Combined Gas Furnace & Circulation Pump: Central Heating + Flow Water Heater Installation Tips
gazeta12 17766 4
  • #1 16917076
    gazeta12
    Rate: 8
    Whether in a dual-function gas oven without a container inside or without a container next to it, i.e. central heating + flow water heater, you can (should) install a circulation pump on the hot water circulation tube (the so-called third tube). So that you don't have to drain the cold water from the tube until it gets warm. It is quite uneconomical if the stove is further away from the bathroom.
  • #2 16917204
    Flesz
    Help: 54
    Rate: 68
    Circulation is used only in tandem with a storage tank, I have not encountered circulation working with a dual-function furnace.
  • #3 16917720
    BUCKS
    Help: 536
    Rate: 1087
    It depends on the boiler.
    I have an old Vaillant VUW240 / 2-5 and there it was possible to mount circulation on the "bare" 2-function boiler.
    The boiler has a secondary exchanger, which in both circuits has a capacity of approx. A glass, but also has the COMFORT function, which means that the boiler constantly maintains a certain temperature on the exchanger or you can use the room regulator to heat the "tank" or set the time periods in which is to be hot water heated. One-time heating of water in the container takes about 9-10 liters of gas. With circulation, one-time heating would certainly use more gas but how much exactly I have no idea.
    When I had the boiler installed, I had no idea what circulation was, so I did not put it on because of the extra costs, but now I know what a bajer it is and I would certainly install such circulation to my 2-function boiler. Unfortunately, the installation of circulation would mean that I would renovate half of the kitchen, part of the corridor and basically the whole bathroom, so this solution is out of the question.
    I have to wait about 0.5 minutes in the shower until they order about 3.5-4 liters of cold water and heat from the boiler. Circulation would increase comfort and reduce water wastage at the expense of slightly higher gas consumption, but on the other hand you would not have to wait for 0.5 minute, during which the boiler works and the gas flies into the chimney, so for a single heating cycle total consumption with circulation could be on a similar level or even a tad smaller.
  • #4 16917728
    Rysio4001
    Heating systems specialist
    Help: 617
    Rate: 1076
    For starters, there is no information as to what brand and model of the boiler.
    E.g: Junkers had in its offer a model of a two-function, flow-through boiler, which was adapted to connect DHW circulation. Only that this boiler had some modifications for this purpose, and an enlarged plate heat exchanger.
    After this model, I have not encountered a dual-function boiler without a container that would have such a possibility, which does not mean that there are no more such solutions.
    Regards.
  • #5 16952865
    gazeta12
    Rate: 8
    Thanks for the answers.
