly
    Rate: 14
    It is in POWER ONLY mode.
    You can exit it by pressing EXIT on the remote control, it will function normally but the square will continue to run around the screen.
    To completely remove it you must have a service pilot.
  • #3 9997694
    ZoooN
    Pressing and holding EXIT completely solved the problem. Thanks.
