Optimal Operating Schedule for DHW Circulation Pump for Efficiency and Longevity
pawszka 33264 10
How should I schedule a domestic hot water circulation pump to balance comfort, efficiency, and pump wear?
Use intermittent operation or, better yet, demand-based control; 15 minutes on and 15 minutes off is enough and should not harm the pump [#9795036][#9803682] The savings from running it intermittently instead of continuously during the same morning/evening comfort window are only minimal, because the tank will still cool and be reheated when hot water is used [#9795567] If you want the most efficient setup, switch the pump only when hot water is actually needed, for example with a push-button or bell switch that runs it just long enough for hot water to reach the tap [#9803682] Also make sure the circulation pipe is very well insulated, because poor insulation wastes heat and can raise gas use significantly [#9795567][#9796314]
  • #1 9794813
    pawszka
    Rate: 43
    I have a pump installed in the domestic hot water system, which significantly increases the comfort of using hot water. I have it connected via a clock with a programmer. Initially, I had the operating time set between 6:00 a.m. - 10:00 a.m. and 5:00 p.m. - 11:00 p.m.
    I read somewhere that there is no point in having the pump run non-stop. It is enough that during the period we are interested in, e.g. 6:00 - 10:00, the pump turns on every few minutes for a few moments.
    It seems reasonable, but how do you know? turn it on every now and then ? Will such "intermittent" operation harm the pump more than continuous operation?
    Regards
    Paul
  • #2 9795007
    Dacomos
    Help: 125
    Rate: 192
    Well, to control the DHW pump, it is probably a temperature measurement, not a time measurement :?:
  • #3 9795023
    pawszka
    Rate: 43
    maybe the temperature would be a more accurate value, but it would probably be more complicated to control the pump. It`s probably easier with the time trial?
  • #4 9795036
    zybie
    Level 30  
    Help: 133
    Rate: 754
    Just 15 min/15 min is enough, it certainly won`t harm the pump.
  • #5 9795140
  • #6 9795223
    pawszka
    Rate: 43
    I believe that it is not just a matter of saving money on the pump. If the pump were to run all the time, the water in the tank would cool down faster and the stove would be turned on. And this already generates a gas bill.
    The question is how to set it optimally?
  • #7 9795567
  • #8 9795638
    pawszka
    Rate: 43
    I put what I could into the lagging. However, most of them are bricked up and heat the floors.
  • #9 9796314
  • #10 9803682
    ogi4
    Help: 8
    Rate: 60
    In new installations, the bell switch rings at each required hot water consumption, turning on the pump and holding it for the time needed for hot water to flow to the tap. In the old wireless remote control with a transmitter. This is the cheapest circulation operation and very effective.
  • #11 13555080
    pawszka
    Rate: 43
    I set up a time trial that runs in the morning and evening. During the day you have to wait a while for hot water.
The discussion revolves around optimizing the operating schedule for a domestic hot water (DHW) circulation pump to enhance efficiency and longevity. The user initially set the pump to run during specific morning and evening hours but is considering intermittent operation to reduce wear and energy costs. Responses suggest that using a timer for short intervals (e.g., 15 minutes on, 15 minutes off) is sufficient and will not harm the pump. However, it is noted that continuous operation may lead to increased energy costs due to heat loss from the tank. Proper insulation of circulation pipes is emphasized as a critical factor in reducing energy consumption. Some participants mention modern systems that activate the pump based on demand, which can be more efficient than fixed schedules.
